Simple circuit design question.
I have a pretty basic question...
I'm building a sub with 2 identical drivers that each have 2 ohm DVCs. So in effect I need to drive (4) 2 ohm voice coils. The amp I intend to use has these specs:
  • At 8 ohms: 215W RMS x2
  • At 4 ohms: 350W RMS x2
  • At 2 ohms: 550W RMS x2
  • Bridged at 8 ohms: 700W RMS
  • Bridged at 4 ohms: 1100W RMS
My question - what configuration will provide the best (highest?) power to drive this cabinet?
Nobsound power adaptor
I am looking for a 24v 6a power adaptor for an amplifier, I saw this Nobsound power adaptor that says its designed for amps and shows its guts. The guts show heatsinks as opposed to strips of metal. I dunno if that would be much better in a sealed enclosure like its in. They are 2 times the price of regular ones. Are they worth it? Anyone have any experience with this? See attached link and see the 3rd and 4th pic in listing.
https://www.amazon.ca/Nobsound-Supp...hvtargid=pla-1118254602954&psc=1&gad_source=1
Battery heated DHT (RE084) operating point
I'm entertaining a pre-amp using RE084 valves and supplying the heaters from a battery, using cathode bias. How would the heather supply affect the operating point? Or am I overthinking this?
I want to use the RE084 at a operating point of ~4V, 4mA, which would need a cathode resistor of ~1k.
Can I simply use two 2k resistors going to ground (one from each side of the heather), this would drain the batteries least as they are from the battery perspective are in parallel with the heather. The alternative would be two smaller ones, from the heater that go to a larger one to ground (for example 2*80 + 1* 960)
Furthermore one side of the heather would in this case be 2V and the other at 6V (the heather are 4V and assuming I have a perfect 4V battery) relative to ground/grid, would this affect the bias point? I could understand that with a higher cathode voltage (relative to grid) such as for a 45 or 300b this becomes more of an issu, but given the grid voltage
Thanks!
Matthew
Stereo console with DVC woofer design study
I am impressed with high WAF stereo console projects and want to make someday one for our apartment where the space is pretty limited. There are many of the design variants, but the one that I am leaning to is to have "kinda" 3 way design with shared DVC woofer and 2 mids + 2 tweeters. My shameless edit of well-know project:
The design objectives:
1. High WAF, of course
2. Single shared woofer with DVC, that will play pretty high, up to 400-600 Hz, as I am not worried about stereo presentation much, as there will be limited one because of pretty small c-c distance between mids and tweeters. The space is mostly limited in width. and with this setup I can still make pretty big BR box for woofer.
3. Distance between tweeters is ~1 meter at most, and ~0.8m between mids, or even less. Maybe SICA 5inch coax for combined tw-mid or SBA 4-5 inch NRX or PFCR and small 14-25mm tweeter-supertweeter.
4. Passive design, with normal 3-way stereo crossover(-s). Would like to avoid expensive capacitors, and still to stay with MKP/MKT, no electrolytics.
Right now I see that I am limited with driver selection as the single 10 inch class DVC woofer, that is not rated as subwoofer with 8+8Ohm impedance is Ciare HS251, there are couple 8inch 8+8Ohm from Audax and that is pretty much it. All the others DVC are Dayton subwoofers, mostly 4+4Ohm, which are not suitable for passive 400+Hz crossovers, also I am from EU, where the pricing of Dayton is not that attractive.
There are also an option to go 2x FR drivers with no crossover or the same DVC woofer with 2xFR as WAW/FAST 2-way, but right now full 3-way study is priority.
Also maybe there are other nuances, community brainstorm is very welcome.
