WTB Oscilloscope
Looking for an oscilloscope for audio, smps/PWM and rc car motor types of signals. Happy with 2 channels and I am not very particular about features, only that it works and it's accurate. Size or digital/analog is not a concern either, so aiming for a cheap solution.
Located in UK, so I would prefer UK and EU continent sellers to avoid high shipping costs.
Thanks.
DC offset on op amp output
Hello all,
It has been a while that Im searching about the DC voltage offset on an op amp out put and its effects on AC voltage which we care about. I have noticed in some designs that DC offset varies from 35 to few mili Volts on the op amp output. So what would be the effect on AC voltage (if it has any at all)? What are the limits?
I appreciate your consideration,
Alan.
Why dont commercial manufacturers use soft starts?
Hi guys,
I salvage all the cheap faulty home theater amps I can find as they are a great source of power transformers and heatsinks etc.
I have not once seen a soft start system (at least that I am smart enough to recognize).
Some of these amps have 600 or 700w power transformers.
Conventional wisdom of the internet states that anything over roughly 300VA should have a soft start. This is if course stated to toroidal types however my understanding is that regular EI types are not much better.
Am I missing something?
Alpair 12p on wall
Helping a friend put a system together and we're gonna build him some boxes, I suggested the Alpair 12p as I've tried the 10p and was very impressed. I thought the bit of extra directivity from the larger cone would help given we're just going with these with maybe a sub underneath to save some money.
The boxes are going to be right on the wall sitting on a couple of brackets with some sorbothane hemispheres underneath just to decouple them from teh wall abit (condo living) So they'll be maybe just a teeny bit off the wall, but basically on wall on either side of the TV. Sitting distance is 10 feet away, speakers about 8 feet apart.
He has a loft with 16ft ceilings and far away side walls, so its just the width of the room that is small. Very reverberant room, no treatments, concrete floor. Anyhow was thinking of using the following design: http://frugal-phile.com/boxlib/P10free/CGR-Mar-Ken12p-310817.pdf Not opposed to building something even slightly larger as long as its shallow.
Any other suggestions or does this look good? Going to make out of MDF and paint white.
For Sale 20Mhz Oscilloscope - not used but stored in India
I have an Oscilloscope bought years ago 2Ch- 20Mhz - stored in India ( Bangalore) and available for sale. I will be in Bangalore - India ) during 1St Apr till 11th. I will post pictures when I reach Bangalore. Please contact me ( message here) in case you are interested. I had two Probes as well but search among my storage in my Apartment and should be possible to locate when I reach Bangalore
Rockford bd1500.1 going to protect mode
hi guys, recently buy a rockford bd1500.1 amp, right now it is connected into 4 ohms, supposedly it can go down to 2 ohms, and while playing in 4 ohms, when volume is 3/4 of the total and when bass hit, amp goes to protect mode. I switch the radio off and inmediatly on and amp starts playing again. Amp is not hot, and it sounds cristal clear. No evidence of malfuncition inside amp. Any thoughts??
Reel Tape Head Stage vs Phono Stage
I've recently bought a Technics reel to reel deck and have been thinking about getting an outboard preamp for it. Most of them are quite pricey, though, and there don't seem to be any kits around. (Bottlehead used to make one.) If I'm wrong about that, and someone can point me at one, I'd appreciate it.
Anyway, my question is about the difference between a preamp for a reel to reel and a phono preamp. The deHavilland tape head has 52dB gain, which, I see, is about the same as a phono stage. Now, I'm guessing that you can't just use a phono state as a tape head. Can someone tell me why not? Impedence matching or something of the sort? Is there any way to compensate for that?
For Sale Modushop monoblock chassis (pair)
For sale is a pair of the Monoblock 4U 400 chassis with 10mm black front panels. These are the preorder chassis from March of 2022. The heatsinks have been drilled with the UMS pattern by Modushop, the back panels are completely undrilled. One chassis has been assembled & used to prototype an amp (picture shown, amp boards are not included- it will be disassembled for delivery), the other is unopened. Selling as a pair. As shipping for these is quite expensive, I would prefer to arrange for pickup in Northern California, however shipping can be discussed.
Asking $550 for the pair before shipping.
Safety concerns about a particular crossover design
Hello everyone,
I’m revisiting an old crossover design of mine which I consider a potential threat to my amplifier (or any amplifier for that matter). I hope some more experienced people with knowledge of electronics and how electrical networks work to help me better understand and define the impact of such design.
To cut the long story short, it’s all about the current going through the coil of the HP filter (see the first picture below). Due to relatively high value of the capacitor in series with the tweeter (10uF) as well as the small value of the coil in parallel (0.17 mH), it seems that the latter is effectively shunting huge amount of current to ground. At least, that’s my assumption and in order to establish exactly how much current I’m dealing with, I’ve ran a simulation using XSim (luckily I kept the ZMA files of the project). The XSim screenshot below (second picture) shows that the current through the coil reaches as high as 3.85 Amps at around 3 KHz when using 100W power / 8 ohms. This number alone doesn’t tell me much if not compared to some sort of a threshold. Here the Ohm's law comes in handy and according to my calculations a 100 watt amplifier on 8 ohms load is expected to deliver 3.53 Amps of current.
