Looking for a McIntosh 4100 FM left channel integrated chip - IC702
I have a McIntosh 4100 receiver that works perfectly except for one thing. When in tuner mode, in stereo, the left channel doesn't work. I consulted with a national McIntosh expert and he suggested the IC chip for the left channel was bad. The chip number is IC702 with McIntosh part number 133-037. Does anyone out there have or know where I could acquire this part, to fix the minor FM problem? I'm not a technician, but if I could get the IC, I'd bring it to someone.
See if this helps.. Best way in these cases is to buy the part from them.
  • semiconductor_data.pdf
Thank you BenY. I'll keep that in mind when I get a repairperson to look at the receiver. In the past I've had every reputable shop in Portland (OR) look at the problem and none of them could solve it. I spoke with Terry DeWick on the phone and he was the one who suggested it might be an IC chip. He didn't know which one. I looked at the parts diagram and guessed at it. I am NOT into audio repair.
To RJM1, I did look at post 7 from your first message and I didn't understand how it applied to my problem. I also looked at your second suggestion and I didn't understand that discussion either.
To stocktrader200, I don't do repair work so shorting outputs is not something I'd even try.
Thank you all for trying to help.
