500W PA amplifier with Limiter
Protect
This is recomended protect.
apex
how to power up b500
first time powering up
except the slow turn on
do i need to place 100r to fuse?
Do not powering up without heatsink, drivers transistor work in class A.
Don't forget wire jumper on coper side pcb.
Don't forget to connect input GND.
Use 150R 20W on primar ac transformer.
U can use 100R instead fuses, I don't, but I made 1600 amplifiers still now.
Check DC offset before connect speakers, use 100uF bipolar if U want test amplifier without protect.
Good luck!
