Replacing Knobs with sliders ?.
So Im sitting at the work bench with a few pre-amps and tone control boards.
Some have come with Knobs some have come without knobs.
Im trying to draw up what my control panel will look like. Mains power s/w. AMP selector switch, Speaker selection switch.
Im going for a steam punk look. And had this idea. Can I replace the knobs with Sliders.
So slider for volume. Smaller sliders for Low / Mid /High balance control.
I did some reading And searching.But all the sliders I found have 3 pins only.
Like for the pots you get a double gang i.e.6 pin. Do you get double gang sliders. ?
My pots are all 100K. So replacing them with 100K sliders work ?.
I could always have two sliders for each control but Na that would take up too much space.
Any help with the right part name or what its called would be helpful.
Just want a confirmation that the idea will work before I blow money buying these sliders.
I found this.
https://robu.in/product/sliding-adj...ZrUJfP4t65YAIHM9StX64o7d5HMf5_OhoC_cEQAvD_BwE
and
https://www.ebay.com/itm/265128598401?_trkparms=amclksrc=ITM&aid=1110006&algo=HOMESPLICE.SIM&ao=1&asc=240037&meid=88a453539075480cbc72f5725c0e09a6&pid=101195&rk=3&rkt=12&sd=281782160222&itm=265128598401&pmt=1&noa=0&pg=2047675&algv=SimplAMLv9PairwiseWebMskuAspectsV202110NoVariantSeedWithRevOpt90NoRelevanceKnnRecallV1&brand=Bourns&_trksid=p2047675.c101195.m1851&amdata=cksum:26512859840188a453539075480cbc72f5725c0e09a6|enc:AQAHAAABMAoNKsJM3HOHkM0OuV9XKcsoXSMLk3wBBxTIYdgqgcSsJbD%2BWQW2%2Fi9%2FH9y8TZ%2F9TU3Es3oTKRolT9u5mF91RnSGjcRDdDpXI3GNi9QMheFP623sd2luaveQWWobQW5%2FEZdkQxxL1xR3GssHJroZdzCBpXxJOsPw0QMSolT00G4BYqZScYxhbUSYAdCh3xUsLbzLu%2BJpfd39LQ5SvGL7JgM0JpliD5d0n2A1S0WfooJSnDUz%2Feq0ZRhydrRfnwJN5Z8mbLPYEq%2F4JF5dKZg0lhjtcXKIYijiRabJLjXX%2B0cMCxQSotf6eq3An84%2BjcBJGVY49tCsA28P9MjqDaqC%2Fpw2NrXL780OTIWWCqbSRpD52CtjaIy2E5gdRKGqIn9QCsCmS8HAqOVWfVA%2FDz5R0qM%3D|ampid😛L_CLK|clp:2047675
I found this.
and
