Hi Bardos,
This is the PCB i will use for testing your DAC PSU, I cant say its the best designed PCB but in the lack of time i did my best. All i have to do is to connect it to the DAC. I hopw ill find out the reason for voltage drop phenomenon.
Best regards
Goran
Best regards
Goran
Hello Bardos,
I tested the power supply unloaded, instead of 1K on the base of BC550/560 i use trimer potentiometers of 5K, bicause i have only that value. It works ok, i can setup the voltage -15V, -5V, +5V very precisly. You can solder high turn potentiometers of value of 2K and all will be fine. I use the trafo 17V/60VA. Now i will try to connect it to the DAC.
Goran
Goran
Bardos,
Connected to DAC it works perfectly no voltage dropping. Im impressed with the improvements, it sound very natural now.
Thanks for showing me this power supply.
I just changed the 1K ressistors like i said with 5K trimmer high turn potentiometers.
Hi Bardos,
I can suggest you to buy a trafo 0-17V/30VA, should not be expencive. and your board will work also. If you are interested, i can make you a board and send it to you. Im planing to change all regulators i have with this PS, so i will make severall boards. If you want i will make for you also without any charge.
Goran
Goran
The next will be changeing all LM's and 78XX, 79XX with PS you sent me.
About board, its not a problem at all, you can have not just one. Just ill be able to make them after ill came back to Poland, it means after 2 weeks.
Send me your adress, now or when ill back.
It will be if you can tell me the size of caps you want to use, so i could design your boards.
For 7220 it can be used also but with some changes.
Goran
Goran
Hello Bardos,
Durring night i have designed the PS PCB for SAA7220, the same circuit as for +5V of the led PS. It will have separated trafo and different transitors, in this case i will use J13009 mounted on the small heatsinks. For filtering caps I will use 10.000uF/25V, 2200uF/35Vx2, 220uF/63V Vishay x 2, and Silmics II 100uF/35V. The trafo will be mounted on the PCB also, the voltage on the secundar is 11V.
This morning Im going to solder the components and I hope ill have time to try if it works.
Ill send you photos when it will be done.
Best regards
Goran
Best regards
Goran
Bardos, things get complicated a little, i already have 4 trafo's inside CD player, the best would be to build separated box for the trafo's. I should find or build some nice metal box for that purpose, but for now im just testing so ill stay with the box i have. also i will need to make better transport, the problem with that is that flat cable is too short, im not sure if its a good idea to make it longer and install the transport on the top of the enclosure.
Maybe you have some experience about that, i mean if the longer flat cable could produce some problems?
Goran
Goran
Hi Goran,
You are building fast. For so many chips to power go for separated box.
The longer cable more likely picks up more EMI. With a good shielded cable might work. Need to be tested.
BR
Bardos
BR
Bardos
Hi Bardos,
Im doing it fast because Im in a luck of time, Im leaving Poland in 2 days.
The PS board for SAA7220 is finished,and components are soldered, i just have to see if it works.
Take care
Take care
Hello Bardos,
Sounds PERFECT 🙂
I highly recomend You to build it. I made some small modifications.
Im still testing it, especialy the heathing of the transistors. The heatsinks are necessary here.
Very good sound, I think I wont sleep this night also 🙂
Cant stop to listen .
Sounds PERFECT 🙂
This thread is excellent 🙂
Thanks. I hope You really like it. My intention is to improve the Marantz CD40 with help from members of this forum. At this stage its just testing project as You can see from the photos. The finall product will look much better, with new enclosure and better boards and components.
Hi Goran Nice job on the PSU and the box look very cool. Thanks for the 7220 ps. So the BD139 seems to work right. I will try out as soon as I fixed the Nad 3020.
Hi
I too have a phillips based cd player with separate 7805's dedicated to SAA7220, 7310 and Ram Chips. I have been looking for ways to improve this simple arrangement.
Would you make additional boards and maybe sell them to other members like me ?
Your boards are an excellent solution but would understand if it's not practical do to this
I am also learning quite a bit from this valuable thread and can already implement some changes from your advice so far - keep going !! 🙂
Thanks Bardos, We both know its not so cool 😉, but just wait when ill finish all mods and tests 🙂 I already have plans for new really cool box. Yes the BD139 works great. Its turned on for 24 hours and it works perfect. Really great improvement. Just as I suggest you will need a heatsinks for both transistors. You can also use BD139 instead of J13009, or some really fast transistors. Regards Goran
- Digital Source
- mutting transistors on the output of Marantz cd40 help!!!
