Kicker CX600.1
I have a CX600.1 from 2016, and this tiny little amplifier is kicking my butt...
It originally had a short between the output mosfet and one of the rails. I forget which, its been a few years. Then suddenly this short went away.
Regardless, I replaced the IRS20957 and the two output transistors just in case it was that. The short never came back, but the amplifier will not start. It looks like its very similar to the UcD DIY amp designs and it is self-oscillating. Tangentially, this is why i never liked self-oscillating designs as they are nearly impossible to troubleshoot without it being able to kickstart
So as it stands currently, theres about 1.1V DC on the output terminals and the amplifier wont start. the Protection LED is stuck on as well. I am not sure where to go from here without a schematic.
the +/-15VDC is present on the LM311, and the 12V is present on the IRS20957. none of the surrounding diodes are shorted
Discrete Class-A headphone buffer for BA3-FE, no feedback
Would it be possible to omit the OPA and connect the power amp directly to the output of the BA-3 line stage?
I connected my HD-800 to the BA-3 line stage.
I know this isn't ideal, but the HD-800's 300 ohm impedance will do.
And the sound is absolutely phenomenal.
I've heard the HD-800 for a long time and on many amps, but this beats them all by far.
So I could imagine that BA-3 and Whammy power amp might be the final solution for me...
(BA-3 Gain 8x 100mA idle current)
SPICE How to collect a good library of models?
In SPICE you can only use the models you have at hand.
And you can add SPICE Models by and by.
But to find those models you need for simulation is NOT easy.
Personally I have searched net and also diyaudio.com to find models.
How do you do to get new models?
Any good sources?
Can you tell how you have found them.
Mark Levinson No. 436 Allignment (Powersupply + Idle Current)
Hello
I'm currently working on two No. 436 with some issues.
Both work with 0V DC on the output... but i have DC on the XLR (both pins) port.
-0.9V on Amp #1 and -0.15V Amp #2
When hooking up a low impedance source #1 triggers DC Protection. When starting up with the source attached the servo amp immediatelly compensates that and the Amp works (no DC on the Outputs, full Outputpower).
#2 compensates the the 0.15V when attaching something without triggering the DC-protection
Checked the servo amplifier ... works ... when i trimm R1 i can see pin 6 of the Op amp moving from 0 to + 14 and -14V without getting DC on the output.
Moving R1 to extreme i see DC on the output as the servo OP Amp can no longer compensate. Works as expected.
I found a bad 2N5551 (hfe <10) in #1 and hope that replacing all four 2N5551 fixes the -0.9V problem.
In #2 all four 2N5551 seem O.K. (hfe at 150), but i will replace them anyways ... they were running way to hot for a long time ..... brown discoloration around them on the circuitboards
Any ideas what is causing the DC at the input ?
I've got the schematics, but there are no voltages listed at all ... :-(
What voltage drop should i see over CE of the 2N5551 ? in both Amps that voltage ist close to 100V ... wondering if something is wrong with the currentsources (Q20,Q23,Q24 and Q10,Q14,Q16,Q17). I expected a lower voltage on the 2N5551 and a larger voltage drop over the current sources.
The other thing that bothers me is that the documentation i have doesn't include a allignment procedure.
To what voltage must the two regulators be set. I currently have +/-104V on the LM317 / 337 outputs. Is that value correct for the 436 ?
Again, the manual doesn't tell any voltages (exept the -/-16V for the OP Amps 🙂).
Hope some one can help
Best regards
Peter
Bigger midranges/speakers have better imaging?
Playing with driver sizes i discovered that bigger drivers does not really have better imaging but because they are bigger can give you a more strong phantom imaging.
But can have on that factor.
These are just examples, is not about output.
A small 2" midrange will have Great imaging, close to the listener and to each other. Are good for desk speakers but for a living room you need bigger drivers because if u use small 2" in your living room, being so far from each other and from the listener, the imaging will be defused and not focused.
Reactions: lasercut
Hello from Denmark, Roskilde
Hey diyAudio community!
I'm Benjamin originally from France but I have been living in Denmark for many years. I am an acoustical engineer from profession but do a lot of DIY in my hobby times. The DIY connected for this forum are soundscaping (hobby of recording stuff instead of taking pictures, including recording of migratory birds on top of my house) and repair of older electronics!
Thanks for having me here.
Cheers
Ben
Hard to find pot
I've found a bad pot (no puns intended) in an amp I'm repairing for someone.
See attached files.
Note the extra soldered PCB bracket for support.
Also note I must have the switch.
80k to 100k. Don't really care about taper.
Can anyone help find this thing?
Thanks Al
My MOSFET amplifier designed for music
Hi, Well after having seen all the amazing projects and designs you guys have come up with I thought I would share my design on these pages. First and foremost this was designed for music reproduction in a domestic setting and without wanting to "hijack" another current thread, YES amplifiers do sound different, that is why I spent so much time in the development of this one. This amp is without doubt "musical" in all the best sense of that term, it's ability to recreate a believable soundstage is absolutely compelling. If anyone is interested in what it looks like and further details there are some pictures in the "Post your solid state pics here" forum. (About post 283) The thinking behind this project draws on the work of the late John Linsley Hood whose designs and thinking I much admired.
26th August 2024. LTspice simulation files added. These include Renesas and Exicon Double Die models and should click and run on the current version of LTspice.
Also included is squarewave testing. Alter the .par line to suit. tr = risetime, f = frequency and vp = amplitude. The sim should scale automatically to accommodate these settings. The squarewave starts at 0.00 volts and so the output should be symmetrically centred around 0v.
The sim called 'Startup Behaviour' shows the operation of the servo and why the speaker delay circuit is essential. After 3 seconds a 1kHz signal is applied and output. The delay should be around 5 or more seconds to get a totally silent switch on.
This index of the thread should help you find the relevant important notes and general information.
1. The circuit diagram in this, post #1 is correct. The only omission is a 10 ohm 2 watt carbon/metal film across the output coil.
2. The TL071 opamp must not be substituted. This type works correctly on the single negative 12 volt rail. Other device types may not do so.
3. A speaker relay incorporating a switch on delay is essential due to the action of the servo and the single ended input stage. This can be extremely simple consisting of a FET, a C-R network and relay. Post #273 in another thread shows the idea of solid state relays developed into a working example. Credit for the idea of the SS relay goes to those mentioned in that thread.
My MOSFET amplifier designed for music. - Page 14 - diyAudio
4. alex mm' brilliant PCB designs. Post #300
My MOSFET amplifier designed for music. - Page 15 - diyAudio
5. The FET pinouts, post #113
My MOSFET amplifier designed for music. - Page 6 - diyAudio
6. Squarewave testing, posts #157 to 161
My MOSFET amplifier designed for music. - Page 8 - diyAudio
7. Heatsinks, post #164
My MOSFET amplifier designed for music. - Page 9 - diyAudio
8. A glowing endorsement, post #186 and this,
http://www.diyaudio.com/forums/soli...-amplifier-designed-music-10.html#post1567427
9. Spicing it up... LTspice files, post #312
http://www.diyaudio.com/forums/soli...-amplifier-designed-music-16.html#post3171018
10. And finally some of my benchmarks and my thoughts on how it sounds. The adventures of getting the design to where it stands today, post #107
http://www.diyaudio.com/forums/soli...t-amplifier-designed-music-6.html#post1539997
11. Further development of the design using parallel output devices to improve current delivery into adverse or low impedance loads. Circuit details and PCB layouts are in post #904
12. Gerber Files and BOM for an SMD version of this amp. Design and development of the boards by @geoffw1 are in post #1678
Gerber Files and BOM for SMD version
Need slimmer tower, TL, MLTL, folder horn, etc...2-way, active or passive
I have looked, a lot, might of missed something just right already.
Full time RV.
Looking to DIY towers, widest would be 8" but prefer slimmer, height no issue, depth not either for two reasons.
