Alex...
You already corrected the schematic.
Didn't I understand the error of R3 and C3?
So that it serves CS+ and CS- and SD pins?
Did you already finish the protection?
Lindomar.
Lindomar.
hi Lindomar,
in- of TL072B must be connected to output pin
in+ of TL072B must be connected to R3 and C3
protection module is finished.
CS=current sense
a voltage across these 0.05 ohm resistor appears when a current flows...with a ratio of 50mV/A so easy to compare this voltage to a reference and shut the ir2113 down when it becomes larger than the reference (overload situation).
have a look at IR2113 datasheet for Shutdown (SD) operation.
CS=current sense
Alex...
Would the protection be this?
Your protection seems to be simpler.
Lindomar.
Lindomar.
You only need negative side sensing. When current flow into positive side, you get a current image trought the recovery diode. The use of a 555 timer into protection is to avoid harsh sound of fast attack and release of the current protection when trigered. At least 0.5 sec of cutoff is needed to advise user that their is a protection activated. The way of crest is better than the way of yorkville. If you whant transparent current limit, just sens the current at the speaker output and feed it back the the input throught 2 threshold back to back zener. This will limit gain of the amplifier under hight current by the add of out of phase current image voltage. Or feed current sense to a limiter (CA3080) to do it more elegantly!
Fredos
www.d-amp.com
Fredos
www.d-amp.com
Hi lindomar,
Yeah, my first idea was to use the protection circuitry taken from Crest LT series but as you can see Current sensing is only on the low side (maybe the bootstrap capacitor voltage drops when overcurrent situation occurs on the high side...)
Finally I decided tu use a pnp transistor across a shunt resistor on the high side and a npn transistor on the low side to trigger a 555 used as monostable (5s delay) (idea from YORKVILLE EF500P).
threshold is set at 30Apeak on both side...
Hi Fredos,
"You only need negative side sensing. When current flow into positive side, you get a current image trought the recovery diode. The use of a 555 timer into protection is to avoid harsh sound of fast attack and release of the current protection when trigered. At least 0.5 sec of cutoff is needed to advise user that their is a protection activated. The way of crest is better than the way of yorkville."
you mean current image trought the recovery diode of the mosfet that's off ?
so one side protection is needed !
Yeah, you will get out of phase image of the positive side on the negative side, what curently people call buss pumping...
Fredos
Fredos
Alex this lacking the protection, place the protection that you created.
This simpler one and has a yellow led.
Alex you asked for to also send PCB. 😉
Alex congratulations for the help to all.
Here this Alex project already with the correction.
alex-damp.rar
Lindomar
alex-damp.rar
Lindomar
Hi to everybody,
be careful i noticed a(nother) mistake on my schematics !!
U1 pin 4 is -10V and pin 8 is +10V (inversion in schematics)
enjoy ;-)
enjoy ;-)
alexclaire said:Hi to everybody,
enjoy ;-)
Corrected........
Alex-damp Corrected-01. hehehe
Alex sends PCB?
Lindomar.
Hi Alexclaire,
Are you planning to share the shema of the protection circuits?
If yes, then please send me a copy:
sixtek@gmail.com
On the margin thanks for sharing the amplifiers schematic! Nice work!
I'm planning to build a 400W version with +/-70v rails.
Best regards
sixtek@gmail.com
Best regards
Hi everybody,
I you wanna thank someone, you should thank Fredos (D-AMP) who shared his D1200 model schematics with the community and has to deal with some critics at the time (he was told to make advertisement for his products...) In my opinion Diyers don't buy 1200 dollars power amps ;-)
It was just a way for him to share his experience...
So you know what you have to do !
For the protection circuitry and pcb I let you choose the right way !
Alex...
In what you do program draw PCB?
I don't know how to draw PCB very well.
Thank you very much Freedos for the help to all of the forum.
Lindomar
Lindomar
- Class D
- IR2113 blowing ! help needed...