Obviously there’s an excessive amount of current going through that coil and all I want is to keep it at bay. I’am well aware of the possible solutions like lowering the cap value, increasing the inductance of the coil and so on. The small value of the resistor before the cap is not helping either. But attempting new crossover design is something I’d like to avoid for a number of reasons. That’s why I decided to mitigate the problem with a simple solution by using a resistor in parallel with the tweeter, which I soldered directly to its connectors. The value of 22 ohms seems reasonable for that purpose and now the current trough the coil is down to 3.52 Amps (see picture 3) which is exactly on the threshold. There’s a tradeoff as well - now the tweeter response is down with around 2 dB, but I don’t mind it. Actually, I think it’s even better that way.
Finally, I’ve measured the impedance of the speaker (picture 4) and you can see that its lowest point is around 3.8 Ohms at around 180 Hz which is also a reason for concern.
My question is whether the speakers with this final crossover pose a significant risk to an amplifier. Is the small adjustment with the resistor in parallel enough to effectively alleviate the problem and bring the current to more reasonable (not harmful) level.
I hope my calculations are correct and I’m not missing something along the way.
I’d very much appreciate your input 🙂
-Allex
Novar base list?
Working with manufacturer to repop 9 pin PtoP and PCB Novar bases. What's in question is (as always w/ manufacturing) potential sales. Anyone know of online database that compiles tubes by base style?
Alternate plan is to go thru my B&K 707 tube tester chart & compile list of tubes that test on Novar socket, but this will only cover mainly North American tubes, and miss some of the Euro and / or Russia makes. I'm hoping to find worldwide database.
Jim
Mullard Stereophonic Amp LTSpice Model
The only way to get better at LTSpice is keep practicing and probing; these models will never get built. Sometimes, things don't work out, as in this case: I am getting 9μV output, clearly something isn't right. 😆
My brain is soggy due to being unwell, maybe missed something, can someone have a quick look over the schematics and see if missed something, please?
Here is the original schematic: http://www.r-type.org/articles/art-003f.htm.
Thanks in advance! 😀
PSB Stratus Gold & Goldi PORT DIMENSIONS & Specs
Does anyone have DETAILED dimensions of the port that is on the early '90's PSB Stratus Gold as well as the mid-'90's PSB Stratus Goldi speakers? I have an interest in modding the earlier model to the latter model. I have not verified (yet) whether internal cabinet volume had been changed between the two. Any related info would be greatly appreciated.
Troubleshooting blown GK amp; 120hz + voltage on output
Trying to troubleshoot this GK amp (schematic attached).
Found three blown transistors (Q2, Q3,Q7) and replaced them. All other transistors seem to test good. Replaced the filter capacitors.
When the amp is powered on, it produced a loud hum at 120hz. There is 48v DC voltage on the speaker output. This would indicate blown power transistors (Q4 & Q8) right? I had a replacement for Q8 and put that in (no change) and Q4 also tests good.
What else can this be, given the voltage on the speaker out? I ordered a replacement for Q4 but don't expect it to work since the incumbent tests good.
Require ALPS 50KAX2 Potentiometer for Sony WALKMAN D6C
I have been restoring my Walkman D6C that i picked up at local vintage store.
However to my bad luck the record level pot is broken and only one channel is working.
Rest i restored it to full working condition.
Sony part number: 1-230-275-11
This pot was custom made by ALPS for Sony D6C.
I saw the eBay ads for RK16 50KAX2 but as per datasheet it wouldn't fit the PCB. Any leads as to anyone who has older stock of sony spare parts/repair enthusiasts.
Any input regarding this is greatly appreciated
Thanks in advance.
How do you assess & test the result for your DIY passive filters on the speaker?
Are finetuning my MTM passive xover in the current room and in the actual baffle.
The midranges are Audax HM210Z10 in about 16 liter each and the tweeter is a Mundorf AMT29CM1.1
Xover-points are around 340 and 1900 hz ( have active filter for woofers under 340 hz)
Have made 2 different xovers with slightly different values on both coils and capacitors, & both with & without resistors.
I think it´s so hard to judge the result when you listening in mono, and old amps often have "balance-button" so you can go from right to left easy but mine haven´t.
So i have to connect one MTM at the time, and go to the speaker and disconnect and connect the other to shift.....Not good!
And feels that it makes it more difficult because my MTM works from 340 hz.
I'm hoping for some advice on two aspects of this process.
The first is simply this: What do you listen for when you've put together a new DIY passive xover?
For example, do you listen to the speakers separately or together?
And how are you looking for ways to refine the result?
With woofers connected or not?
In "sweetspot-sofa" or right in front of the speaker?
Have you a favorite curve, and how does it look like ?
For an exemple i post a pic on the 2 different passive xovers mesaurements (that i listening on), but so hard to analyze/judge the sound i think
Best regards John/Sweden
For Sale Normundss input and switch boards for the dam1021 dac module
Hi dear diyaudio friends
For sale is a set of Normundss input and switch boards for the dam1021 dac module. In another thread I'm also selling DAM1021 modules.