1) No subs, only place I have for them would be behind the towers, if subs required then I could build smaller towers but would like to not have a need for subs.
2) Front "horn" opening, not rear, a must.
Passive, willing to spend funds on foil inductors, great caps and resistors, wire, etc....
Active, preferred but not absolute.
2-way, less complex and added cost, spend more on quality drivers and xover parts, amps, etc...
Budget, $1k for drivers and xover parts if active, $1500 or so if bi amped including amps...
Proven plans only unless I can get a bit of help on crossovers, which I have built but I want really good ones.
Recommendations and questions most welcome🙂
Thanks,
Rick
ELX112 horn - recommend a compression driver?
I'm working on a 10" inch monitor/light PA top. Got a pair of ELX-112 waveguides (clones) from AliExpress. I want to pair them with B&C 10CL51.
I'd like opinions on their subjective sound and can anyone recommend a CD for them? Only documentation I have found is this, with Celestion CDX1-1731 and the polars look pretty nice.
https://www.mtg-designs.com/tips-tricks-tests/waveguide-shootout/1in-bolt-horns/ev-elx112-wg
very "textbook" single ended Class A amplifier i designed
i want to use up my irfp140(i used the irfp240 becuse i couldnt find the model for the 140) so i designed this amplifier, the weirdest thing here is the second supply for the voltage gain stage, its here to compensate the common emitter gain stage losses and make the voltage swing a little bit bigger without adding more parts, also compared to my last se amplifier i used mosfets which are supprisingly not that awfull.
Reactions: cumbb
ThermalTrak Transistors have been discontinued
Newark provider notified me of this information and the manufacturer Onsemi, I confirm that all models have been discontinued. Although more questions Onsemi did not want to give more information.
Besides the option of Sanken: Does anyone know what other option is there with this technology?
Or does anyone know if this product was purchased by another brand?
Hammond 273BX is smoking after putting it in the two diode center tap arrangement
So I am following up from a recent stereo tube amp design that was not working and right now I am working on the power supply. Please look at the picture below as well as the schematic. When I add power to the transformer it hums louder increasingly and beings smoking which is a sign something is not connected right. Please advise, thanks!
Arcam Delta DAC buzzing on left channel
Hi, wondering if anyone can help. I replaced the thermal pads on my dac and managed to short the output I think to ground. The back of 2sa958 touched the heat sink (I think). everything works but the left channel has a buzz that seems to go away once warm. I have already checked all the capacitors!
I have attached the manual and left channel section. The buzz seems to disappear when I place my finger on particular sections of the left channel. For example TEST point 16 at the bottom next to the blue capacitor. I tried to measure everything and it seems fine, no idea whats going on. I have a good scope I don't know how to use.
Any advice appreciated
  • arcam_black-box-1,2_dac_sm.pdf
KEF X300A Bluetooth Mod help?
I bought a QCC3031 "HY1002" bluetooth module (https://www.aliexpress.us/item/3256805281764019.html?gatewayAdapt=glo2usa4itemAdapt) that I am trying to use in a Kef X300A powered speaker.
The X300A has an analog "line in" input that is routed to a WM8782A ADC setup in slave mode. My plan was to replace the ADC with Bluetooth module. I got it to produce garbled sound via I2s. My issue seems to be clock timings for i2s. I need to emulate the configuration currently setup for the WM8782A. I loaded the Qualcomm ADK configuration tool for this purpose. I got the module up on the config tool via USB. The WM8782A is configured for the following.
WM8782A Config
-Slave mode, 128,192,256,384,512,768fs
-24 bit word length
-96khz fast sample rate
-audio mode I2s
When the WM8782A was in circuit I got MCLK = 24MHZ, BCLK=6MHZ and LRCLK=96KHZ.
My question is, can I get the QCC3031 to emulate the WM8782A using the Qualcomm ADK configuration tool? Unfortunately, I am out of my league when it comes to i2S programming. I see that an .xml file for configuration can be loaded. Does anyone have a configuration file that might work? I have schematics and info for both the X300A and the QCC3031 module.
Any help would be appreciated.
Gary
Best design for mostly TV/movies?: XT25SC90 NE123-8 NE180-8 -- Wavecor TW300WA14 NE180-8 -- NE123-8 26W/8861T --
Leaning towards first design, but it's pretty complex.
The Wavecor TW030WA14 NE180-8 (2.5-way) seems easiest, but I read the NE123 is more or less magical.
Tymphany NE123-8 and Scan-Speak Revelator 26W/8861T00 Bass-mid woofer would be easiest
I also have some TG9, TC9 fullrange drivers.
Also have ScanSpeak neo tweeter
Tymphany XT25SC90 NE123-8 NE180-8 NE180-8 -- I think will have to be MTWW --
Wavecor TW030WA14 NE180-8 NE180-8 -- would be easier, but I'm not sure voices would be as good.
https://hificompass.com/en/speakers/measurements/vifa/vifa-ne123w-08
https://www.dibirama.it/home-page/tweeter/340-wavecor-tw030wa14-tweeter-1-1-4-8-ohm-70-wmax.html
Spacing when installing compression horns into an outside speaker enclosure
Hi all,
Is there any kind of specific guidelines or recommendations as to to deploying and spacing horn speakers in an outside environment. I have been looking for a high performance IP rated speaker and came across these Kicker 8" Horn-loaded compression speakers. https://www.kicker.com/48KMXL8
Ive seen they sell enclosures which have them mounted directly side by side, but I am wondering if this is based on them both being used as a single channel, not as a stereo pair. Can horn speakers be placed close together if they are acting as a single channel or is there still scope for audio issues? Ideally I would like to mount a couple of these speakers outside to with two pairs functioning as a left and right channel.
Any advice appreciated.
SMPS issue on a MarkBass Little Mark 250
Hi everybody,
I'm having a weird issue trying to put
back to life a dead power amp used in a
MarkBass Little Mark 250 bass amplifier.
I attached the actual part of schematic that needs
to be checked.
The first time I looked at the main PCB (power amp + SMPS)
I checked for any shorted power mosfets
in the SMPS high voltage side then
in the linear push-pull power amp section.
No damaged mosfets ! and no surrounding parts either.
Then I noticed that the SMPS mosfets driver U5 (8 pins DIP IC)
had been removed by the precedent tech..
Checking the schematic I found it was
a IR21531D SELF-OSCILLATING HALF-BRIDGE DRIVER.
So I ordered some and made some tests.
First I assembled on a breadboard a test rig
that supplied the IR21531D from an external DC supply across
a 10k resistor to the IC pin 1.
Slowly rising the ext supply voltage showed
that the IC started working normally at around 21VDC.
At that voltage the remaining voltage (dropped by the 10k resistor)
to the IC supply pin1 was 10vdc which means
the IC needs a minimum of 1,1mA to start its normal operating pulses.
Rising up the ext supply from zero to 21vdc:
The IC vcc pin follows the rising voltage from the 10k resistor
then stop rising at around 9vdc. Then it starts to oscillate
(sawtooth) from 8.5vdc to 9vdc and behaves this way
until (keeping rising) the ext 10k resistor current reaches around 1,1mA.
Then the IC starts to behave correctly.
The 2 output (pins 5 & 7) were showing complementary pulses
with normal timings.
-> This is the normal IR21531D behaviour.
Instead of an ext 21vdc and a 10k resistor feeding
the IC vdd pin, the MarkBass SMPS uses 330vdc and a 270k resistor (R78)
which gives around 1,2mA to start the IC.
My problem with the MarkBass SMPS is that the installed IR21531D
would keep oscillating between 8.5 and 9vdc even after
reaching the minimum necessary 1,1mA supply current.
It should normally start outputing its 2 complementary pulses
then its transformer TR1 would take over and feed the IC through
C67,D39,D34,C69,R80,D21,C70,D40,C52 a little less that 12vdc
from the D21 zener.
I suspected C52 to be leaking but no, it is ok.
