My_Ref Fremen Edition - Build thread and tutorial
Thanks for the reply guys.
Mouser now stock Silmic II at a fraction of the cost of some places - but the nonROHS ones. I may go with these or an NG as a inexpensive starting point. (It feels like a weird conspiracy - realised my Miopia/Dislexia had crippled my search for AMTRANS AMGR, despite being sure I cut and paste, eventually found more stuff on esoteric parts, while also realising that perhaps ordering caps from the Ukraine right now is of question …)
My intentions are building 4 amps as monoblocks to bi amp, and eventually look at matched parallel sets for the bass drivers - this will replace my triamp gain clone set up. Ill start with standard value caps as a base line - with the idea of eventually looking at tuning the each amp via C13 or even C12 and omitting the corresponding parallel inductor or capacitor in the crossover network … etc etc . ( this may never happen…..)
As of now I simply wish to attenuate the input 6dB, playing with the gain is clearly a no no. Halving R13 and adding an identical series MK132 will work - but a series 47k seems a bit big. Or am I missing something?
Man have i stuffed my board??
The idiot i am, wasnt concentrating and soldered caps directly where it was marked not to use 😱
So while unsoldering the caps i scratched the board and exposed copper which is now covered with solder!
Can someone advise on what to do next.
Much appreciated
Ryan
Dario is too fast for me. I was drawing a little pic showing traces to ground plane (blue) and isolation space (yellow). Note there are four traces in those two pads. I suspect even if you lost one the others would be enough.
The bubbling on the mask looks like too much heat was used. Solder wick (copper braid) really helps in a situation like this. I apply some extra Chip-Quick flux on the braid and watch carefully as the solder is transferred off the pin/pad. It is much easier to tell when to remove the heat. Done carefully and slowly from a couple angles the TH parts can actually fall off the board on their own.
Last weekend I had to remove 24 three pin pieces from a different project and learned how well the braid functions if one slows down and watches the action with a good magnifying lens.
Now taking student applications for "Bob's Braid Academy" 😀😀
phew!
That bubbling is the flux residue. So i am all good there. While inspecting the board i found a couple MK132 resistors going the wrong way. So i desoldered them and reversed them.
Is there any way to test the resistors to see if i damaged them while i was getting them out and back in?
man i would love a course like that.
Do you have a common sense course too? 😀
Actually while we are on the topic of board cleaning, can i just bathe a board in pcb cleaner? Will this be covered in flux removal course or common sense course
Just to clear things up on my pondering (and I appreciate I’m possibly opening abit of a messy can)
I'm questioning using R13 as a shunt in an equal voltage divider - and the use of some 47K series input resistance - and appropriate shrinking of C12 to some 20 pico for a similar filter product.
I realise a bulk film 20k pair as a voltage divider up wind of the original circuit would suffice being the same as a passive stepped volume (and one could still question the filter change).
BUT - theoretically -
One - at 47k is series resistance noise a big question? , the bulk film being best (I actually thought the MK132 was bulk) - if no is tantalum or thick film caddock? (I’m not good with analogue noise)
Two - the filter – has a 12 fold or so smaller cap differing parasitics/or considerations? Even if I use the same package / make. ?? esotericism aside - is this an issue?
It’s the first time I’ve really had to pay attention to the moving filter of a passive set up – I use a 24 bit digital set up - and have no fear of digital attenuation for the first 40dB of a 16 bit source, but I’m matching amps here ……
Apologies for long post about stuff that too little knowledge of is dangerous. I’m not worried about getting de-facto answers here lads ‘n lasses - I can make my own blunders – but I’d like your musing on such tomfoolery…..
Will taste, and do not want to start any controversy, but I still prefer the sound given by laminated transformers, as long as they are constructive of high quality.
At least in my case, and I repeat will taste or feelings, I find it more airy sound between instruments.
I have tested my My_Ref with 300VA toroidal transformers and then return to the lamellar at the expense of construction problems that have given me, but honestly I appreciate more the sound.
They will feel, but the music should be enjoyed by as you appreciate more, talk a little audiophile but realistic.
Good day to all
Thanks Davym,
What transformers did you end up sourcing? Seem to be quite a few people using R-core.
Hi sebbyp. I used 22v 300VA toroidal transformers from airlink but they do hum a little bit. I only notice it when it's really quiet in the house and no music playing, usually at night. I intend to change them at some point for potted versions or R-core but I have other priority's at present and the amps sound brilliant as they are.