The input and switch boards are brand new and partly assembled by Normund.
The set includes:
DAM1021 assembled input board V2.3
DAM1021 input board balanced connectors
DAM1021 assembled switch board V2.3
DAM1021 assembled muting and output board V1.1
DAM1021 muting board balanced parts
Raspberry Pi 2/B+ connector for DAM1021 input board
I will only sell the complete set.
Price is 100€
I’m also willing to trade for one or more of the following items:
(Of course, I will pay difference in value)
Manufacturer sealed bags of:
2SJ74-BL
2SK170-GR
2SJ74-GR
2SK370-BL
And maybe other rare signal JFETS or dual JFETS
BurrBrown PCM1704-K DAC chips
Analog Devices MAT02 and MAT03 dual monolithic transistors
2 x Starkrimson® Ultra Amp Module
XRK Audio RTR TPA3255 Reference Class D amplifier
Please also take a look at my other offers in the Swap Meet
Here are some different shipping rates:
They may differ a little from country to country, for a exact quote for your country please ask.
Of course, I will charge only the prices I will have to pay)
(Prices for bubble wrap envelopes are valid for most countries worldwide, DHL package prices are a bit cheaper within Europe)
Bubble wrap envelope up to 500 grams (Deutsche Post):
Without insurance and tracking: 3.70 Euro
With insurance up to 30 Euro and tracking: 7.20 Euro
Bubble wrap envelope up to 1KG (Deutsche Post):
Without insurance and tracking (Deutsche Post): 7 Euro
With insurance up to 30 Euro and tracking: 10.50 Euro
Small DHL package worldwide (up to 2KG):
Without insurance and tracking: 10.99 Euro
With insurance up to 50 Euro and tracking: 14.99 Euro
Small DHL package within Europe (up to 2KG):
Without insurance and tracking: 5.99 Euro
With insurance up to 50 Euro and tracking: 8.49 Euro
Shipping within Germany will be cheaper, please ask.
I will ship anywhere in the world. Shipping costs strongly depend on the number of capacitors you are going to buy and which shipping method you prefer. Of course, I will only charge the real costs, I won't charge anything for packing materials and effort. I prefer to use Deutsche Post/DHL, but you can decide which shipper and which shipping method (letter, registered letter, small package, normal package, insurance, tracking) I should use.
As payment method I prefer PayPal for friends and family, so no extra fees will be added. Of course personal collection of capacitors in Cologne and payment in cash is also possible.
Kind Regards
Phil
InterM R500 Plus locked on prot. mode
Hi!
I've got an InterM R500 Plus amplifier which shorted due to condensation and now I'm trying to troubleshoot and fix it. The protection leds are on, channel 1 signal led is on and both clip leds are on. There is no sound.
First things first - I have only a very limited idea of what I'm doing so hoping for sincere help. I am very interested in fixing the amplifier, not because it's so worth it, but because that's my way of learning.
There were 4 resistors burned out when I opened the amp, on the output board (R501-504). So that was the obvious problem. But after changing the resistors, the problem remains.
I've measured the DC offset - channel 1 it's 69.5V, channel 2 it's around 10mV. I also measured the output of the amplifier board on channel 1 and it's the same.
Where to go from here? What and how should I measure?
Thanks!
suggestions for simple headphone amp (OPA1688 / 1622)
Hello everyone, I need to design a very low noise headphone amplifier with the following characteristics:
headphones: Vic Firth Sih2 datasheet
Sound pressure level 102db +/- 3 db (1mw at 1kHZ)
maximum power 100mw
Impedance 32 ohms +/- 15%
Conditions:
  1. The circuit is powered by a single 9V battery.
  2. Candidate ICs: OPA1688 or OPA1622 (I read suggestions)
  3. the input of the amplifier will be connected to an AD9833 (Programmable Waveform Generator IC) datasheet
my questions are:
can these ICs work with a single supply (9V Battery) ?
Can they reach the maximum power of the headphones? I need to at least reach 110db SPL
I have already tried with different ICs, (TDA2822, TDA7052, PAM8403) but the result is very noisy, mainly white noise and RF noise in some occasions.
I have a EARS Headphone test jig from miniDSP, to do the tests and measurements Link
I really appreciate your comments and suggestions.
Leonardo
For Sale Best Soviet audiophile tube rectifires and double triodes
I offer the following items
VO-188 ( = RGN2004 ВО-188) Soviet Audiophile Rare Rectifier Tubes / years 1950s / UNUSED/ 12pcs 45 usd/ea
5C3S ( = 5U4G 5ц3с) BLACK PLATE ANOD Soviet Audiophile Rectifier tube /years 1960-1961/ UNUSED/ 6pcs 35 usd/ea
6N9S (6Н9С) = 6SL7 = 1579 MELZ Metal Base Soviet Audiophile Double Triode /UNUSED/ 2pcs 50 usd/ea
6N8S (6Н8С) = 6SN7 =1578=ECC32 MELZ Holed Anodes Audiophile Double Triode / UNUSED/ 2pcs 150usd/ea
6N8S (6Н8С) = 6SN7 =1578=ECC32 MELZ Smooth Anodes Audiophile Double Triode / UNUSED/ 2pcs 100usd/ea
Getting some fancy bluetooth headphones.
