Post your Solid State pics here
Cute Monster ,man. 🙂
Hope you don't have local neighbors - that's a KW total AB amp there !
PS - 25C ? at 60ma bias ? I sort of predicted that. My Slew is in a case
about in between your two. I get about 32-35C . 40C if I really crank it.
OS
Thanks. 🙂
The closest neighbor lives ~30 m from my house. No complains yet. ;-) I run it at around 70ma bias, it idles around 20c above ambient. The 25C picture is showing room temp with the amplifier switched off.
Another Lcduino with attenuator almost finished. This is going to be used with rotel rda975 dac and the Honey Badger. I also built a Y1/Y2 for the other stereo.
My power amp - CF-FET-V2.0
OK, it's already described in CF-FET thread, here are just some pictures.
Starting from the front-end PCB and early prototype testing, and ending with a finished "product".
I'm using it as a main power amp in my audio system now 😎
Rod Elliot P101 build
Inspired by Burning Amp, I just finished my new power amp. This is Rod Elliot's design, with his soft-start board and a diyaudio power supply board.
Shockingly clear and analytic so far with my (ridiculously efficient) Pi Seven speakers.
The case is not what I would like aesthetically, but for now it does the job. The metalwork is part of an earthing network that terminates in a star by the IEC socket and at the output end of the power supply.
tim
tim
Neat.
