900W H-class PA Amp with Limiter
Good day to all DIYers.
Nice build BOSS2009 !!!!!!! Just a suggestion to you if you want to keep the temperature done on heatsink you should turn the module on its side. Because heat rises . If you leave the module like that shown in the photo uploaded your transistors temp will stay high.
please note its only a suggestion !!!!!!!!!!!
Regards.
Audiobrad.
Thank you very much for your suggestion Audiobrad...
Best Regards
H900
H900 in commercial amplifier whose pcbs burnt beyond repairs😉
Corrected from post 246. Anyone doing class H should be able to figure it out, but...
Hi all
I introduce you another version of a switching Rail H class from 900W H class amplifier.................I found this diagram on a Russian forum, VEGALAB , I hope you enjoy !
This schematic does not use expensive , obsolete or rare components, and will not pose problems when designing PCB
OK obviously
But why u don't tried h900 three tiered for less heat and so less weighted heatsink
And the term of heatsink size matters course we never buy airplane for distance of 5kilometers
Hahahah
A 2-step class-H produces 30% less heat than same rating class-ab and a 3-step class-H produces 45% less heat.🙂
It also helps in handling reactive loading of output stage, since the VCE across transistor reduces very much in Class-H, Hence less heat and much safer operation.
hi mr Apex please advice i wanted to make class h 3steps because of the above reasons wanted to use es1d , lm 311, irfz44 , (4pairs) c3856 , a1492 , mur860 , voltage to be used dc +135 , +90 , +45 0 -45 , -90 , -135 dc
please advice . i am even willing to use complimentary step up fets eg p channel irf5210 and n channel irf 3710 . like the below pictures
i hope to achieve to drive low impedance like 2ohms less heat and to use widely available parts like es1d , lm311 irfz44 /irf1010 , c3856 , a1492 , mur860
thanking you all in advance steve
  • lm 311 diyaudio.com 900W H-class PA Amp with Limiter pg 25 lowside_correct .PNG
  • lm 311 step QSC-RMX5050 amp and power supply .pdf
  • lm311 half 900W Class H Power Amplifier - Page 7 - diyAudio  2kW power Amplifier.jpg
  • lm311 step 900W H-class PA Amp with Limiter Page 127 Switching Rail H Class.jpg
How much heat will you be putting into the heatsink?
What is the Rth s-a of the heatsink?
What is the orientation of the heatsink?
Now use that information to find out the temperature of the heatsink and from there the De-rating Factor to apply to your output devices.