My daughter is sending me a Senheiser over ear headset.
Its supposed to support aptx support. And all the latests bluetooth codecs. How would I test or quantify the improvements in bluetooth. As in what tests would I have to run. What data to collect. Im in the process of testing as many china modules as I can. Some are really good some not so good. Right now I measure the freq response to see if its flat. If its not I measure the response curve.
I also look to see if sine wave at various freq comes thru undistorted. What other tests can one do ?. Id like to test the improvements in Aptx and Ver 5. Then make a call if its worth paying extra for these modules to use in my builds.
How does Tangband measure Xmax?
I was thinking of buying a pair of Tang Band W5-1138SMF to use as midbass drivers for my desktop speakers.
They claim 9,25mm of xmax, but nowhere does it say if it is one-way or two-way or by 70%Bl or by 50%BL.
Does anybody know how they measure it?
I also found Omnes audio SW 5.01 that looks similar but has one way Xmax of 7mm, which is either more or less depending on Tang Bands way of measuring.
Defective Definitive Prosub 100TL
Hi all,
I discovered, during the week, that one of my Definitive Subs had stopped working. I rarely use them unless I'm watching DVDs these days, so the fact one had stopped working, wasn't recognised. I have 2 such subs and I use them as 'stands' for my Paradigm studio 40s in a 'quasi' home theatre setup.
I have opened up the sub and done a few rudimentary tests:
  1. The 'Auto on/off' light continues to glow whether or not there is any input signal (it's supposed to turn the internal amp off in the absence of any sound)
  2. I measured the resistance of the 10 inch subwoofer and it's at around 40 Meg Ohm...
So it looks like the speaker is history (it looks pristine, no visible damage).
On the main PCB there are a pair of circa 3W resistors that become very hot when the AC power is applied. 2 adjacent resistors (1/2W) show signs of overheating as does the junction between the 3W resistors.
Unfortunately in SA we have had 'load shedding' periods for years where we have/don't have power. These have become extreme over the last year or so with only circa 16 hours electricity available over the course of a day. The timing of these 'outages' varies from day to day (as they are 'rotated') so switching electronics on and off when the power is expected to go off/turn on, is not a sensible approach. Thus these subs have remained on and have been subjected to the power availability (there's a large 'thump' when power is restored - at least when the sub is working).
  • So the question arises as to whether to; purchase a new driver and carefully check/repair the electronics
  • Scrap the lot and buy a new subwoofer
  • Build a new active subwoofer and use the existing sub chassis/box (I have a 'spare' stereo 50W amp I could use as a driver in bridge mode I guess).
  • Build a passive subwoofer together with an analogue crossover and volume control, using the existing chassis/box
P.S. I'm more 'into' music than I am to surround sound.
Suggestions, pros/cons, appreciated.
For Sale DIY Audio Chassis components....300mm baseplate and a few riser panels
SOLD
Asking $15 plus shipping
I have a few chassis components for Deluxe or Dissipante type chassis that maybe someone can use.
1- 260 360mm baseplate for 300mm deep chassis, unused with mounting screws
1- 210 x 180 mm riser plate, unused
1 - 150 x 120mm riser plate, unused
1- 180 x 150mm riser with holes drilled, slight bends.
1- small 150 x 30 mm riser segment, used
1- bag of left over mounting screws, bolts and nuts for chassis kits, over 1 pound.
Shipping weight will be about 8 pounds and I will make up a container about 18 x 14 x 2 inches to hold it all.
Anyone have a copy of sheets for K&K Cascode kits?
Hi all. I ran across these unused kits I had got from Kevin years ago, and realized any instructions that came with are long gone. I'm sure I could figure it out eventually, but I figured it was worth a shot seeing if anyone on here still had whatever data/instructions he sent with them. I've got a few of the smaller "Cascode", and a few of the larger "Large Cascode" boards.
Thanks for your time,
Loren
Crossover and time delay/offset, for horns particularly.
Crossovers for cone/dome drivers on flat(ish) baffles are pretty well understood.
Typically the physical layout issue is that the tweeter is a little too far forward on a flat baffle.
The tweeter can be physically moved back or a little time delay added to it in the crossover, especially convenient with a DSP crossover.
All well documented.
But almost the opposite issue occurs when horn mid/tweeters (assumed 2 way for simplicity) are used with cone woofers - the depth of the horn means the mid is delayed.
It is possible to push the horn driver forward to the woofer plane but this can be problematic - physically awkward with a substantial horn and a potential source of diffraction problems for the woofer.
It is possible to delay the woofer but this seems to miss an opportunity.
The delay of the mid would seem to allow a closer approach to a linear phase crossover but without any DSP step.
