Sorry, I work in the energy sector and learn new techniques here. I just thought why all the TV sets, washing machines etc. have PE connected, must be older gear.
No, NO and NO !!!!!!Youre living in old ages.
Nowadays we have RCD:s (Residual Current Breakers) in almost every home.
Quite OK to break the ground connection with no concern from safety.
The "ground" is today mostly used to avert disturbances from mains interferencies though interference filters.
Johan
You, me and everyone else MUST NEVER break the PE to Chassis connection.
The Safety Earth is there for ONE REASON ONLY. SAFETY
Re: Golmund clone
All the problems are gone ...
The photo shows clear the setup ...
Everyone nows this setup.!!
No voltage ~ between 0 PSU and chassis( ~4mv). No voltage ~ between 0 PSU and L profile.No ringing at all when i connect at L profile with earth GROUND
The sound more neutral clear .
TOMMY1000 thanks for your clear position .
Regards Nikos
Regards Nikos
post2484, right pic:
Is that the Mains Power input socket I can see?
The top pin looks like it is the PE terminal.
That PE terminal MUST have a direct mechanical fixing to the adjacent Chassis. This direct connection should be a green/yellow cable.
Nothing else is allowed to interfere with this SAFETY connection !!!!
Is that the Mains Fuse Holder?
The Mains Power MUST go to the END terminal of the fuse holder.
The power OUTPUT from the fuse holder MUST come from the side terminal.
Who wired up this "Very Best Amplifier"?
They deserve to be put in prison !
AntrewT
Image confusing.
The top pin it is ΝΟΤ the PE terminal
And you confuse us.
The next time you want to say something clean would have to show us a plan how wired the amplifier.
Copyrighted ESP material removed by moderation. Do NOT post copyrighted material here without the permission of its owner. You may link to it instead.
Image confusing.
And you confuse us.
The esp shows the fuse after the switch.
Put the fuse before everything else.
What is showing in post 2484 right pic?
Tell us and then we can interpret what has been done.
You must be some old fashion about this.
There is since many years a thing called Class2, Double Insulated. Just check your drilling machine etc....
All TV and audio sets, consuming less than 2,5Amps (@230VAC), in Europe are now equipped with the EUR-IEC 2 pole contact with no earth.
There is a Class2 6Amps contact too!!
No chassie groundings, as this will also make ground loops with disturbances and hum, leading to inferior sound.
As I said before, the grounding thing was only to make safety to blow the mains fuse if the insulation was shorting. Only to make protection for the chassie not to carry mains voltage.
The ground also serves to be a pathway in mains disturbace filters
Today when all serious installations are equipped with a RCD (RCBO, ELCD) device and sets are double insulated, this is not the case.
Maybe in the UK, most devices are sold with the 3 prong contact, but the ground pin is almost never connected with the chassie.
Only looks like that with the British mains contact
Johan
AntrewT
Image confusing.
And you confuse us.
Earthing (Grounding) Your Hi-Fi - Tricks and Techniques
Μr ....moderation so sorry.
But i have seen many times in this post and other posts show pictures from official data sheet without permission and moderator not involve.
Image confusing.
And you confuse us.
AndrewT
YOU have an obligation to investigate the matter before sent us to jail, οnce you take in the forum so easy the role of self around policeman.
You are still wrong about the compulsory protection system built into all Class1 equipment.You must be some old fashion about this.
Johan
Class11 is very different. Don't use this to conduse the issue over safety for our Class1 projects.
tell us what the pic shows.AndrewT
Re: Golmund clone
Golmund clone box
The construction is in the research stage and was not installed insulation in critical parts.
Golmund clone box
better, much safer.
Now bolt the PE wire direct to Chassis, not to the Star Ground.
Get some Green/Yellow sleeving and sleeve the PE to Chassis wire.
Any electrician will give you a couple of inches.
Thanks AndrewT
When I paint the box I'll do all the necessary changes to cable colors.
Hi .
WANTED amplifier Goldmund Mimesis clone or board for the amplifier is fully ready to use . pm please .
Thank you !
Thank you !
Goldmund 9.2
The boxes have been painted
The amplifier on the bench for the final tuning.
looking good man 😀
I think the transformers chassis will look good in blue or dark orange
that metal work look nice also 🙂
Juan
Juan
- The Very Best Amplifier I Have Ever Heard!!!!