General question and experiences with noise "distribution"
Hello,
i recently bought a Greenwave AC EMI measurement device and made some interesting observations while testing to find the best spot for the filters i wanna share and talk about
1. Noise searches the shortest path
this got specially obvious as in my listening room the AC comes in at the door light switch, plugging filters directly into the socket at the door reduces EMI levels in the whole room from that point on, where in comparison filters plugged into the last sockets of the circuit barely filter any noise, as the whole noise still travels down the whole line to the last socket
i guess this is only a really good tip if your main concern is incoming EMI from outside AC, as filters plugged between devices will effectively isolate the two devices somewhat noise-wise
2. Know your filters
Power filter with included 1/2/3 stage emi filter might not be "the solution" as these will not only block incoming EMI, but also block EMI that wants to flow out of the system, now if you close one drain the noise either searches another path or stays "floating" in the (with filters) isolated system
imagine following scenario i measured:
before power strip with filter with 2 greenwave filters : 400mV
after power strip with filter: 1600mV with PC running
after power stirp with filter AND and additional greenwave parallel filter: 400-600mV
i can really only explain the measurements like this:
the power strip filter essentially blocks noise in both ways making the devices after the power stirp somewhat "floating" noisewise, pluggin in one parallel filter gives the majority of noise again a path to flow out of the system trough the unfiltered ground connection
imo this is really important to understand, as i dont think its a good idea to only isolate a system without giving the noise a path to flow out of the system, making the issue potentially worse than it was
there are these filters that somewhat differeniate from your usual ones: https://auth-nt.de/produkte/netzfilter/adapter/1/netzfilter-emd-503?number=EMD503 in that they have also the ground connection fitlered, essentially really isolated all paths for noise, so even a parallel filter afterwards wouldnt help much
like i said before, not really sure if its a good idea to "contain" the noise
what i draw from this is that with your usual power strip you want to use parallel filters additionally, the power stirp filter isolated outside noise and the parallel filter gives the noise from inside a connection to flow out of the system trough ground path, to me it makes logically sense at the measurements i saw with the greenwave ac meter also support this but its really never talked about, so what do you think?
Reactions: indianajo
TDA2004 Bridge configuration, distortion/2nd harmonic?
Hello,
Recently started a little project where i needed a decent speaker output, so started researching some chip-amp designs.
I landed on a TDA2004 which was readily available from my "local" electronic store. Using the 2005 datasheet for the bridge configuration (the tda2004 datasheet does not have any, but cant really find reason why).
I attach the schematics from the datasheet for reference. Only thing i changed from it was adding a 10k log pot on the input, and using 56ohms instead of 12 to lower the gain somewhat. Should end up at about 38db instead.
I'm very happy with the sound from it, it turned out perfect for my project. Its enough fidelity, hehe.
However, of course I could not let it be, so I found some videos online about using FFT functionality of a oscilloscope to check distortion.
I got interested in this, not mainly for checking the amp as I know there are tons of other checks that needs to be done and as I said, I was happy with the sound.
I just wanted to try out FFT on the scope, as I have never used it before.
I got everything setup and using a .wav file with a 1% distortion added just to check that I'm able to catch that, and I was successful.
However, I did notice that I have a distortion on the 2khz that is about the same %. Now, it is not in fact the added distortion that is playing tricks here. That distortion is always present, no matter if i choose another 1khz "clean" file or even a function generator.
Did some reading, and I think "crossover" distortion can show up like this. So is this the reason? Can it be fixed on a amp like this? Or maybe is it even expected? I see that there is 1% distortion in the datasheet specs, but not sure if this is what they mean with that.
Please see the spectrum analyzer screenshot and the circuit attached.
Any ideas or other intel is greatly appreciated!
Voltage Display Replacement (DSN-DVM-368) on Zero Zone LPS-25?
Hi All,
I bought my Linear Power Supply secondhand. I opened it up and if the name on the board is indicative of the maker, it looks like it's a Zero Zone LPS-25. The voltage display has been dying for some time and I would like to replace it but I'm having some difficulty finding it. Anyone have one of these? DSN-DVN-368 v3.01.
I am definitely a novice when it comes this stuff, but my soldering skills are pretty decent. I used to mess around with R/C cars and I've built a couple ACAs, although I don't really comprehend everything I am doing since it's basically like a paint by number type of build).
At some point, I would like to learn enough to build one of these Linear Power Supplies myself and this display replacement is a start right? Any help is appreciated. Thank you!
* Alos, any tips of removing what looks to be hot glue?
Interest for another Omicron group buy
UPDATE 03/24/2025: this GB is now closed.
After the third Omicron group buy closed in June last year, there has been a number of requests for more boards, so I'd like to see if there is interest for another group buy for:
  • Omicron through-hole board;
  • Omicron SMT board;
  • Omicron power supply board;
  • Omicron headphone protection board (which is not necessary for the Omicron itself, as the same protection is already included, but which may be used with other headamps).