I have seen little analysis of this, there was a thread a while back but the OP seems to have lost interest.
"Quasi-optimal" crossover for high-efficiency loudspeaker system.
I read the Vanderkooy & Lipshitz articles referenced in the 1st post that supposedly prove the idea is unworkable.
A closer study shows that certain assumptions in their analysis are too restrictive, a practical solution may be possible after all.
It will require asymmetric crossovers for the HP and LP, and probably non standard shapes.
I have found the maths a little difficult, presumably why V & L only looked at the simple symmetric case.
Anyone have any references or ideas on this?
I will start with an example.
Since we have a time delay an obvious candidate for the Low Pass would be a Bessel filter.
First is a Bessel LP, it has maximally flat Delay.
Second is a HP "Bessel" created by the usual method, the frequency response is mirrored.
But a Bessel is not about frequency response so this does not create a HP with maximally flat delay, as is obvious in the plot.
A closer match would be a HP filter with maximally flat delay.
Anyone know what this is called or have a reference so I don't have to create it from scratch?
David
Lower than normal impedance in vintage speakers
I got a pair of vintage full range speakers. I haven't tested them sonic-wise as I want to build cabinets first to have a thorough evaluation of the sound.
The units are visually in good conditions, but the Ohm meter reads 5.2÷5.3, while they are rated for 8 Ohm.
Shall I expect any quality degradation from this lower impedance?
Thanks,
gm
What to do with Beyma 12P80ND drivers
Having had a pair of 12P80nds gathering dust for the last 6 years - i have been pondering do i use them or sell them. I saw this speaker over the weekend which got me thinking
https://www.abacus-electronics.de/produkte/aktivlautsprecher/oscara/oscara-212.html. I have a pair of TPLs , the 12P80nds and some seas subwoofer drivers all spare that could be used. The challenge with AMTs has been integrating them with other drivers. The 12P80nd was meant to be a good match, but i didn't like it when i tried them in a simple box a while back. So could the answer be trying a different box....... I know some will shout out dipole, however if you use the TPL's open baffle, they are bipole not dipole and you get some horrible interactions, from my experience mixing dipole and bipole.. So i was thinking monopole upto a 1000hz and then bipole or hornloaded TPL's above that with higher DI, if needed
So how to best use the 12P80nd... well i was thinking a terminated transmission line - so will effectively get a infinite baffle response. I modelled a logarithmic spiral as a first pass, not the most efficient use of cabinet space. Am i right in assuming that as the driver will only be covering frequency's up to 1.5k smoothing out features smaller than a wave length wont add much. I have the CNC so can make what ever shape of transmission path i like.
To manage the beaming of the 12" drivers i was thinking of trying something like this first to see if it works that well I have some 12mm Perspex to make a test waveguide.
Need opinions and help on modifications
Hey guys need your help I have a little Dot MK 2 headphone /preamp. What I want to do is I'm going to take it out and put it in a different case I don't like the chassis that it's in.
Since I'm taking it apart what I want to know is based on the photo are there any audio upgrades I could do to this film capacitors coupling capacitors something like that you guys think would make a sonic difference in the amp?
Altec 802 Trade
Looking to trade a fine sounding/looking Altec 802D driver that reads around 6.2 ohms DCR for a Altec 802C or 802B driver
that reads over 8 ohms. Will consider buying an 802D under 7 ohms DCR.
For Sale DX25+WG300, Tectonic BMR, Peerless Woofers
I'm looking to offload all my current drivers I have and hop out of the DIY space. It's been fun, I've learned a lot, but it's turned into a frustrating money pit of unfinished . I understand I am not a frequent user here so if anyone needs verification I have a reverb account with a perfect seller rating and lots of sales. Just ask and I'll shoot you the link.
DX25+WG300 - $40 shipped.
Tectonic BMR TEBM46C20N - Just cover shipping.
Peerless 160f25 woofers
Programming QCC3034 BT AMP circuit
Hi guys, i put this question in here because of this good thread CSR8675 programming guide w. software and tons of CSR info and have in the past edited a few CSR chips, but prefer the QCC3003/3005 boards. Normally ill use my CSR\USB programmer and connect to the board with a Pogo Pin clamp and then change the name of the BT and edit the DSP\EQ settings. Recently i grabbed the QCC3034 board shown in the Aliexpress link
but cannot figure out what the N, P, P, V and G relates to the programmer and if i can use the Unviersal front end and APK tools like you do with the others?
I would really like some assistance if available as this amp seems to have 8watts per 4 ohm driver where my other QCC3003/5 boards only have 5 (onced boosted to 6.5v)
Retirement project
Now that I have more time, I decided to produce this amplifier.
Laid out the P.C.B and made them myself.at home.
I still need to fabricate. a couple of heatsinks for the bridge and the driver transistors.
When I have done this, I will wire everything into a temporary case and test.
Looking forward to this so far it has been very satisfying to return to the audio hobby.
Technics SU-A900MK2 overloaded/amp not working/nothing burnt
Hi!
few years ago my son unfortunately overloaded Technics SU-A900MK2 amp, full volume on 2x 100W 4ohm speakers... This exact device was in 2 service shops and both told that it has faulty AMP and it's not worth it repairing so they put their hands away from it.
