NONEED TOSORRYING.THREAD ERFUN BY BYThey are still a completely unknown part (= garbage). Sorry.
-Chris
Andrew...
Why are you wasting our time by posting Duplicate images that don't reside on the DiyAudio server ???
Do you see double somehting, if so than go where need notingtowaste here thats amerian or nasa thingAndrew...
If your info is correct, the transistors are probably output types for car radios.
Possibly germanium such as OC35, AD149
Check with a transistor tester
I told them that I think these transistor are fake, they told me that parallel dies are ok …
Fun fact: If you read the data sheet (by ON or even by NJS), it sais:
"Monolithic construction with built-in base-emitter shunt resistor".
"Monolithic" to me means: One die. Not two.
Not really, in this case it means that the darlington pair is one die, not a small transistor feeding a power device with a discrete resistor emitter to emitter. You can still parallel these die and call them monolithic
Both the 2N568x and MJ1103x series devices have relatively poor SOA at high voltage (drops like a stone at 30V). Likely due to current hogging by one die. Second breakdown is a current hogging mechanism within the die - made worse by voltage. Paralleling dies can't help that situation. They seem to be doing that with their 50 amp transistors - it may be the only way to get a decent beta at 50A, and the single bond wire is probably only good for 25 or 30.
For a while ON was making a version of the 15024 rated at 300 or 400 watts - with two 15024 dies in it. They are not making them anymore - there is probably a reason.
I am beginning to think that these double-die Motorola/ON transistors are real (or maybe fake by design …)
The MJ11032 might be a double-die version of the MJ11016. If you compare a MJ11032 (50A, 120V, 300W) with a MJ11016 (30A, 120V, 200W), you will see that they both drop very steeply above ~35V and that the MJ11032 (blue) is always ~50% above the MJ11016:
But I still don't understand how they avoid current hogging or uneven current distribution. Are the dies matched?
- Design & Build
- Parts
- My Transistors, original or copy?
