Studio Reference Amplifier
Hi Mr. Mile Sir,
With +/-110V rail voltage, Can I bridge the SR200 circuit to have 1500W/8R? If so, what are the parts I may need to change?
Thanks,
Blueice23
This is circuit for stereo/bridge mode.
Correct board?
Hello Mr. Mile Sir,
I just want to know if this PCB layout is correct? (please see the attached files)
I will use this PCB for my SR200 ref amp.
Blueice23
  • 02 SR200 V2 PCB.pdf
:Amp will be like 'Ultimate Fidelity' with DC servo, and cascode instead super baxandal pair in VAS... I don't want made another 'Goldmund' clone:)
I've seen several designs that use baxandall pair in VAS, much before Goldmund's, like Luxman, etc. I think you should keep that, because it does work very well and should have a good part in the amp's sound.