AMP "does not amplify", it just leaves the sound that comes into the AMP
I haven't seen any burnt transistor, shorted capacitor or burnt route on the PCBs, relays do turn on so the protection is fine
the 2 power modules - SVI3205B + RSN6000B seems also fine, zener diodes checked with multimeter, nothing weird 🙁
RSN6000B does have a power transistors which can be purchased from link below - 2SJ338 + 2SK2162
https://www.ebay.com/itm/192202054620
17.2V rail does provide 17V
Q751 + Q752 are quite hot -- they wobble so the solder is melting
I will try reflowing the PCBs, desoldering the transistors and checking them.. in best scenario I wish hopefully the transistors inside the RSN6000B are faulty and nothing else 😀
Does anyone had a similar issue with Technics AMP ?
Schematics included in the attachment
Thanks a lot for your thoughts!
  • technics_su-a900mk2_sm_1.pdf
How to use subwoofer apart from speaker? Logitech X-230
I have a Logitech X-230 system, I don't want to use the X-230 sound system speakers because my laptop speakers are of better quality, I just want to use the Subwoofer. But the problem occurs here. Because using the subwoofer system to use with its own speakers. So it doesn't work alone. I drew the program of the system. More or less, if my hand holds a soldering iron and a tool, it can be seen if it can be explained. I did not cancel these speakers. I want to connect the subwoofer to the laptop and use it only as bass, how can I see it or is it possible? I am sending the subwoofer's circuit and system diagram attached.
Forgive me if my english is bad because i am not a british or american citizen 🙁....
Can I use this power supply for both +/-15v and 9v?
I need to power circuits that use different voltages at the same time, +/-15v for a stompbox adapter circuit, and +9v for several guitar pedals, and led dB meters. Can I use this power supply splitter with a voltage divider in parallel after the +15v to get +9v, and then wire grounds together? Also, how much current should the 30v dc wall wart be rated for to power everything?
Pass Labs X5 Buzz/Hum
This is my first post, so please be gentle. I’ve got a beautiful Pass Labs X5 that is the backbone of a mixed use Stereo/HT setup. The stereo side drives two channels from an Adcom GFP-750 and the HT side uses the other three channels for my front soundstage being driven by an Onkyo RZ50. I love the aesthetics and sound of the amp, and plan to gift it to my son as an heirloom.
The problem is, it audibly buzzes, and that same buzz comes through the speakers if you get within a foot or so of the speakers, and it’s driving me insane.
I recently had a friend and very competent tech go over the amp, and replaced the main filter caps as a possible solution. We also used some dampening material to try and isolate the toroidal transformer from the case. Neither of those things made a difference.
At this point, I’m wondering if there’s anything that can be done? New transformer potentially?
Hoping a community member, or Mr. Pass himself will be able to assist.
Thanks.
Armstrong 625 diagnosis
Hi all you Armstrong fans. I've acquired an Armstrong 625 with no sign of life and am in the early stages of repairing it. Would really appreciate some guidance on diagnosing the fault(s) and the following symptoms:
I have replaced the main reservoir cap and the 2 DC speaker caps. I now have power, lights on the dash;
I get audio from both L & R speakers 1 and 2, plus each side on headphones.
However - audio is ONLY with TAPE input, and this is low/moderate output volume (even with the Volume turned up to full);
No output from AUX or DISC inputs, and no TUNER output from the onboard receiver;
The output from the tape input continues regardless of how the Selector is set - ie selecting another input makes no difference and the output from the tape continues unaltered;
The backlight on the Tuner dial and Armstrong light illuminates, but the receiver does not seem to pick up an FM signal, and the red stereo light never illuminates. I've tried attaching antennas to each socket.
When playing a signal through TAPE, Treble and Bass dials don't affect the sound, nor does applying High and Low filters.
All the solder connections look and feel sound, and no previous repairs have been done. I needed to replace the original large caps, as above.
My thoughts in summary are that while the PSU and Amp seems to be working on both channels, it seems that the Inputs are not being selected and connected properly to the Amp (A17). However this does not explain why the receiver seems unresponsive - this may be a separate issue.
Any thoughts on where I should look and poke next, please? Many thanks in advance!
LED Mounting
I'm planning on mounting 3 X 5mm LEDs in a panel utilizing the recommended mounting fixtures shown. However the LEDs have a shoulder around the base preventing sliding the LED into the barrel and the strut inside the mounting barrel prevents sliding the LED into the barrel from the back.
I could trim off the shoulder of the LED if that won't compromise the LED or try and trim/grind out the strut inside the barrel. What would be the best course of action?
The website for Newark seem to indicate the mounting barrel is compatible with those LEDs.
Lundahl strap change
Has anyone noticed how a couple of years ago Lundahl changed from a ferrous to non-ferrous strap. Personally without science to back me up I always thought the ferrous strap not a good idea. Lundahl must have thought so too. I'm assuming they must have had a reason. Anyone know why they did it? I don't recall it ever being mentioned anywhere. Or perhaps any other anecdotes on shrouds etc.
