Any tape reel can be loaded just by holding the end of the tape down against the hub and rotating a turn or two until there is sufficient friction. Then you don't need to hold the tape any more; to cue it up, just rotate the reel to pull the leader or tape a bit further through the playback path or push play and let the machine do it.
Threading into the slot is not at all necessary unless you prefer the look of a strip of tape hanging out. You may not find it easy to manipulate it with a pencil/stick either, without some practice. It doesn't do much to simplify loading. I think the hole is as much for placing you finger onto anyway: the tape is loaded entering the slot and exiting the hole at an angle, so you hold it in place by putting your finger over the hole.
