Test & Measurement interface for Soundcard
Its not the diodes at the input that have been removed but the diodes before U8 (the output line driver) that are discussed these are sized to clip just slightly above the meter range causing not quite ideal use of the dynamic range on some soundcards.
I suggest that instead of removing D10/12, D11 / D12 be replaced by a string of 1N4148 diodes the number of is suitably selected to put the protection limit closer to the full scale voltage of the soundcard YOU are using.
Note: I got better THD (flatter increase) vs frequency by using THAT parts for the line recievers/drivers) (see posts a few pages back)
Did you mean replace D11 / D13?
Here are some amp measurements before I static shocked my 2i2 to death :/ This is an emotiva Mini-X A-100 at -3db from max output, about 26 WPC @ 8 ohms
USB vs Battery power
attachment.php
attachment.php
I added two more diodes inline with D11 and D13 and put D10 and D12 back. This causes the output signal to get clipped around 12Vpp
About the lamps.
The link does not work (anymore), and so I think you must mean these:
12V Microlamps (2-Pack)
Model: 272-109, Catalog #: 2721092
I have some X-Mass ornament micro lamps left and will try those.
Tks!
I just switched these to xmas lights since they're meant for 120v and I didn't realize I grabbed the 12V lamps from radio shack... not that I think it will make a terrible difference, but I was curious.. They both end up measuring the same.
Hallodeletue, I see from your picture that you use little circuit boards with chips on them in place of the input resistors. Can you share that circuit with us? Is it better/equal to using lamps?
I also see a mod north of the DC-DC convertor, probably dealing with the DC input voltage. Care to share that with us?
Tks,
Paul