Measuring between pin 1 and pin 4 of the IC on both
the test circuit and the MarkBass circuit show the same high
impedance value of around 7K.
So no parts that would sucks any current on the IC's Vcc trail.
And these tests were done with and without loads on the +/-55vdc rails.
I'm stuck there..
New DISPRE preamp, successor to previous popular version
Hi all,
Couple of years ago I published simple discrete preamp, Dispre. The preamp was well accepted and became quite popular. There was a thread on DIY audio:
http://www.diyaudio.com/forums/showthread.php?threadid=64843&highlight=
and an article in Klang und Ton by Holger Barske:
http://www.symasym.holgerbarske.com/doku.php?id=dispre
http://www.symasym.holgerbarske.com/doku.php?id=gemeinsames
also, my original page: http://web.telecom.cz/macura/dispre_en.html
I have decided to come with new, complementary-symmetrical version of Dispre. The new topology results in vanishingly low distortion (less than 0.001%) and uses very small amount of feedback (10dB), just to help to stabilize DC output. Open loop gain is 1MHz! A servo is included, so no output cap any more. Here is the concept:
Japanese market Threshold Model 4000 use in the US
Perhaps I overpaid, but I just bought a Threshold Model 4000 in what I consider very good condition cosmetically (and the seller claims it was recently serviced) from a Japanese seller, and it's labelled 100V 50/60Hz, with an IEC connector on the back so it will accept a standard power cord. With my limited electrical knowledge, it seems to me the transformer would be different for a Japan model amp, which, in retrospect, makes the purchase not nearly the good idea it seemed late last night after a few drinks. I don't suppose Nelson Pass still participates on this forum? Regardless of what it will take to make it function here, I'm very excited to get one of the amps I've been drooling over for 40 years. Move over Perreaux PMF2150B (which I've loved having all these years). Not terribly relevant, but driving Mirage M1s, a pretty easy speaker to drive (and still sound REALLY GOOD to me). Counterpoint SA1000 preamp recently retubed.
Thanks.
Joe
5k SE Transformer Tests: Monolith, Edcor, Antek, and Tamradio
Hi Folks,
I had a few 5k SE OPTs and a TSE II set up on the bench, so I ran some comparisons with the Analog Discovery 2 and Audio Analyzer Suite. The test setup wasn't fair to all, running around 385V B+ and biasing each at 91 ma where I was getting low distortion on the amp, but not necessarily being nice to the tiny Tamradio. Only one channel driven. 8 ohms only.
The transformers were the Monolith S-11 (new), Antek MS-30W50 (new), Edcor GXSE 15-8-5k (used), and the Sony/Tamradio 5k with 8 and 600 ohm taps from the Sony TC-500a reel to reels (and others) (very used).
I'll be curious to hear what folks think. My relatively uninformed ideas are that that Monolith is a different beast with its extreme HF response. The Antek is quite a thing at the price. Interesting that the square wave isn't quite symmetrical. Lots of power too, making me wonder if it isn't quite 5k. The Edcor is beloved for a reason at the price. The Tamradio, well, not a fair fight.
If I don't get distracted actually finishing some projects, I'm tempted to compare the Antek to the Edcor and the Tamradio in the chassis where both live, for the former, to see what the Antek does with some more power and UL connected in the Tubelab SSE and the latter to see if the Tamradio looks happier in comparison in its normal 2.6W RH84 home. But then, I did hurt a bit 845 amp doing power runs and both the TSE II and a preamp need to find their way into enclosures, so I may not get it done.
Paul
TPA3255 Bluetooth Car Amplifier, Battery operated Boombox.
Here's my design of TPA3255 Car amplifier amplifier, The design includes 12V battery to +40V Interleaved DC-DC Boost Converter with Fuse and Battery Reverse protection.
Next I will design the pre-amplifier & Bluetooth audio & Bluetooth Remote Controller.
Prototype boards will be available by next week and hopefully I can demo the audio performance.
Here's the video of the design and assembly.
Login to view embedded media
dual bridge rectifiers - one for each channel or one each for pos/neg
When building a power supply for an audio amp with a transformer that has a center tap, or better yet dual secondaries, and using two bridge rectifiers, I get that you can use one bridge for the positive and one for the negative rail, and then share the split rail supply with both channels, as in this standard Pass DIYaudio design, from the Aleph J build guide:
Screenshot 2025-02-15 at 11.17.46 PM.png:
Alternatively, Rod Elliot suggests this "dual mono" design where you have a center tap transformer and two bridge rectifiers and you use one bridge rectifier for each channel, as in this link:
rod elliot power supply
I'm wondering what the pros and cons are of each of these approaches.
I get why you would want to separate the channels, to avoid 'cross talk', but what's the advantage of separating the pos and neg rails?
Tigersaurus remake?
Thinking about re-doing the original Southwest Tech Tigersaurus with a new board that will accommodate a more up to date transistor array by eliminating the hard to find and costly 40410 and 40409 transistors that are mounted on their own heat sink. Does anyone have any ideas for a replacement transistor? I have located some 40409's and 40410's but at $10 a piece its a little more than I want to spend on my retirement income.
For those not familiar there was an article in the 1973 March-April issue of Radio Electronics. Designer was Daniel Meyer. This was the design that he discussed with Bongiorno and shortly after the discussion Bongiorno came out with the Ampzilla which copied Meyers quad diff front end.
Help with choosing midbass woofer
Hi All
I was wondering if you can help
I am looking for a midbass woofer that I will use in my car in a sealed box, the box will be around 15L and in a sealed application.
I need the woofer to play from 45 to about 140hz, I need it to have good xmax, be sensitive and good power output.
I want something as accurate/snappy as possible.
Can you guys recommend any woofers to do this?
Also what TS specs would be most suited for this application?
Many thanks
Interest in balanced line receiver boards
UPDATE: This GB is now closed. The boards were manufactured and are being shipped to the participants.
Earlier this year, I created a thread about a balanced line receiver board:
Since there have been some questions on the availability of these boards. I am starting this group buy to see if there is enough interest to warrant a manufacturing run.
What it is
  • One 68x28mm (approx. 2.7x1.1in) all-through-hole board implements one channel of high performance balanced line receiver.
  • The use case for this board and its theory of operation are discussed at some length in the main thread.
Features and benefits
  • Low distortion. The board allows using modern opamps (e.g. the LM4562) and has much better distortion performance, both measurably and audibly, compared to most integrated balanced line receivers (e.g. THAT1200 series).
  • DC blocking. The board includes an active DC blocking filter, making any coupling capacitors unnecessary.
  • Choice of balanced or ground sensing output. The output can be configured as balanced or as remote ground sensing.
    • The balanced output option is useful if your downstream device has a balanced input. (Note that balanced means equal hot and cold output impedances. Only the hot wire is actively driven, so you won't be able to drive two amplifiers BTL fashion).
    • The ground sensing option is useful for downstream amplifiers with single ended inputs. Configured for ground sensing, this board corrects for the difference between its own ground and that of the downstream amplifier, making sure that the latter sees the correct signal at its input. The details are discussed in the beginning of the above mentioned thread.
  • Choice of gain. The default gain is 0dB (unity), however, the gain is set by discrete resistors, and any reasonable gain can be chosen.
  • Good CMRR even at higher frequencies thanks to an advanced PCB layout. Typical CMRR is better than 50dB with 1% resistors and better than 70dB with 0.1% resistors.
Pricing
  • Will depend on the level of interest, starting with $5 for one board (one board = one channel, two are needed for stereo) plus shipping. Should the total number of boards exceed 50, the price will go down.
  • Shipping is flat $5 for the continental U.S. (USPS Ground Advantage) and $15 elsewhere (USPS First Class International Package). Should you want to buy something else from me, I of course can combine shipping.
Build and other technical details
  • The schematic and the board outline are published in the main thread.
