A Thread for those interested in PPSL enclosures
larry, you inspired me to do some more maths.
Tricks to reduce the rear corner volume of the plenum are to extend the midrange response, are you planning on running a pair of 21SW152-4 up into the midrange?
I wonder if it's possible to treat the cavity resonance by another means? For example, extend the cavity a bit, then fill it with just enough damping material to tame the resonance? Or is that too much bother for what can be dealt with via active filtering? 🙂
djk,
Was this inquiry for me? If so, no sir; purely aesthetic in nature. If not wise to pursue, I certainly will not do so.
I have no plans to run the IB > ~100Hz; ultimately, I'll utilize quad 21SW152-4 experimenting with LPF to best compliment my mains (Danley SH50/SH69/SH50).
I have no experience with an IB install; I plan to run one pair in IB, and a second pair in 12 cubes sealed. I'll measure and listen for which alignment I prefer. Regardless of install, the drivers shall enjoy a PPSL orientation...
Thanks TB46. The graph you posted seems underwhelming. I am not sure I am reading it right, but LMS ultra 5400 achieving only 90 dbs at 20hz, is that right? BTW< I have Lab Gruppen 14000 powering these.
GM, thats the LMS Ultra 5400 series 2? I believe I have an older version of the lms 5400...
Dunno, it's whatever someone posted awhile back: ~19 Hz Fs, 0.31 Qts, 235.5 L Vas
GM
edit: hmm, they are somewhat different than Ricci's, but don't know which specs are earlier or if his are measured........
