JG´s Nobrainer and Nobrainer Discrete
Thank you Joachim.
Will try the zeners in parallel with the input for now.
Anyway this was a positive experience for me. Learned how to repair the amp and also tought me never to unplug cables while the power amp is on. (The riaa amp I was using is capable of swinging 20v at the output....)
Incredibly complex it seems.... Can you give me some guidance ?
How could I implement that on the Nobrainer ?
I would not 🙂 the first one is a try to outdo D. Self (and it does) and the second one is the D. Self design (from his book (but fixed)) (it adds some HF artifacts that I do not like). Currently I'm thinking of a better, easier and less complex (but still secure and 'High-end' system) 🙂
Frans (Mastermind 🙂)
I will then wait for your version 🙂
We talked about other ways to put Opamps at the input of a power amplifier.
I find this design quite interesting.
It is a kind of instrumentation bridge.
It gives a 20W class A amplifier.
Sorry for the hard to read schematic.
The original is that poor and i had to blow it up.
HI
I would like made a 100W 4ohm power buffer with an opamp based VAS
Your input buffer (just CCS) is better than input Diamond buffer ?
Sébastien, I do not know why you asked this in a PM and then post the same question here...? but here is a copy of the answer that I gave to the PM.
PM said:
Hi Sébastien,
That is not what I am going to say, if any thing that I made is better (or worst) then others, it needs to be judged by those others, my answer is: Ask RCruze
On the brighter side, I think that using the referenced configuration, with an OPA50x high voltage op-amp, will yield a very good amplifier.
Frans.