  • The board uses compact axial metal film resistors, such as Vishay CMF50/RN50 or SFR16S, Yageo MFR12, KOA Speer MFS, etc.
  • Other components are very ordinary and allow broad substitution. Since the board is through-hole, one can socket the opamps and try opamp rolling.
  • Full BOM and assembly instructions will be provided.
If interested in purchasing any of these boards, please reply to this thread. Copy this sentence along with everything below into your post and add your own line as follows:
(1) Your name here on diyAudio -- (2) number of board, pieces -- (3) Country to ship the board(s) to.
Try to preserve formatting.
Running List for Subscription :
alexcp -- 2 -- US
This group buy will close on Saturday, September 30. Be sure to sign up before then.
Musical Fidelity A308CR Power Amplifier Recap Suggestions
I have been using Musical Fidelity A308CR power amplifier and preamp that I have been using with Totem Hawk speakers for quite some time now. The build date is stamped in 2003, they are both officially 20 years old to date! Everything works great and looks good internally but considering the age, I'd like to give them a refresh and replace the 20 year old capacitors and upgrade a few internal bits as well. I also have modified a Musical fidelity x10v3 tube buffer with an upgrade kit by guy named "Rockgrotto" who supplies modifications for these units (basic soldering, and removal of the old tubes + caps) but that is the extent of my abilities with basic knowledge. So I am open to any suggestions you guys have and what you would change internally in these amplifiers.
Btw, feel free to criticize as well if you don't like the amplifier design - please explain why though! I am aware that Musical Fidelity tends to use fairly basic/average components in their designs (Jamicon caps) and the wiring seems fairly substandard, amongst others. I however look at that as a positive - these amps sound pretty darn good as is (and were the top of the range at the time from Musical Fidelity) so updating/replacing the weak stuff with caps from the likes of Nichicon and adding thicker internal wiring could only make it something special (or at least that's my logic!)
Below are pictures of the a308cr power amplifier for now, as that is what I want to tackle first. So far I am looking at replacing the 8 Jamicon 10000uf 80v caps with Nichicon 10000uf 100v caps (LKG2A103MKZ) and all remaining smaller caps with similar ratings by Nichicon. There are also 14 Metallized Polypropylene Film Capacitors that I would like to update and I'm open to suggestions on that (Wima? Siemens MKV?). Kimber TCX for the main board to binding posts, while using Kimber TCSS for the signal path wiring. I may also consider changing out all the diodes for something better quality as well, but again, I'm open to what you guys think. It has also come to my attention that the amp should be biased properly, but I don't have the equipment to do this - is this necessary? Thank you all in advance!
Satori 7.5" mid-woofer coaxial tweeter for Voigt Pipe Focal Flax EVO
Is this Satori suitable for a VP and how ideal?
7.5" Coaxial Driver Combo Tweeter and Mid-woofer
AudioXpress.com Test Bench
Data is correct to stock at time of printing, however SBA are constantly improving their stock and data may change without notice. For the latest datasheets, please see www.sbacoustics.com
Black Cone
60W
7.2mm
0.31
0.5kg/s
1.13mm/N
43Hz
90dB
each
Mid-Woofer
37.1L
6.54
0.33
0.12mH
0.12mH
8 ohm
1.1T
152cm²
165mmØ
39mmØ
12.1g
0.13kg
116mm
187mmØ
6.5Ω
8Ω Re 6.5Ω
Satori
Single
Satori
SAT16-GRL
1
60Wrms
7.5'
8.05Tm
[th width="201.734px"]
Description​
[/th]​
Review​
[/th]​
Note.​
[/th]​
Colour​
[/th]​
Prms​
[/th]​
Xmax​
[/th]​
Qts​
[/th]​
Rms​
[/th]​
Cms​
[/th]​
Fs​
[/th]​
Sens.​
[/th]​
Price Type​
[/th]​
Type​
[/th]​
Vas​
[/th]​
Qms​
[/th]​
Qes​
[/th]​
Zn​
[/th]​
Le​
[/th]​
Impedance (Ohm)​
[/th]​
Flux (lm)​
[/th]​
Sd​
[/th]​
Width​
[/th]​
Coil​
[/th]​
Mms​
[/th]​
Mag.​
[/th]​
Depth​
[/th]​
Diam.​
[/th]​
Re​
[/th]​
Impedance​
[/th]​
Series​
[/th]​
Sold As​
[/th]​
Manufacturer​
[/th]​
Grille​
[/th]​
QTY​
[/th]​
Power​
[/th]​
Size​
[/th]​
Bl​
[/th]​
Also the flax evo
Push buttons are intermittent and have static, how do you clean them please? NAD SERIES 20 3020 AMP
I’ve had the amp overhauled and it sounds great but when I switch between like tape and auxiliary and tuner, the sound cuts out and I have to just kinda like press the heck out of the button to get it to actually sounds fine so it seems that they’re dirty, but I don’t know how to clean them.
I’ve included photos of the buttons on the outside and the switches on the inside. Thank you!
Help with HK/Silver pre/power combo
I've recently recapped my Silver SP5050/SA5050 combo, which is almost the same as the HK725/770. There's 2 things that I haven't been able to work out though that I'd appreciate help on.
I'm using a known good CD player as the audio source.
1. Every time I turn the amp(s) on and play music, there is crackly distortion for about a minute, both channels impacted. This is not caused by pots being turned, and it goes away I guess once something warms up. But if I play music for 20 minutes so everything is warm, turn it off and then turn back on straight away, the same distortion is there for a minute. I've replaced all the electrolytics plus a couple of transistors, but wondering what that behaviour could be a symptom of?
2. The left channel for the "A" speakers doesn't work. The LED power display comes on, showing a signal for both channels, and the "B" speakers work fine. As far as I can see, there is one relay for A and another relay for B, so on that basis I guess there is some sort of fault on the actual speaker terminals or the board they mount on. Is that correct?
Need help with oscillating amplifier (Denon POA)
Hello all!
I would really appreciate any help i could get here since i've been working on this amplfie for way to long and i'm still having problems. I have invested in a new scope to se if i can get any leads. Since i'm new to using scopes and in general an amature i have realy no idea what to make of these measuements down below.
The problem i'm having is that the amplfier seems to oscillate and cause my voltage rails to drop and my DBT is flashing slowly and low. Powering on amp with CN6 connected i'm able to get out of protection for about 5 seconds and then relay kicks in and protection light goes back on. Most parts on amplifer board are replaced with new ones and all elektrolytic capasitors are replace with new quality ones. The measurments down below are with and without CN6 connected. The scope is set to AC Couple because something is telling me im getting AC-ripple or oscillation from AC?
Main amp board:
PSU
Pic 1 probes at red and black from PSU (pink position) : CN6 disconnected . FFT 10Khz (I'm having problems setting trigger point becuase waveform is jumping all over the place, up and down)
sds802x_hd_png_1-png.1415916
Pic 2: Same as above but FFT 25Mhz (high freq)
Pic 3 probes at red and black from PSU (pink position) : CN6 connected. FFT 10Khz (waveform more steady!)
Pic 4: Same as above but FFT 25Mhz (high freq) (waveform more steady!)
Pic 5: probes at CN13 position from CN6 disconnected . FFT 10Khz
Pic 6: probes at CN13 position from CN6 disconnected . FFT 25Mhz (high freq)
Pic 7: probes at CN13 position from CN6 connected. FFT 10Khz
Pic 8: probes at CN13 position from CN6 connected. FFT 10Khz
Pic 9: probes at CN13 position from CN6 connected. FFT 25Mhz (high freq) (2.2V ac coming true?)
Pic 9: Probes at test point 1 & 2: CN6 Connected. FFT 10Khz
Pic 9: Probes at test point 1 & 2: FFT 25Mhz (high freq)
What can be the cause of this. Maby Brdige rectifier are failing at load or anythin else to concider?