New:
Old:
Please help me decide what to build
I have a stash of wonderful wood that is suitable for building speakers or fine furniture. I have so many tools like saws (including table saw), jigs I only used once, a hardly used router and bits, etc. plus a motivated helper. It seems wrong not to build a speaker.
My goal is to build small speakers that are suitable for use with or without a subwoofer. My emphasis is on clear midrange, high output, and low distortion.
I'm looking at two drivers right now. Feel free to make another suggestion. I love this driver on paper, been itching to use it for years. https://www.parts-express.com/FaitalPRO-6FE100-6-Professional-Woofer-8-Ohm-294-1150?quantity=1 Also this driver https://www.parts-express.com/FaitalPRO-5FE100-5-Professional-Woofer-8-Ohm-294-1140?quantity=1
Using this calculator https://www.diyaudioandvideo.com/Calculator/SpeakerBoxEnclosure/ the first driver returns a vented box volume of 1.3 cubic feet. That's bigger than my 8" two-ways. I suspect if I build this it will be a wonderful speaker, studio monitor quality, but maybe too big.
This is where my limited experience takes me. Would it be worthwhile to "cheat" and configure a smaller box? The 5" midwoofers would probably fit the bill just fine (crossed @ 100 Hz) but the 6" drivers seem (on paper) to offer so much more, so fudging might be a good strategy - and this is where I need advice.
I'll look at other drivers etc (not too expensive) or advice on alternative strategies (passive radiator etc). Thank you!
Windows 10 media streaming issue
Hi there, I have been playing with Windows 10 built-in media streaming service. My music files are in the shared Music folder on the Windows 10 PC. Another Windows PC on the same home network can play those files without any issue. For the playback I use Windows Media Player on the other PC.
The issue is that my music does not play back on an Android phone, using BubbleUPnP. I can see the Windows 10 machine as UPnP/DLNA library, but can't see the contents of the Music media share.
For comparison, I have a NAS with shared music folder, and I can play back all music on Windows or Android from there without any issue.
Why am I unable to browse and play music files from a Windows 10 using a smartphone?
PA amplifier question about hookup
Greetings,
we have a pyramid brand PA amplifier with auto mic talkover which we use at our factory. We moved to a new facility and upgraded to a bigger wattage unit, but it started making a horrific noise.
Anyhow, I put the old PA amp in place, and it works fine but it is not very loud because the wattage is significantly lower. I had tried to buy a replacement with the larger wattage but they were very expensive at the time and hard to find. I ordered one from the internet and they sent the wrong item etc.
Anyhow, long story short, and simply put - Can I run the output from the functioning amplifier with auto talkover into a less fancy but higher wattage amplifier to maintain functionality but increase our volume?
We are using 70v style speakers with it. The way its rigged up is our phone system has an optional adaptor that you can connect to speakers and call an extension to page out, so when we moved i sprung to get sirius xm radio for the shop and some nice speakers with the intention of dual purpose of paging and entertainment
SV S1616D Build Questions
First, thanks go to Victor for getting the kit to me so quickly. Your customer service is always top notch.
When I first got the kit, I thought I bit off more than I could chew. But I have gone slowly. Despite that, I caught at least two wiring mistakes during final review and sorted them out prior to applying power.
I have powered it up and nothing has exploded or caught on fire. So far so good.
I am posting my voltages below. As you can see, most everything looks within range. One of my concerns is that I have roughly about a 15% imbalance between the two 12au7s.
Is this a concern? If so, where do I start to try and track it down.
I haven’t tried any music yet to see if it actually works yet. I’d like to sort out the above prior to buttoning it up.
Looking to repair a Feiler TS-9 Electronic Vacuum tube Volt-Ohm-Milliammeter
Evidentially it was offered in a factory wired form or kit form. I would like to find/buy the kit instructions and or schematic for this unit. I can't seem to find a schematic or any information other than it was made in 1950 was offered wired for $48 and in kit form for $22. Its quite nice for its age and with some rewiring and tweeking the 4 pots I would be able to bring it back to its former glory or at least good enough so I can use it on circuits in old radios and such. Any help would be appreciated. More than willing to buy the information that I need.
For Sale SB Acoustic DIY speakers
For sale my DIY speakers that I own for more than 6 years. Cabinets were made then, but I upgraded with SB Acoustics drivers about two years ago. Match made in heaven.
Drivers are: SB Acoustics SB15CAC30-4 midbass, SB Acoustics Satori TW29B berilium tweeter and SB Acoustics passive radiator.
Dimensions: 200 x 305 x 315mm. Veneer is American walnut 2.5mm thick. Front is Corian (Solid surface).
Crossover is LR2 with Jantzen Superior capacitors and Jantzen WAX foil inductors. They are 4ohm with 88dB sensitivity.
Selling them with FBM Rondo speaker stands.
I spent about 2000€ on them when I purchased everything and for the enclosures. Selling for 1100€.
