I find the two layer layout too difficult to follow/read.
If you could post layout with top turned off and another with bottom turned off, I may have time to work my way through it.
FKP are a really good choice 🙂
Yup,
Many yrs. back when I deal with 100KV pulses discharge in to 4 spark plugs I have to order for manufacture a special type of caps for that purpose. I then learn the lesson. Some 10 yrs back I got an idea what if I scale down that and use in my old fash. direct MC phono-RIAA preamp to use the same trick but scalled downt to the ultra low voltage caps (100V). I then do a lot of the trial and error tests and once I figured out what is most important in this particular situation I end up with special selection procedure caps. and use two of each equal value - selected & correctly marked but used as a one requ. value and soldered in opposite inductance value direction. All was done with a lot of listening and measurements with a real music high Vin (5V) snare drum impulse superimposed with 0.25V 20KHz square into it true passive inv. RIAA box (made on the same principles) and with a lot of comparison in time + freque. domain and again with lots of listening tests. The end result was surprised me and it stays the same till todays. No other single cap. be it expensive to the sky cannot convince me to exchange it for my chosen tandem caps ''I select'', they were KPs. 🙂
A.
Joined 2009
Hi Andreas, I didn't quite understand what you meant by this ?
Joined 2009
Attached...
I'm quite happy to see better parts recommendations - so the WIMA is good with me (if they fit).
Joined 2009
I noticed the resistor values for the feedback network were wrong, they were P3a values which has an LTP whereas this amplifier with current feedback should be low impedance. I've updated the schematic and BOM.
Christian, you might consider that even the low power version with a feedback resistor of 1.2k would be better if it had 1.5k for higher gain. And I suggest you seek out a better quality feedback resistor than I just put into the BOM. It needs only be 1W.
Joined 2009
I'm ready to arrange for a batch of pcb's to get shipped to Ranchu32 and I will likely order a batch for myself (10 boards in a batch if I remember).
Any desire for further error checking - Andrew ?
who wrote that for Wima?
They have the less than and greater than back to front !
Hi Andrew... surprising and attentive as usual.... what do you mean ?
Yup,
A.
Also have been experimenting with that technology and am quite pleased with the results (I mean using two half capacitance kp caps together in "opposite inductance value direction").
It seems these "builds" are able to mimic some "supercap" characteristics at a 1/10 price 🙂
Joined 2009
Hi Bigun
I followed this thread closely and most of the discussions is beyond me !!
I am interested because everytime i listen to the P3a from Rod, it bring a smile to me.
Have you any plan to run a through hole version of the board in future?
Through hole parts are easier to obtain in my area.
cheers
kp93300
cheers
kp93300
Joined 2009
Hi kp93300,
I would consider it, but it shouldn't be a problem getting what you need for the version we are making so far in this thread - you can get just about anything by mail-order.
Where in Malaysia are you ? - I have family in Seremban and KL. Wonderful country.
Hi Bigun
I am from the land of the Hornbills--Borneo island.
If you are holidaying In malaysia now,you should try the king of the fruit ---durian . The mangosteen is another must try fruit .
The experience will be as memorable as the P3 A amp !!!!
cheers
kp93300
cheers
kp93300
Hi, Gareth, R.Cruz,
Maybe a little off topic but I did some quick measurements in my job lab and here are the very quick results. If You just try to each image save as - You can read the short info of each image meaning. As You can see from images with a little trial measurements it is possible to select really very good ''TANDEM CAPs'' values needed with almost eliminating or at list halving the most disturbing parasitic effects which do the most unexplainable effects to the circuits when they're used, thus designers and diyers to blame theirs circuits of a strange oscillations, phase shifts-bumps etc...
The graphs are captured with my phone and the images are with limited resolution but they're also all SELF EXPLAINABLE and were measured with fast sweeps from 20Hz to 10 MHz just to quick get a basic info of the DUT, it is also possible to get 10x higher resolution with higher bandwidths but it consumes a lot of time and is intend only for serious job analyses.
Almost all the same parasitic are present also in resistors, coils, PCB Traces, active semis BJTs Fets measured in live circuits from pin to pin incl. PCB traces within + - 10V, etc....
When observing this way a whole new picture of a particular Element, circuit, is arising and explain a lot of new why and how... to proceed.
With my best regards,
09_CAP_L_SERIALL_AC_TEST-4_2x50nF-MKP'2-(250V)--(DUAL--AC--INDUCTANCE-CANCELING-CONFIG)'.png425.4 KB · Views: 151
08_CAP_L_SERIALL_AC_TEST-3_2x50nF-MKP'2-(250V)--(DUAL--AC--INDUCTANCE-CANCELING-CONFIG)'.png419.6 KB · Views: 155
07_CAP_L_SERIALL_AC_TEST-2_2x50nF-MKP'2-(250V)--(DUAL--AC--INDUCTANCE-CANCELING-CONFIG)'.png435.9 KB · Views: 163
06_CAP_L_SERIALL_AC_TEST-1_CAP-1x100nF-MKP'2-(250V)''(SINGLE_CAP)''.png444 KB · Views: 160
04_CAP_L_PARALELL_AC_TEST-2x50nF-MKP'2-(250V)--(DUAL--AC--INDUCTANCE-CANCELING-CONFIG)'.png441.4 KB · Views: 793
03_CAP_L_PARALELL_AC_TEST_1x100nF-MKP'2-(250V)--''(SINGLE_CAP)''.png465.6 KB · Views: 831
01_GOOD-MATCHED-2_2x50nF-MKP'2-(250V)--(DUAL--AC--INDUCTANCE-CANCELING-CONFIG)'.png423.3 KB · Views: 913
Continue ....
