Nice work, is sound good?
loud and clear😉
regards sandman
finally i finish my diy amp b500 thanks apex
EF version sounds very good and less heat.... Good work!
wiljj very nice looking
Hi khalsa,
It's sandman15th work not mine and looks really good...😉
Regards,
40-0-40 ac 😱 I dont know how much amps.. i brought only second hand from a local electronic shop here in riyadh.(150 sr). its hard to find trafo here in my location... 😡 by the way off topic happy halloween guys..=)But torroid look small for stereo...whats the power rating of that torroid?
regards Sandman
Having trouble here my b500 not sound clear having distorted in highs sory for my bad english
Sent from my MyPhone A919 Duo using Tapatalk
I see it my mje 15033/15032 having no insulator and then my dc offset is -6mv but having distorted soind please somebody there who can help? Sir apex help me,Sir miles what is possible trouble with my b500 my dc offset is 50v
how much your rail voltage??? how much voltage u get in r24 and 25?(it must be 14-15volts) dnt forget tha jumper and the groundings.. double check also you mj'sI see it my mje 15033/15032 having no insulator and then my dc offset is -6mv but having distorted soind please somebody there who can help? Sir apex help me,
regards: sandman
regards: sandman
Yes -+15v on r25,24 sir and the rail is -+50v i didnt forget the jumper thanks for your reply
I will 2xcheck my b500
And post the outcome 🙂 my bad english,
Hi sir can u help me with my b500 my dc offset is 20mv and .5v in 2sc5200 base,emittee but why 2sa1943 having .12 v only is this normal b'cos when i input sound and plug a speaker my amp sound distorted in highs. What is possible my problem here im already stock up
regards: sandman
regards: sandman
the mje 340 (Q5) must be in the same heatshink with final transistor, better if the mje 15032-33 on the same heatshink also
I wanted to ask Mr.Mile or the other could answer, even fellow DIYer may experience the same thing with this problem, .. why the H900 standard when playing a kick drum, bass disappears (PA as SUB) ... the 4R or 8R load. but if for a bass guitar no problem, voltage regulator 45ac-90ac-ct ... 4kva. and I do not use nsl 32. where is that must be repaired or is there any other damage?
sorry my bad english
thanks and regards
thanks and regards
Hi.. this is my on going B500 TEF based on Liem Poo pcb.
Hope anyone can check also for any errors. My Power supply is 2x50Vac @20amps toroid. Ne5532 is replaced with NJM2068.
verry nice your project for b500 TEF, please Proceed with a project h900 TEF !!
Hello Liem Poo... I have already parts gathered for H900TEF.... 🙂 I will prepare the board this week... Many thanks for your support.. I will post a pics later...
Best Regards
Done checking componet and voltage measuring found out 100r resistor change value to 1mr and finally my b500 is working fine now thanks to mr.apex and to other here.
Its sound really good 🙂
- 500W PA amplifier with Limiter
