Test & Measurement interface for Soundcard
I see the description of the device on Pete Millet, is there a user manual to explain in more detail testing/calibrating of this device? I read through the thread and got some ideas but my level is quite low and it would be better if there is an user manual.
For software I see ARTA has been recommended more recently, AudioTester is no longer available. ARTA is also now freeware, you cant beat the price.
What are the recommendations for an USB soundcard?
Here is how to do the adjustments (link to the source):
pmillett said:
After you stuff it, you need to make a couple of adjustments to calibrate the meter section. There are two adjustments on the board. One is to zero the DC offset of the input amp - this could probably be left out with no ill effects. Basically you set the range to 200mV, short the input, and turn the pot to get as close to a zero reading on the DPM as you can. You will never quite get to zero, because there is AC noise here as well. Mine"zeros" to 0.3mV.
The other adjustment is a full-scale adjust. If you have a calibrated AC voltmeter, you can set the full-scale adjust to make the DPM match the reading on your meter, with the input signal of your choosing. If you only have a DMM, you can use it - just feed in a 50 or 60Hz signal (filament voltage would work) to both your DMM and the soundcard interface, and adjust the full-scale pot so the reading you get matches your DMM. (Don't try this with any other frequency, or anything but a sine wave, unless you have a really good DMM - most are only accurate on line frequency).
Reactions: Eliad
I found an EMU 0404 on ebay sold as is for a very good price. I took a gamble on this. I got it working.
If anybody it trying to make EMU 0404 work on Win11. Search for this driver
EMUU_PCAppDrv_US_1_40_00_BETA. This was developed for VISTA.
At least for my system seems to be working. Apparently this driver can work for EMU 0202 too. With this driver I can use ARTA or REW.
I have the EMU 0404 and i read there are some mods which are recommended, can anybody point me to the more detailed information on this?
Reactions: Kravchenko_Audio