16_CAP_R_PARALELL_AC_TEST-1x100nF-MKP'2-(250V)---(SINGLE-CAP).png494.1 KB · Views: 136
18_CAP_Q_AC_TEST-1x100nF-MKP'2-(250V)--(SINGLE_CAP)''.png474.7 KB · Views: 145
19_CAP_Q_AC_TEST-2x50nF-MKP'2-(250V)--(DUAL--AC--INDUCTANCE-CANCELING-CONFIG)''.png481.1 KB · Views: 139
15_CAP_R_PARALELL_AC_TEST-2_2x50nF-MKP'2-(250V)--(DUAL--AC--INDUCTANCE-CANCELING-CONFIG)'.png480 KB · Views: 135
14_CAP_R_PARALELL_AC_TEST-1-2x50nF-MKP'2-(250V)--(DUAL--AC--INDUCTANCE-CANCELING-CONFIG)'.png472.5 KB · Views: 126
12_CAP_L_SERIALL_AC_TEST-7_2x50nF-MKP'2-(250V)--(DUAL--AC--INDUCTANCE-CANCELING-CONFIG)'.png460 KB · Views: 125
11_CAP_L_SERIALL_AC_TEST-6_2x50nF-MKP'2-(250V)--(DUAL--AC--INDUCTANCE-CANCELING-CONFIG)'.png442.3 KB · Views: 127
10_CAP_L_SERIALL_AC_TEST-5_2x50nF-MKP'2-(250V)--(DUAL--AC--INDUCTANCE-CANCELING-CONFIG)'.png446.2 KB · Views: 145
Continue .....
CAP_C_SERIAL_AC_TEST-2x50nF-MKP'2-(250V)--(DUAL--AC--INDUCTANCE-CANCELING-CONFIG)'.png480.7 KB · Views: 163
CAP_C_SERIAL_AC_TEST-1x100nF-MKP'2-(250V)--''(SINGLE_CAP)''.png469.6 KB · Views: 170
Ricardo,
From my own experience I can tell You that this bar can be rise even
from 1/10 price to 1/100 price and even much higher .....
BTW if just mouse is pointed over each image
there is arising the explanation of it's meaning very useful...
A.
Joined 2009
Thanks Andreas. I'm not sure I have understood all the data presented - you have a nice piece of equipment there, I'd love to get my final pcb checked out on that thing for parasitics. Anyhow, It looks like you have shown a fair bit of parasitic inductance which gets shunted by the capacitance at higher frequenices. Your data is also a good reminder that capacitors have a resonant behaviour up at high frequencies, in this case several MHz. When looking for caps for compensation these 'features' are important and they become most important when the open loop unity gain frequency gets up past 1MHz and the stability of the circuit becomes dominated by parasitics that are often neglected in simulations. If using the 1206 npo ceramic caps, the parasitics are reduced and the resonant frequency is pushed up a lot higher.
PCB - I would still appreciate extra error checking if anybody has the time. The circuit 'works' in spice but the schematic is then manually transcribed into Eagle. If there are errors in the posted Eagle schematic then we have a problem - I have checked it over but an extra pair of eyes is welcome here. The Eagle layout software will ensure that the pcb layout matches with the schematic (it has built in Electrical Rule Check) and it will also flag a lot of common errors (it has built in Design Rule Check) but it's not perfect and it doesn't know about parasitics, or about separation between traces for high voltages or about trace width for high currents. So I'd be grateful for any input on these potential errors in the design.
To get boards in time for the holiday break I believe I need to order them very soon so I'm proposing a deadline of end of the month - meaning I should place my order this Sunday.
Hello Gareth,
Yes, You are point out one very acute point in an El. circ. design,
which is quite heavily persistent and covertly hidden and messing the things quite a bit.
Pls.look at Yours HM.
A
A
Joined 2009
cheers
kp93300
I've been to visit many times the Peninsular and never had the chance yet to visit the East. I am a big fan of durian and enjoyed eating it quite a bit on my last visit. I also like mangosteen. I also like cold Milo, Rendang.... actually my last visit coincided with Ramadan and I was able to enjoy some amazing food from Break Fast at roadside vendors.
What does this mean ?
- TGM8 - my best amplifier, incredible bass, clear highs, no fatigue (inspired by Rod Elliot P3a)
