Well , everything explained and shown in technical thread :
Iron Pumpkin(s) and other smaller vegetable animals , but be aware that
latest and final iteration of electronic part of package (main difference being JFet buffer instead of Diamond ) is shown in
Iron Pumpkin(s) and other smaller vegetable animals, Tips 'n' Tricks thread
on sale are several options :
1. Iron Pumpkin SE (yup , that one being for RCA inputs/outputs) ,consisting of :
-Iron Turtle SE AVC ,
as assembled and tested unit (two irons on one common pcb ), rotary switch ,50cm flat cable finished, necessary stand-offs
-two pcs of Iron Pumpkin SE mono pcbs (selector, shunt regs , buffer -all that on one pcb) , with all small SMD JFets presoldered , all BC bjt critters , voltage references , BD bjts for reg CCS ,all relays, Philips MKC 1uF caps , selector Lorlin switch with two finished flat cables, all multiturn trimpots , necessary 1-pin sockets for optional Borbely WCF buffer iteration, u22 cap for WCF
price - measly 550E , plus 30E for Paypal , P&P expenses
2. Iron Pumpkin (Bal) (yup , that one being for XLR inputs/outputs , possible combination with RCAs, read threads for that) ; that one consisting of :
-Iron Turtle (Bal) AVC ,
as assembled and tested unit (one iron on one pcb but two pcbs stacked having same footprint as previous one) , rotary switch,50cm flat cable finished, necessary stand-offs
-two pcs of Iron Pumpkin (Bal) mono pcbs (selector, shunt regs , buffer -all that on one pcb) , with small SMD JFets presoldered , all BC bjt critters , voltage references , BD bjts for reg CCS ,all relays, Philips MKC 1uF caps , selector Lorlin switch with two finished flat cables, all multiturn trimpots , necessary 1-pin sockets for optional Borbely WCF buffer iteration, u22 cap for WCF
price - measly 650E , plus 30E for Paypal , P&P expenses
3.Iron Turtle SE AVC (so no electronics),
as assembled and tested unit (two irons on one common pcb) , rotary switch ,50cm flat cable finished, necessary stand-offs
price - measly 450E , plus 30E for Paypal , P&P expenses
4.Iron Turtle (Bal) AVC (so no electronics) ,
5. Iron Pumpkin SE electronics ( so no AVC in package ) (yup , that one being for RCA inputs/outputs) ; that one consisting of :
price - measly 130E , plus 20E for Paypal , P&P expenses
6. Iron Pumpkin (Bal) electronics ( so no AVC in package)(yup , that one being for XLR inputs/outputs , possible combination with RCAs, read thread for that) ; that one consisting of :
price - measly 160E , plus 20E for Paypal , P&P expenses
for all technical questions , visit linked threads
for other questions - ask here or in PM
considering prices from other vendors of AVC thingies , I believe this is pretty good bang for the buck
shipping time from 1 to 4 weeks ......... sometimes things need to flow from Germany or China ......
and yes case/chassis needed : regular width , minimum 3HE ........ even if , with some care , it can be squeezed in proper 2HE case
in both cases 350mm deep case is good to have , from various reasons ..... one of them being - necessary distance between small Donut to rest of preamp