Build a FM stereo decoder using chip and tube
This is a FM MPX stereo decoder that uses a stereo chip to acquire the 38KHz switching waveform, and applies that to a "TV" tube that switches on and off the composite audio (which carries both the mono and the L-R difference signals) to produce left and right audio outputs. Idea is to use the chip to get a synchronized switching waveform. And the tube handles the audio signal that will go to your audio amplifier.
attachment.php
First thing is to find a chip that produces a 38KHz switching waveform. Turns out most of these stereo decoder chips don't provide that, keeping this signal inside itself. Some will provide 19KHz, but that's not useful. With my selected chip datasheet TA7343 I can get the 38KHz signal, but only if I don't have it directly drive an indicator LED. Doing that disables the chip's stereo demod section, but I'm not using that here. I found that when this chip loses lock on the stereo pilot signal, this 38KHz output pin goes much higher in voltage, thus I used a buffer circuit to light a "not stereo" LED indicator when that happens. The FM radio station essentially MUXes the left and the right channels by alternating the left and right audio signals at 38KHz rate. Making a sequence of L, R, L, R, etc at this 38KHz rate (time division multiplex) And my circuit recreates this 38KHz switching signal and essentially deMUXes the left from the right. The 6HS8 is a tube meant for color TV work, where this tube splits apart chroma information (which is also a MUXed signal of R-Y and B-Y chroma signals). In my circuit, each grid 3 has a square wave at the 38KHz rate that allows (when near +2V) its audio channel to get to its respective plate, or when this grid goes about -5V negative, cuts off the audio (disabling the audio that belongs to the other channel from reaching this plate). I used an LED to create a fixed bias for this tube, so these levels would always work). The LM393 dual comparitor chip produces 2 38KHz square waves, one inverted (it's essentially a data slicer). These square waves feed the grid 3's after passign thru a "DC restore" circuit that sets the voltage range of these square waves to levels the tube wants (also if stereo lock is lost, this circuit will clamp both signals to an "on" level, thus passing audio to both outputs). Otherwise, the comparitor chip will make a positive level on one output and a negative level on the other, thus cutting off one of the outputs.
I appear to be getting good channel separation, but no, I haven't figured out which channel is the left, and which is the right, just yet! 😀
Reactions: stelios
No internet radio with M1 Clic
Hello all,
I'm not sure if this is posted in the correct forum, but here goes.
I have a Musical Fidelity M1 Clic that I use for listening to internet radio on occasions. This has functioned perfectly fine since purchase two years ago then today when powered on and Internet Radio selected shows "connection error". The unit is connected via LAN and the connection appears okay, when the cable is plugged in the correct time shows and the icon shows a connection. The LAN port used is okay as checked out with my laptop.
Being an older device I wondered if the system for internet radio has changed and this unit no longer supports this. Much like terrestrial TV was switched off some time back. Are their any Clic users out there still able to listen to internet radio?
In case it helps I am based in the UK.
Cheers.
Alan.
For Sale Ariston CD1 cd player, CDM4/19 + TDA1541A(si)+OPA627BP
British Ariston CD1 CD player. Considered one of the best players in the world in the early 90s. It has CDM4/19, TDA1541A(si), and specially desinged power supply. Op-amps have been upgraded to OPA627BP (4 of them). I have a heavily modified Art Dio (upgraded diodes and power caps, Linear op-amp, upgraded power supply, Dale resistors, disabled ADC section, directly-soldered cables , and more). Using CD1 both as a player and a transport at same time, I find the sound coming out of CD1 to be of much high quality, especially regarding imaging and depth. Subjectively, I would say that CD1 is a very musical player.
My player is in excellent working condition and reads my CDRs without any problems. CDM4/19 has recently been checked by a technician and is in good condition. I would give my player a cosmetic rating of 90%. No remote is included.
A recent CD1 without remote and any Op-amp upgrade was sold in Taiwan for 13500 Yuan (=$400) + shipping. My asking price is $210 with free shipping to the lower 48 states. I will also ship my player to Taiwan and Mainland China for an addition fee of $40. You can also email me your offer if you are seriously interested.
Please email me at mhan@oberlin.edu for pics and more info. I don't have any feedbacks, since this is the first time I sell my gear here. I live near Cleveland and I welcome you to audition this player.
Note: It is suggested on the player that the transport should be removed during shipment. I will do it for you at your request.
Building a High-End midway crossover with WEE Technology - WEET - WMH capacitors
Hello fellow audiophiles,
I have been building my own speakers and modifying them for many years. The goal is to achieve the most natural sound quality possible, so that the playback is indistinguishable from an unplugged live performance. A loudspeaker should not have its own sound; after all, it is not a musical instrument but a device meant solely for reproduction. One of the most challenging aspects of designing a good loudspeaker is undoubtedly creating an effective crossover filter. It involves not only calculating the perfect values of the components but also making the right component choices.
Over the past years, I have extensively experimented with capacitors, always trying to use the best possible ones. However, high-quality capacitors are quite expensive, and sometimes it's not feasible to use them due to their high cost. I always use film capacitors based on polypropylene in my designs, as electrolytic capacitors are a no-go for speaker crossovers, at least for me. For low frequencies, you often need capacitors with high values, especially in a three-way system like mine. The midrange driver starts around 60Hz, and I let the woofer roll off around 50Hz to avoid interference frequencies. Using really good film capacitors in this scenario can quickly become quite expensive.
In my design, the midrange driver covers a frequency range from 60Hz to 5KHz. It's a very wide range, but the advantage is that almost all critical frequencies are handled by the same speaker driver, eliminating any crossover interference within this range. For the midrange driver, I need a series capacitor of 100uF, which is quite a high value that can't easily be filled with super expensive capacitors if you don't want to spend a fortune.
Until now, I have used a combination of Jantzen Audio Superior-Z and Jantzen Audio Silver-Z, along with bypassing them with Cornell Dubilier 940C 3000V capacitors. This setup already cost me over €450 per midrange driver. Although I'd like to use even better capacitors, options like Alumen-Z would cost around €1000 per midrange driver, which is not doable for me. Therefore, I was thrilled when I came across the brand WEET on an audio forum on the internet. I checked the capacitors they offer and directly contacted Fay through www.musicaps.com. She was very friendly and professional, addressing all my inquiries excellently. Eventually, I chose 20 pieces of 10uF WEET WMH Aluminium capacitors, and we agreed on a price that was feasible for me.
I then spent two days building my two crossover filters on wooden panels, which I mounted on vibration dampers, externally on the back of the speakers.
After completing the setup, I began listening to the speakers. I know that capacitors, and every conductor in general, even a simple copper wire, as well as all the new sockets, plugs, and not to forget the 0.47mH Litz coil placed in series with the capacitors, need a minimum of 150 hours of playtime before they start sounding as they should. Often, the sound quality reaches only 80% to 90% of its potential during that time, depending on the materials used. For instance, Teflon capacitors require half a century of "breaking in," and silver conductors also need several weeks to reach their full potential. However, I started by playing track no. 2 from the IsoTek Full System Enhancer & Rejuvenation Disc, which is a half-hour long track. I knew there would be quite a noticeable difference after playing this track once only. After 30 minutes, I played a piece of music and started listening.
Right from the first notes from my speakers, I was pleasantly surprised! It already sounded significantly better than what I was accustomed to! Over the following week, I let the speakers play continuously at a low volume. During the night and when I was away from home, I used the IsoTek CD, and when I returned from work, I played music. Every day, I heard improvements, and I must admit that I experienced goosebumps several times while listening. These WEET WMH capacitors achieve an unbelievable high sound quality: the openness, depth, and width of the soundstage, the pinpoint precision, and the realism with which the music is reproduced are of such high quality that at times, I genuinely feel like the musicians are performing in my living room. I have never been a huge fan of live recordings; somehow, I found them less natural and was more drawn to studio recordings. However, that has changed completely now! Every live recording I've heard so far has astonished me; the realism is unlike anything I've ever heard before, even with very exotic speakers and expensive sound systems. I can only use superlatives to describe the experience, and that's precisely how I perceive it. Not just me, but all my audiophile friends who come to my place regularly to listen, while enjoying some drinks and snacks, were amazed as well. The most memorable compliment came from one of these friends who said before leaving: "Thank you, Alex." I asked, "Why?" And he replied with a smiling but serious face, "Now I won't be able to listen to my own setup at home for at least a week because it sounds like an old-fashioned transistor radio compared to this."
