[Headamp] upgrading a Lehmann BCL clone
Offset:
Thanks but is easy to do. 😱
You can buy the chassis on ebay and the R-core too.
This chassis is for Lehmann clones so is easy work with him. You only need do some holes on the floor. Front pannel is 8mm and have all holes.
R-core is a 15-0 volt X2. I prefer a r-core because It is quieter that a toroid.
I used aluminum feet too for a "luxury look" 😛😛
About emiter resistors, it´s an interesting mod. It would be interesting replaced by 5 Ohm but I think that the hot on MOSFET would be a problem... if you use the original PCB.
Thanks for the hint about R-core transformers. I never used one, but I had a closer look to them right now. It seems that they indeed have some advantages in comparison with toroidals. I think I will give it a try in one of my next projects.
When you say quieter, do you mean less mechanical vibrations or lower stray magnetic fields?
I wonder why R-cores are rarely used in commercial audio products, are they more expensive?
Yes and no. I had some tries with different BIAS currents on my test setup (breadboard).
In one case BIAS ran away till transistors started to smoke. I don´t know what happened, probably a mistake in my setup? I had a debate about that with damon1983 (via PM) and he stated that it´s no problem to increase BIAS up to 500mA.
In the moment I can´t give any instrutcions, because I don´t see clear regarding this topic.
Yes you are right, 500mA BIAS is overkill for a headamp.
But anyway, higher BIAS requires bigger heatsinks. I´m not sure if original heatsinks are sufficient.
And original stock heatsinks are not heatsink, it's like a scary joke.😡
I don't know, why they made bias 40 mA for discrete's class A. If needed low power amp - THS4062 (as example) will be enough.🙂
2V RMS to 4R+0,47uF measurements. (THD 1 kHz=0,46%) (BIAS=175 mA)
