TPA3116D2 Amp
For those wanting to try the same value cap but a different mfg other than Panasonic, here is the Nichicon and Panasonic data sheets to compare.
The Panasonics are a few bucks cheaper. But one has to wonder, the specs are exact from what I can see, im thinking Panasonic might be private labeling this cap for Nichicon...
http://www.mouser.com/ds/2/293/2012fpcap_catalog_nu-5085.pdf
http://www.mouser.com/ds/2/315/SEPF_OS-262370.pdf
Datasheet tell you the Oscon is a little bigger, but in real life the Nichicon is a little bigger then the Oscon 🙂
Interesting, in the pic the Oscon looks fatter.
Let us know which one sound better, probably only a bat can tell the difference between the two 😛
Lenght is most visable size difference, diameter Oscon also is a little less, but closer or further from camera does have impact on photo 🙂 Oscons rest on metal can on PCB, on Sure3116 that is on + and - soldercontacts for SMD, so plastik can-wrap becomes isolator, possible trouble there.
Can you elaborate on what you mean?
Are you suggesting that the exterior can of the OSCON caps are conductive?
I just put my DMM probes on the can, at the highest resistance sensitivity. Though the OSCON cans look like metal, they are not conductive.
I also checked:
- Two probes on the can
- One probe on can, one on + cap lead
- One probe on can, one on - cap lead
In all cases, I get infinite resistance.
I also checked:
Matt - The cans are aluminum with a microscopic layer of plastic on them. i scraped off a small spot, and they are conductive. All 8 of mine were pressed tightly against the SMD pads on my TPA3110 Sure board. The thin layer of insulation bothered me more than I want to live with, so I melted the solder on each lead (16) just enough to lift the can off the pads slightly. I then dabbed hot glue on each pad under the cap. Problem solved 🙂
This may never present an issue, but everyone should be aware that the Panasonic Oscons could possibly pose a problem 🙁
Is that unique to the OSCONs though? I would assume (just guessing here) that most electrolytic caps are built this way?
I also checked:
The can is conductive, like many electrolytic can, but like many can it has a plastic wrap/foil, like any datasheet mentions this is not for isolation.
It is crimped on by heat... warnings in datasheet/application notes say you should use isolation or leave room or mount them differently (indeed other side of pcb is an option).
So I am preparing for DUGs PBTL boards and I ordered a pair of PSU boards from john broskie at tubecad.com. these are regulated lv supplies and well filtered...dead quiet. I will be ready for "dual mono" when they arrive.
I got a toroid xformer from antek...200va 20v dual secondaries. Since it gets fed raw 28v at 4A after regulation I get exactly 24V after diode/regulator losses. Plus the TPA doesn't draw that much current.
I ran one of the supplies to my hotrodded blue boards and I must say it continues to impress the hell out of me. It thumps like a class ab but sounds like a SE tube amp...TI really worked some magic on this chip.
DaUxzuj958ahSOtvPR2AKsdsmOlB_MPeFJMOKat00zA=w565-h424
LM317? What speakers do you use?
For 8 ohm it could work. I am interested in linear, but I really need much more power. 12A peak(10A continues) 14V is sufficient for 1 channel, for 2 channels bass gets weaker, Revc or better measured resistance speaker with multimeter is 1.0 ohm, DUG's work brilliantly, other pbtl3116's function without problem too, a stereo3116 per channel, biamping, works if volumepot isn't maxed.