I've never received a better compliment, and at the end of this rather lengthy review, I want to pass on the same great compliment to WEET and thank them for all the beauty these capacitors will bring me in the coming years!
The WEET WMH capacitors are not just very good; they are a MUST for anyone who needs higher value in capacitance range and wants to build or modify a relatively affordable crossover filter in such a way that there is no doubt about achieving a realistic reproduction. With the WMH capacitors, you can be certain that at least capacitor quality won't be the limiting factor!
Best regards,
Alex
1kV GU50 PP 100W RMS amplifier from a SINGLE PAIR
a year ago I have come across a stash of GU50s. The human brain thinks simple in those situations, see shiny, want shiny, even if it serves no purpose. SO I took em.
Today I have tought to myself, HMMMMM these things are rate 40W anode dissapation Ua1kV and Ik 350mA
I think I can easily pull out 100W RMS out of a single pair. Well, would be easier if I didnt want a UL output transformer with cathode feedback windings too.
Here is the setup:
Yes youre seeing it right, 1kV anode voltage. With this voltage I could probably get into the 130W RMS territory (as the cathode current in this setup is peaking 250mA nowhere near the Ik limit of the tubes)
At this voltage getting acceptable class AB behaviour is not that easy as it requires to drive tubes into 30-35W dissapation but according to the simulator it yealds 2.7%THD at 100W RMS
The parameters for the transformer are
10k Ra-a
30%UL
10%CFB
The one issue I am seeing here is the quite large negative G1 voltage. At very negative voltages grids start to behave like electron deflectors..something like a beamforming electrode but in an undesireable place. I might reconsider what to do about it, either lower Ug2 but then having to drive grids positive. If anyone has experience with such negative bias voltages with these tubes or tubes of any kind, precise values or whereabouts your contribution would be really appreciated.
The exact reason I went with 600V Ug2 was because I didnt want to push grid current into them. The GU50s do however have the magical capabillity of withstanding up to 1W ! of grid 1 dissapation. That is quite insane If you ask me, however G2 dissapation kinda sucks a little. But that is not an issue as my G2 voltages are largely below the anode ones so not much G2 current flows until the anode voltage falls below G2 voltage and then larger current starts to flow which is sorta limited by the 100ohm resistors (while still not impeding gain)
The cathode feedback windings hugely increase the drive requirements right up to 600V p-p. This is certainly a problem to overcome with both a tube or transistor driver. But I have a solution.
This abominaton:
C1 and C2 replace grid cappacitance of GU50s (datasheet maximum value)
At first I did not plan it to come out like this, but I thought "what the hell lets give it a chance anyways"
Interstage transformer with cathode feedback to prevent phase shifting.
Everything is DC coupled, no bass frequency compromises HOWEVER I see a slight issue with this. While the voltage on the anode resistors are going to be fairly predictable thanks to the current sources, if the tubes are mismatched that will cause a current flow difference between one anode to another one and consequently DC current will flow trough the interstage transformer.
I dont know of a small power still manufactured tube that could give me a 600V p-p swing without great distortion, melting it or straight up ripping the emissive coating off the cathodes. So it was either a cascode of I dont know what tube that could also give reasonable drive power without melting, or an interstage transformer. So I thought if I have to use an interstage transformer might aswell overdo it. And that was the result of such thinking.
I dont know the winding ratios yet because I just threw down the priary inductance by gut feeling and then adjusted everyting arround until I got desireable results and gains.
Any feedback on this insanity would be appreciated. Please do leave feedback as I mostly draw this sort of stuff up trought the night half asleep and I might miss some fundamental errors why this cant work or wont work the way I want. Suggestions on how to make it better or fix it if broken are greatly appreciated.
Reactions: Svytoslav
Trying to understand fault with a 70s Sony amp that blew up protection resistor, and VAS stage capacitor
Hi all,
I've been given an old 70s Sony amp to try to repair (to learn), that has a series resistor (into the propriatory Sony module) visibly damaged.
I disconnected the 2 chip modules to ensure there's no damage to them. After several days of checking voltages and trying to understand, I've now discovered that a capacitor at the VAS stage has leaked fizzy electrolyte while I had it powered on.
I'm short on time at the moment, hoping to post some pictures, section of the schematic, and some of the voltages that I recorded later tonight.
I bought 2 of Self's books, trying to understand the various transistor stages before the Sony chips.
There is a current source PNP mirrored section that provides a current source to the differential amplifier stage at the input, and also it seems to provide current to the VAS stage, however I'm not sure how this works as there's a polarised electrolytic capacitor between the current stage and the VAS class A transistor amplifier. It seems different to anything I've seen in Self's books. Between the VAS stage and the Sony modules (SS050 I think they are), there is some sort of current protection system with 4 transistors, their bases being fed from the Sony modules.
Should the PNP transistor that provides the current source to the VAS stage always be on? The diode voltage drop of the other diode should be enough to lower the base voltage so it's less than the emitter and turn the transistor on?
The Emitter of the NPN transistor for the Class A is hooked up to the -36V rail via a 62 ohm resistor, so if this transistor is always on, it will surely punch more voltage across the capacitor in the middle than it can handle?
Quick summary:
Voltages on one channel seem fine. The other channel seems suspect.
Output relay protection is triggered and will not release.
Series resistor into one channel's Sony module is burnt to a crisp (colour of resistor has changed and DMM reads open circuit).
I did a diode test with the DMM on all the transistors (in-circuit) and they seemed fine (I think).
This 100uF / 6.3V electrolytic cap leaked.
Voltages from the collector of the PNP current source and the collector of the NPN class-A amp transistor was +36V DC and -36V DC, meaning there was some 72V DC across this 6.3V capacitor.
This surely means both the transistors were hard-on, allowing the +V and -V rails to be connected to the cap?
Various expected voltages from the schematic (roughly) match what I've probed other than the PNP collector / NPN collector voltage mentioned above.
There's a diode / capacitor in parallel from the +V rail to the bases of the 2 PNP mirror current sources - voltage there seemed to be slowly increasing or decreasing when I probed it (need to check my notes later on and report back).
I'm keen to try to diagnose this myself, in order to learn this "on my own", but would very much appreciate any sort of "cryptic" / "zen-like" questions or pointers you might have to "vaguely point me" into the direction that I can head to next.
Question for 2nd order Butterworth XO
I’m trying to calculate the crossover frequency for an existing crossover, which I know how to do with a simple LC design but I’m not sure how to treat the series resistors in this design. Do I add the resistances in with the impedances and look for the frequency where the sum of R+Ic is equal to the impedance of the inductor+its R? Is there more to it. Why would one design it this way? Thanks
Reactions: Ixnay
Jazzman"s ripole with Faital 12pr320
Hello there,
I had a strange idea at looking the spec of the Peereless SLS-12, used in the famous Jazzman ripole.
Here is the TS spec measured by a Dibirama website . Qts : 0.52 ; Fs :30 Hz , Xmax : 8 mm ; sensivity higher than the datasheet with 91.5/2.83V.
The PA Faital 12PR320, a more a pro midwoofer than a woofer, falls faster than the SL-12 below 100 hz.
It has 93dB/2.83V at 100 Hz, 2 dB more than the Peereless here; 85 dB at 50 Hz (IEC Baffle) only but it is what showing also the peereless SLS-12 datasheet.
