how to know that this transistor fake or original?? theres any sign or difference??? so that if i buy again i have idea..=) thanksif you bought these recently (say in the last 5years) then they are probably fakes.
If you buy those transistors from Ebay, you will almost certainly have fakes. If you buy from companies who are genuine agents of the manufacturers stated on the parts, they will have a high chance of being genuine. I asked you what colour the 2SA 1302 was. Well?
Thank you, nazirdigi. SMPS KA3525+IRFP460. core ETD44, 60kHz, 800 wats. Unfortunately, the layout deleted.
i found out th problem of my b500.actually its not the amp is the problem.its the trnsformer.the 100 watts bulb in series of the xformer keeps on glowing even withouth load.i have to make a xformer for this amp.
hi apex, if I want to use a diode.This transistor used as thermal sensor (diode) in this protect circuit, base and colector conect together as anode and emiter is catode.
bd241 > tip31.
what diode series?
regards
Thank, apexaudio. Testing protection NE555, sstart, very good! PCB in Sprint-Layout.
what diode series?
regards
Use only TO220 transistor for good thermal connection.
Nice work, NE555 is my favorite protection.
thank you, apexaudio.
I picked different transistors.The best was the KT829 - Russian transistor cut-off temperature of 80 degrees.Use only TO220 transistor
AX14 protect
regards
greating sir, how max rail suply for ax14 protect... can i add for b500tef ?Nice work, NE555 is my favorite protection.
regards
- 500W PA amplifier with Limiter
