FDW, what's the 'spring' ?
The one on the amplifier board Boucherot cell - Wikipedia, the free encyclopedia (protects against excessive capacitive loads, and prevent HF from entering the amplifier (via the GFB))
The one on the LS connector board http://en.wikipedia.org/wiki/Choke_(electronics) (blocks the LS-cable for being an antenna)
PS
do not listen to me as zobel is on separate boards BTW
It is a distributed-zobel-network some on the main board and some on the auxiliary boards.
I reckon it's a hamster wheel connected to a generator.
When the mouse (or other rodent) is caught in the mouse trap, it is then lured into the wheel. Whirling like a crazed dervish this generates the power for the Amp.
When the mouse (or other rodent) is caught in the mouse trap, it is then lured into the wheel. Whirling like a crazed dervish this generates the power for the Amp.![]()
That's some mouse ( a (near) 2KW rodent)
The good thing is that i have slimmed down a bit......
Some of us may envy you.
Frans, I'm so sorry, I can't envy you all the time.
One amplifier finished in 8 days, one other (just starting) to be finished in 2.5 days
Pictures of the first build can be found here: https://www.flickr.com/search/?text=ton's signatureorigin&user_id=17267211@N05
(just starting)
I'm sorry, I only had time to look at the PS board stands with the Belleville washers.
this has nothing to do with phonostages but it is intertesting nevertheless :
https://xiph.org/~xiphmont/demo/neil-young.html