The ripoles circa extend the Fs by -10 Hz and drops the sensivity by 10 to 11 dB. The Faital has 42 Hz Fs. In ripole it means around 32 Hz
Xmax between the two drivers being quite equal, minus the worse Qts of the Faital 12PR320 : 0.38/0.40 in real life ; do you think it is feasible to use two Faitals 12PR320 for a Jazmann's ripole if two Sub in the room ? The EBP of the 12PR320 is 100, twice than the Peereless, so theorically more made for vented.
Edit, is there a way to sim that. I only know Vtuix Cad, not an easy task but playing with the baffle step option to reduce the baffle at the size of the driver and click to x2 driver and seewhat the baffle step loss could be as an open baffle (I get -11 dB at 40 hz...) but the only OB sim I have is with an infinite baffle (I assume IEC baffle dimension for Vituix compute)
MPP
After a long sabatical from electronics design i am back on the drawing bord and have designed some phonostages, pre-pre´s, a preamp and will start to design a poweramp too.Being more of an analog guy i have help from good designers of digital gear so da converters and dsp may follow.
my comercial designs are made to have very low distortion, low noise and high speed so using voltage feedback (some call it NFB) is the order of the day. this can be done in many ways and results can be excellent also soundwise nevertheless it orcured to me that i would like to build a phonostage for my own purpose based on other priorities. having worked with Malcolm Hawsford has pursuaded me that maybe the tiny details so important for a feeling of reality (some may call it microdetail or ambience) can be lost if a portion of the output is fedback to the input to cancel distortion thereby also canceling the minuscel details. Douglas Self may not agree and he has certainly proven that a heavily fedback design with even the evil electrolytic capacitor in series with the cardridje can be made with very low measured distortion and noise. This contadictory standpoints stand in the way of marketing an expensive device that does not have extremely low levels of distortion and noise. Getting tired of arguing i desided to do this design for my own pleasure. If there is any interest i plan to make some by hand. Bu be prepared that it will be quite expensive and i can make only a vew in my rare sparetime. Actually today i finished a first prototype and it worked to my satisfaction although it it not fully optimised in any way. During this thread i will give more details. Let me say so much that it is a balanced parallel symmetric transimpedance design. I have seen such a circuit on the web but can not remember who posted it. it is an elaboration on prior art by Leach, Hiraga, Rambeyrolles and Rositer. I developped it a little further and will use very good components like MAT02, MAT03, teflon caps etc. construction is done in classic air dialectric fassion with the components directly soldered point to point. i will also try to take care of mechanical resonances, shielding, grounding and powersupply. i will also make a compasison to other designs, for example cascoded fet stages like in the pass ono. i will publish measurements and parts of the circuit diagrams. any input is wellcome. P.S. MPP stands for my phono pre
Krell FPB200
I purchased the Krell FPB200 a few years ago with the intention of repairing it. I'm now at that stage (I know late). Anyway, the left channel is almost exactly 1/2 the output of the right channel. It sounds good but way low. I measured the power supply and it supplying the right voltage. So far I haven't been able to spot the problem and wanted to see if anyone else has had a similar problem and where was it coming from. Any tips on troubleshooting this would be helpful since Krell is down for now. I've attached the schematics for review.
Thanks,
John
Reactions: hpavictor
Air Core vs Iron Core - Sensitivity
First off, ignore that bass hump. Its not accurate but the rest of this is.
My plan is to use all high quality components in my newest crossover simply because the XO will be mounted on the wall of my office and will be visible to anyone. I was going to use all air core inductors, however, the DCR of the large inductors is takes away a full 1.8db of sensitivity from the entire build. I wouldn't have to pad the mid of the tweeter as much since I could bring those up to match.
This is already a pretty hard to drive speaker. If it weren't for the ribbon I'd be considering active even though I know very little about active outside of the DSP of the head unit of my car which is far and away from hifi. Basically the definition of lofi.
The XO on the woofer is pretty high so I wanted to use air core here but do you think that is really worth it at the expense of sensitivity?
can ribbons or planars work in a MEH?
Thinking this combination would sound good, but Im unclear if the pattern emitted by the ribbon/planar is already too focused to take advantage of the MEH wave guide..
Also wondering if anyone knows of a reasonably priced and small ribbon that I can cross at 800Hz for a 2 way MEH build?
looking at this but its pretty anemic: would prefer a real ribbon..
https://radianaudio.com/collections/ribbon/products/lm8k-wide-band-planar-ribbon-transducer
Image Dynamics HLCD Clone
Over on this thread I made some attempts to do "ultra shallow" waveguides : http://www.diyaudio.com/forums/multi-way/306425-ultra-shallow-waveguides.html
The idea was to put something in my car in the kick panels that was ultra shallow.
Those waveguides had promise, but off-axis response had dips. Can't have your cake and eat it too; if you use geometry trick to narrow the beamwidth, there's a price to pay.
So I thought I'd try making a clone of the Image Dynamics HLCDs. As I understand it, these were designed by Eric from Image Dynamics. I believe Bruce Edgar did some consulting on these too. (They were next door neighbors in California back in the day.)
They're generally the best regarded waveguides for cars. I haven't bought a pair because I like to tinker and DIY.
I have bought a pair from USD, which predates the ID design :
http://www.diyaudio.com/forums/multi-way/151376-homster-how-i-learned-how-fix-horn.html
High voltage 50v opamp? Can you recommend?
Hi Guys,
Working on a projects that uses a power supply but has an opamp to filter the power. The current opamp is Lf353 is gets warm when I output 24v+ and 24v- I want to actually do 27+ and 27- but luckily I didnt as I read that the opamp can only take 18+- max! Infact one guy left a feedback on ALiexpress that the chip burnt at 24v!
The capacitors are high enough voltage so is the lm317/6 but the opamp isn't. I don't know anything about high voltage opamp as I've only worked with normal ones like ne5532.
Can anyone recommend a cheap but effective high voltage opamp please? I'm testing with 24v+ and - which is ok but it would be nice to have an opamp that can go a bit higher to. I probably won't ever go past 30v+ and -
Any help appreciated thanks.
This thread seems to have some info and diagnram. I noticed the opamp was getting its power for the ouput terminals of the board. By that I mean if I turn it up to 27v+ and - then the opamp would also get 27v+ and - in its power rails.
LLC smps with solid wire xformer
Ok, so some sources suggest that for an LLC supply you can use solid wire for xformer vindings IF the resonant inductor is implemented as a seperate inductor.
It looks very, very wrong, but it would be so much simpler and I had to test it. I tested with solid core for both primary and secondary, and efficiency stayed above 80% for 150w out Including rectifier and all.
I switched the primary to 8 strands of thinner wire and kept the solid secondary. Efficiency peaks around 90% for 150w out.
This is a etd39 core and lowest frequency for max load is 80khz.
Secondary is 1.3mm solid wire!
I will test again with 8 thinner strands for secondary, but I don't expect much improvement.
Unless I botched the measurements this is somewhat surprising to me.
Help with Audio Extractor for Separating Audio from HDMI
Hey everyone,
I'm looking for some advice on audio extractors. I want to separate audio from an HDMI signal so I can run it through a separate speaker system without affecting the video output.
My main concern is audio quality—I'd prefer minimal loss or lag. Are there any particular brands or models you’d recommend?
Also, are there specific features I should look out for, like support for 5.1 surround sound or compatibility with different HDMI versions?
Any insights or recommendations would be greatly appreciated.
SB Audience NERO-15MWN700D, Poor mans TD15M?
The SB Audience NERO-15MWN700D looks like a nice 15" mid/woofer with low inductance, smooth extended response and reasonable price. Only downside I see is the qts is listed at .46, if this creeps higher in reality the box size could get a little big. Anyone used it or measured it yet?
It models well in 6 cu ft with response into the high 30's.
Could this be a decent substitute for the AE TD15M and it's long lead times and high price tag? Any other drivers look interesting in this category?
Precision Devices PD.153C002?