Time to move on to different projects with bigger drivers and 95+dB sensitivity.
Location Croatia!
Visaton B200 - foldable Open baffle try
Hi there !
I got a pair of Visaton B200 for my first try in building speakers. They will be powered by a tube amp 2x8watts : Elekit-Tu 8200.
My room is 20 x 23 feet (more or less) and 7,5 feet in height (with wooden beams on the ceiling)
I want the panels to be foldable, for obvious reasons.
This idea is coming from french internet site exploring accoustic : https://www.petoindominique.fr/php/plandesign.php
and has been realized by Christian . Size is about 3 feet high and 4 feet wide.
This one'a got two drivers but my will is to keep an only full-range driver
My first question is about the phase plug on B200 : where can i get it ? is it DIY ?
Second question : Dominique (see link above) says full range drivers absolutely need a correction in the medium curve and he propose to add a resistance (between 3 et 30 Ohms) , a self ( between 0.5 et 2.5 mH) and a capacitor (1 , 5 or 10 uF). Did anyone made any measurement with the B200 ?
CSS SDX10 versus Seas L26RO4 in a ~1 cu ft sealed enclosed with dsp- swarm (4 sub system) ?
I have looked into drivers for a 4 sub swarm-like dba system and have come across these two drivers as high quality options. I am looking for mid 20Hz to ~80Hz performance band. I plan to use dsp crossovers, correction, etc. to pair these with 1 AE dipole 18 in an h frame per side from 80Hz to roughly 300Hz, then ribbons above. Which of these drivers would you choose and why? Thanks...
Looking for a McIntosh 4100 FM left channel integrated chip - IC702
I have a McIntosh 4100 receiver that works perfectly except for one thing. When in tuner mode, in stereo, the left channel doesn't work. I consulted with a national McIntosh expert and he suggested the IC chip for the left channel was bad. The chip number is IC702 with McIntosh part number 133-037. Does anyone out there have or know where I could acquire this part, to fix the minor FM problem? I'm not a technician, but if I could get the IC, I'd bring it to someone.
Unbalanced RCA to balanced converter buffer with variable gain adjustment schematic - can I add signals like that?
Schematics is attached.
I am wondering if I can add two signals coming from RCA inputs and XLR inputs? Will something like what I have makes sense to do in order to support both unbalanced and balanced inputs? I am trying to avoid to switch them with the manual switch.
First stage allows for gain adjustment.
Bias resistors R3, R4 were selected at 10K to set input impedance. Feedback resistors can be 15K or 47K and determine R3 and R4 values as 15K||47K = 11.3K and 15K||15K = 7.5K.
Second stage is balanced signals driver.
Unity buffer for the positive swing signal. Inverting unity gain opamp for the negative swing signal with bias resistor = 2K||2K = 1K. Current sharing resistors of 100R at each end to adjust for offset differences. Output signal doubles in value which is what I want. For example Topping DACs have 2Vrms output level for RCA outs. I will need to double that to drive my next stage at the amplifier end.
Balanced input stage is two impedance matching buffers to be able to drive the next stage at the amplifier end wich has input impedance of 1K.
I am assuming that connecting both RCA and XLR inputs at the same time and play music at both sources will add those two signals together and I will hear both sources?
Each opamp has decoupling capacitors, but those are at different sheet for schematics.
Any suggestions will be appreciated.
Best way to wire up 4 individual subs to a VTV nc1200 amp?
I want to use these 4 independent subs in a swarm like distributed bass array with dirac bass control dsp. I am told the dirac dsp will only work with mono subs so I am wondering how to connect the 4 subs to the VTV nc1200 stereo amp. This amp has one channel inverted to avoid power supply pumping. Can I bridge the nc1200 and simply run a wire from the + on one channel to each sub and a wire from the - of the other channel to each individual sub? The subs are 4ohm each and the nc1200 can handle 2ohm loads unbridged so 4ohms should be ok- if I put 2 sets in series, then those two sets in parallel, I should have a 4 ohm total load. Is this the way to go? Thanks.
Raspberry Pi and AK4399 and Amanero
Hi All,
Returning after years and having forgotten most of what I knew! I was running the originl Raspberry Pi with a Hifiberry Dac hat. I have kept this going with sellotape and sheer will power for too long. I've given in and purchased a Raspberry Pi 4. I have not bought a Dac hat for it (Yet)
I would like to see if I can repurpose another project - A chinese AK4399 based Dac that had an Amanero board connected via I2S for USB input from a Linux PC
I have no PC now and would like to run Volumio on my Pi 4 as music source. My question is -
How will I connect raspberry Pi4 to my AK4399? Directly by I2S or via USB and Amanero? I have some parts lying around to make a smooth 5V supply and intend to place the Pi in the box with the Dac as shown in pic. Any suggestions welcome!
Projects by fanatics, for fanatics
Get answers and advice for everyone wanting to learn the art of audio.
Join the Community
507,815
Members
7,889,588
Messages
Filter
Forum Statistics
Threads
406,305
Messages
7,889,588
Members
507,815
Latest member
ezemattaldi
