500W PA amplifier with Limiter
NE555 protect use separate 12V suply and can be use with any amp.
no sir... protect what i mean is from ax14p, any change value for 80 to 100vdc ?
thanks apex(willy b.cerna),wiljj78,jaagut,desert storm and the rest of DIY community, heres my b500 TEF, =)
http://imageshack.us/a/img407/507/58pb.jpg
http://imageshack.us/a/img22/9858/k7fm.jpg
http://imageshack.us/a/img443/7776/ptwr.jpg
my speaker
http://imageshack.us/a/img34/5821/3m48.JPG
http://imageshack.us/a/img844/2766/3ig5.jpg
additional question guys =) how can i know if my speaker protect are working???is this correct? i tried to put 15volts ac on protect the relay cut off. and led glows. but why my fan always in high speed,by the way im using 15-0-15 instead of 18-0-18 .thanks and regards...=)
MY B500 TEF, ON GOING
Hi.. this is my on going B500 TEF based on Liem Poo pcb.
Hope anyone can check also for any errors. My Power supply is 2x50Vac @20amps toroid. Ne5532 is replaced with NJM2068.
