This required a password,do you know the password?Hello ... Please check out this post #2512 by Mr. Liem Poo..
Good day to all DIYers.
Nice build BOSS2009 !!!!!!! Just a suggestion to you if you want to keep the temperature done on heatsink you should turn the module on its side. Because heat rises . If you leave the module like that shown in the photo uploaded your transistors temp will stay high.
please note its only a suggestion !!!!!!!!!!!
Regards.
Audiobrad.
Thank you very much for your suggestion Audiobrad...
Best Regards
Hello Thimios... Please check post #2581
H900 in commercial amplifier whose pcbs burnt beyond repairs😉
Nice
Hello apexaudio
greetings can H900 be upgraded 7 pairs in out put section MV 70DC +/-
HV 140DC it would be nice a sucessor to h900
warm regards
Andrew
warm regards
Andrew
Good Luck For You...........
Best Regards
His Liem Poo.Good Luck For You...........
What is the highest voltages you used on the H900tef from Dan C.
Sent from my E2105 using Tapatalk
Good day Mr. Andrewlebon.
What is the highest voltages that i can use on the h900tef from Dan C ? 160,80,0,-80,160 vdc ? Or is it standard 120,60,0,-60,-120 vdc?
Increase rail voltage to 120v-60v-0-60v-120v, and you have 650w at 8 ohms, but 4 ohms will be minimum speaker impedance. With 110v-55v-0-55v-110v rail voltage you can run 3x8ohms (2,7ohms) speakers in parallel per channel.
sir,
I have 2 Identical transformer rated 40 0 40 1000va .How can manage psu for apex h900 by using this 2 transformer..??
sir,
Yes you can,
when connected in series you will end up with 80 40 0 40 80Vac
Does the PSU for the h900 use a centre tapped supply or does it need separated secondaries?
The diyaudio Offers You
I need a full diagram of the Apex H900Fet I like and want to assemble it you can share this circuit helps me not to thank
Good evening.
I would like to wish all the members of diyaudio a blessed CHRISTMAS and a happy new year. I hope too hear from everyone in the new year! And THANK YOU to all the contributes which makes site super great! I can't wait to learn more.
Corrected from post 246. Anyone doing class H should be able to figure it out, but...
Hi all
I introduce you another version of a switching Rail H class from 900W H class amplifier.................I found this diagram on a Russian forum, VEGALAB , I hope you enjoy !
This schematic does not use expensive , obsolete or rare components, and will not pose problems when designing PCB
OK obviously
But why u don't tried h900 three tiered for less heat and so less weighted heatsink
And the term of heatsink size matters course we never buy airplane for distance of 5kilometers
Hahahah
A 2-step class-H produces 30% less heat than same rating class-ab and a 3-step class-H produces 45% less heat.🙂
It also helps in handling reactive loading of output stage, since the VCE across transistor reduces very much in Class-H, Hence less heat and much safer operation.
hi mr Apex please advice i wanted to make class h 3steps because of the above reasons wanted to use es1d , lm 311, irfz44 , (4pairs) c3856 , a1492 , mur860 , voltage to be used dc +135 , +90 , +45 0 -45 , -90 , -135 dc
please advice . i am even willing to use complimentary step up fets eg p channel irf5210 and n channel irf 3710 . like the below pictures
i hope to achieve to drive low impedance like 2ohms less heat and to use widely available parts like es1d , lm311 irfz44 /irf1010 , c3856 , a1492 , mur860
thanking you all in advance steve
lm 311 diyaudio.com 900W H-class PA Amp with Limiter pg 25 lowside_correct .PNG36.1 KB · Views: 2,285
lm311 half 900W Class H Power Amplifier - Page 7 - diyAudio 2kW power Amplifier.jpg326.5 KB · Views: 2,189
lm311 step 900W Class H Power Amplifier Page 7 - 2kW power Amplifier.GIF95.4 KB · Views: 2,059
lm311 step 900W H-class PA Amp with Limiter Page 127 Switching Rail H Class.jpg143.3 KB · Views: 1,794
Hello sir mile.
Is this heatsink suitable for 2 H900 in bridge mode
Waight is about 1.3kg 12"x5.5"
And I'm using wire wound .33r is it okay or need to change?
How much heat will you be putting into the heatsink?
What is the Rth s-a of the heatsink?
What is the orientation of the heatsink?
Now use that information to find out the temperature of the heatsink and from there the De-rating Factor to apply to your output devices.
- 900W H-class PA Amp with Limiter
