Very cool, and very tidy, excellent job
Can you post the part number and supplier for the chokes please.
2.2mH - 1.6mm / 14AWG
D=80mm, L=30mm
XA 50:4
XA 50:4 It works since Dec. 2010.
- Transformer 1500W (seondary: 1x44VAC)
- 48VDC CLC => 8x10mF ->L L->8x10mF
- Stereo =>32x IRFP250N
- Total idle current: 7Amp DC
- Temp at the top: 55°C
- Cooling: Alu plate 2.5mm Complete: 1 square meter
- Top and down plate: 12mm
- Top: Attenuator
- 2. Aleph P1.7 incl power supply
- 3. Pass Xono
- Bottom: Power supply XONO
- On the side: AC Supply with 4 double filters
- Duration of simulation 1 year
- Construction phase: 1 year
They are not purchased, my friend made them.
Looks like I'm going to have to wind my own.
Your power amp is a work of art
About the coils what is the cooper lenght please?
Inductor Designer / Calculator
don't go above 0R22
Tanks Zen
146 Feet but got loads of trubles converting that to meters
evvery time I got past a certain point I have to turn a corner and loose count.
And I am only size 7
Joke
right 50 meters shuld do nicely but calculator came up with 0.36 R
Had 2 on the mule cooper came by the kilo so I got 2 kilos and it was 2.5 mm square.
Not a blody clue of how meny henries and they look crap as right pain to bend and wind nicely.
PS tanks for calculator I sure it be handy.
PSS How do you mannage to find this stuff and remember where it is?
Joke
that's famous Mighty ZM's Futile Attempts Method
now you can go nutz ..... old recipe :
"some data for my chokes (presumably 9mH, certainly 0E2 Rdc) :
EI72 package
height of package ~30mm
entire window filled with 1,25 enameled wire
air gap ~ 0,5 mm "
Yes , it was my intention. I would like to have no normal box.Looks like I'm going to have to wind my own.
Not Really....
Air core
By the way, the advantage of air core as opposed to ferrite core is that they have constant inductance irrespective of load.
Of course in a class A amp that argument is diluted because current is essentially
allways the same....well almost !
- Pictures of your diy Pass amplifier