Hello from Charlotte, NC
New member from NC. My name is Kris Ruckman. I am interested in building an open baffle speaker; probably the Bitches Brew model done by Perry Marshall. I don't own any open baffle speakers but they appeal to me because of their room interaction and lack of "box" sound. I found this site while searching for open baffle designs. I have been into hi-fi since the mid '80s and have a fair amount of gear / speakers. My taste is for full-range speakers that can play loud with low distortion. Speakers that are very dynamic / quick and have good timbral accuracy attract me most. Two speakers I own and very much enjoy are the Legacy Audio, Focus model and the Polk SDA SRS.
KR
DIY newbie: variable 3-way 12 or 24dB LR crossover build
Dear Audiogods,
after some reading I have decided to embark on my first active 3-way xover build and I'll be etching my own pcb's.
I dug into a few of Rod Elliott's projects and bought a bunch of NE5532 Op-Amps and a 15-0-15v transformer. The rest still has to be decided but it will be used for both hifi and small PA systems. Initially unbalanced inputs, then if it works and it makes sense I might consider improving.
I like the fact that a 24dB LR is in phase but I would like to have some flexibility regarding xover point. I read this is difficult as many R's would need to change.
If I decide that a variable xover is what I care most about I'd need to chose a 12dB filter that is easier to implement, the down side is phase shift.
1) CHOSING A SLOPE
Case A, Rod Elliott's 24dB LR: the only easy way of having "variable" a 24dB network I can think of is building multiple separate circuits with a fixed frequency, and have a switch to change between them (although not practical as I'd need X amount of opamps, R and C's for every passband. It would work but seems like a stupid and wasteful solution)
Case B, Rod Elliott's variable 12dB: Variable 12dB means it has one output that is 180° out of phase so it needs to be inverted. How does this work in the case of a 3 way filter to be in phase? Would it need to have Mid switched 180° compared to the Low, and then the High switched 180° compared to the mid Which ultimately has low and high in phase with each other? Or did I miss something?
In his project 148 he mentions a bandpass which is 90° out of phase with 6db rolloff which isn't very usable, does this refer to the midrange output I'm hoping to obtain? Or is it something different?
Ths article from linkwitzlab suggests NOT to use 12dB slopes at all though so I'm stuck and confused.
Any expert advice on how to get a 3 way crossover whith phase coherent outputs(regardless of the slopes used)?
2) HPF to cut out subsonics/protect woofers
If I wanted to add a 35Hz highpass to protect my subs how does this translate to the schematic? Is it an additional Opamp controlling this?
Ultimately what I'm asking is not critical as my main goal here is to build something that works and sounds ok (so I'm happy to go with either of the preexisting circuits, then eventually I'll increase circuit complexity as I learn more about electronics) but these are the two big doubts I haven't found an answer to.
Thank you to anyone taking the time to babysit me!!
Hello from Vinnytsia, Ukraine
My name is Stas, I am 20 years old, I am a beginner sound engineer. I do not have a technical background, but I am successfully moving in the direction of acoustics and developing. I do not have my own developments yet, but I hope that they will appear in the near future. Currently I work in a company that develops various speaker systems and amplifiers. They teach me, share their experience, and I, in turn, do everything in my power to become a good sound engineer. Currently I work with existing speaker systems, conduct audits, improve existing solutions, develop passive filters. I have a task to recalculate the horn for the HF driver in order to improve it, but I do not have enough experience, so I decided to turn to your forum for help.
Sincerely, Stas
Yamaha's Hyperbolic Conversion Amplification (HCA) Circuit
last weekend I have heard two different power amplifiers by direct comparsion:
1) Pass "X 600" vs.
2) Yamaha "MX 10.000" (MX10000, MX-10000)
I was surpriced about the low sonic differences between this two devices and I guess, that the HCA technology is also a good solution, especially if the loss power must be lower by the same output power.
Are there HCA diy projects respective other commercial amplifier brands, where is HCA technology inside?
New Member from Spruce Pine, NC
Greetings from Spruce Pine, NC USA. My name is Jason Kritz. I have tinkered with electronics as a kid back in the late 70's and early 80's watching my dad repair electronics, I would tinker on his bench, finding out how these components worked. I have taken courses on electronics and I love finding faults and repairing electronics I mainly focus on vintage and antique electronics from 1920 - 1990, so tube and transistor gear. I run a vintage repair business here (Joyful Noise Vintage Audio) and enjoy reading the threads on the forum. Sometimes I get a bit stumped on some hard cases and look forward to some input and help from others in this field. I also look forward to helping others with the knowledge I have gained through my experience. I am trying to get a Yamaha Mx-1 up and going, but I will keep that comment for the thread already open about the BA3122n. Blessings to you all.
For Sale Inteligent Soft start module (Fully assembled and ready)
I have for sale inteligent soft start module
  • max 2x600W toroid
  • mains DC blocker
  • mains LC filter
  • mains AC detector
  • push button on/Standby
  • Remote/Master slave
  • over temp protection
  • AUX +5V always On
  • AUX +12V (for SSR protection)
Price 50 eur + shipping (shipping for your country on request)
I'm sending to the whole world
Payment: Paypal, Wire Transfer
What tube amp to build
Hi, I'm new here.
Been reading site for a few days. Lot's of data to absorb.
I am thinking of building a tube power amp.
What do you think would go well with a VTL 2.5 preamp, has 12AT7 and 12AU7 tubes?
I've never had a tube amp before. The VTL pre was paired with an Acurus A200 driving PSB goldi's. Then went surround with a NAD T187 preamp.
So the VTL has been sitting. This system will be for another room for stereo only.
I have been in aviation avionics repair for 30 years repairing weather radars and autopilots to the component level.
There are so many plans out there, not sure what to get.
thanks, Jeff
Audio Technica AT-1010 Tonearm Rebuild and Upgrades
Audio Technica AT-1010 Tonearm Rebuild and Upgrades.
Having owned a PMAT-101O for some years i recently bought a used standard AT-1010 with the intentions of
rebuilding it and where i can upgrading the components.If i can match the high performance of the PMAT version i'll
be a happy bunny!
Here is the tonearm stripped into all its pieces.
The first job i wanted to tackle is to make a new bearing housing spindle bolt.The original one has a loose fit where the horizontal bearings run so i made mine with a tighter
tolerance.
The original.
8mm diameter head turned and then 6mm diameter turned for m6 thread.
Thread cut.
Here's the old with the new one which also has a 4mm hole drilled up its length for the tonearm wires to pass through.
Reactions: tmuikku and Zung
Hello from PA
Hello all,
I have joined this forum so I can learn and or possibly help someone else on the never ending audio journey. My current system...
Yamaha RX-A8A in a 7.2.4 setup
Macintosh MC7106 powers the surrounds
Proceed HPA 3 triple mono powers the front and center channels
Polk R700 mains, R400 center, R200 rear surrounds.
In wall side surrounds 3 way monolith 8"
4 8" Monolith angled Atmos speakers
1 Rythmik FV18
1 Bic 12"
LG 65 Oled inch TV
My next project is to build 2 subwoofers. I have been considering a couple Mini Marty's with the new Ultimax or possibly the Stereo Integrity HST18.
This site is a great resource of information and I'm looking learning new things and enjoying the journey..
For Sale PCBs for a Line Preamplifier based on OPA627
I have a few PCBs (as shown in photo) for the construction of a stereo Line preamplifier as was presented in my article in Audioxpress January 2019.
The preamplifier is based on OPA627 and has three unbalanced stereo inputs and two unbalanced stereo outputs.
Due to copy rights I cannot post the article here.
If someone has access to the article and want to build it, the price for each PCB is 28 Euros (shipping is included).
Projects by fanatics, for fanatics
Get answers and advice for everyone wanting to learn the art of audio.
Join the Community
507,683
Members
7,884,111
Messages
Filter
Forum Statistics
Threads
406,028
Messages
7,884,111
Members
507,683
Latest member
NenoCaldas
