900W H-class PA Amp with Limiter
a new version of PCB for this amplifier ,is not yet finalized, I'll be back with the final version for corrections
Anyone please info about PCB layout H900 Below, if this pcb lay out corect i will etcing the PCB.
Thak You
Hi all
I introduce you another version of a switching Rail H class from 900W H class amplifier.................I found this diagram on a Russian forum, VEGALAB , I hope you enjoy !
This schematic does not use expensive , obsolete or rare components, and will not pose problems when designing PCB
it" my transformer for apex h900 part II
transformer for apex h900 part III
this transformer u winded or bought?
what is the ferrite size?
what is the wire gauges u used and how many turns for primary and secondary? how much cost for one transformer ?
I created this travo own
I use a silicon steel / crgo as its core
imported from japan
10cm high
3.8 cm thick
7.5 cm diameter circle in
cores weighing 9.5 k
primary wire 1.5 mm
secondary wire 1.8 mm
with turn ratio of 1.5
spent approximately USD 1,000,000 (U.S. $ 90)
and need the time at least for 3 days to finish 1 unit travo
Sorry my english