Pricing is the same as before ($15 per any other one board, except the protection board, which is $5), plus shipping. More details are below and in the main discussion threads (Omicron and Omicron protection).
If you're interested in any of these boards, please sign up below before end-of-day Sunday, March 23 by replying to this thread. Copy the list of those interested into your post and add your own line as follows:
(1) Your name here on diyAudio -- (2) Omicron TH board, pieces -- (3) Omicron SMT bare board, pieces -- (4) Omicron PSU board, pieces -- (5) Omicron DC protection boards, pieces, -- (6) Country to ship the board(s) to.
Try to preserve formatting.
Additional information
The following four boards (bare, unpopulated, parts not included) are offered in this GB, in any quantity you want and in any combination:
  • Omicron through-hole PCB: a 80x110mm, two-sided board that carries two amplification channels, optional crossfeed, DC protection circuit, and the output filter. All parts are through-hole and regular sized, so the board is fairly easy to build despite its compact layout.
  • Omicron SMT PCB: a 60x90mm, two-sided board that carries two amplification channels, relay-switchable crossfeed, DC protection circuit, and two output filters (one for headphones, one for line output). The board itself serves as a heatsink for the output stages. Most parts are SMT, but no parts are smaller than 1206 or SOT-23, so this board is also reasonably easy to solder by hand.
  • Omicron power supply PCB: a 130x80mm, two sided PCB that carries an AC mains filter, 230/115VAC mains voltage selector, a power transformer, a pair of regulators, and an quick-turn-off circuit that works together with Omicron's DC protection. This board is optional - you can power Omicron from other suitable power supplies - but it has been tested in multiple builds and works well with the Omicron.
  • Omicron DC protection PCB: a 50x50mm, two sided PCB that carries a copy of Omicron's DC protection. This board is not needed to build the Omicron, which already includes the same DC protection circuit, but may be used with other headamps. The quick-turn-off of this protection works together with Omicron's power supply board.
What it is
  • Omicron is a compact, inexpensive and easy to build headphone amplifier with very musical, pure, clean, liquid sound and perfect clarity even in the most harmonically complex pieces. As one of the first GB participants put it, "The clarity is surreal."
  • Designed to work with 32 to 600 ohm headphones and tested with a range of over-the-ear and on-the-ear cans from AKG, Beyerdynamic, Grado, Klipsch, and Sennheiser as well as with lower impedance 16 and 8 ohm headphones, such as AKG's K3003 3-way in-ear monitors; even white Apple EarPods (tethered ones, both 1st and 2nd generation) sound great with Omicron, too!
Features and benefits
  • Ultra low distortion; at -140dBc, Omicron is an order or two more linear than other "high-performance" and "ultra-high performance" headamps. Omicron adds neither dirt nor fairy dust, offering exceptional clarity and fluidity of sound. With Omicron and a good pair of cans, music just carries you away. And if you want to look at the measurements, we have them, too.
  • Simple and inexpensive to build. One channel of Omicron is built with just one dual opamp, two transistors, ans a bunch of resistors and capacitors. The circuit allows broad opamp substitution and has been tested to work well with many modern (e.g. OPA1642) and not-so-modern (NE5532) opamps. At the time of the first GB, the total cost of parts to build one Omicron board (two channels) was just $42.
  • Built-in fast (10ms) and sensitive (80mV DC) headphone protection.
  • Built-in optional cross-feed circuit, helping to create a more realistic soundstage.
  • Compact and easy to build.
Pricing
  • $5 per one protection board, $15 per any other one board, plus shipping.
  • Shipping is calculated at checkout. U.S. Postal Service offers inexpensive shipping to the continental U.S. starting at $3.80 (USPS Ground Advantage) with tracking or $1.60 (USPS First Class Mail) without. International shipping (USPS First Class International Package) will cost somewhere between $16 and $20, depending on the destination. Should you want to buy something else from me, I of course can combine shipping.
Technical details
  • The main thread has lots of details, including full schematics, part lists, board outlines, assembly instructions, and more. The first post in the main thread includes a list if links to most useful posts. I will review the thread in the coming days and update it as needed.
  • The DC protection has its own thread.
  • Part lists aka BOMs has been published for each board. I will update the BOMs over the next couple of weeks making sure all parts are available and any errors and omissions discovered so far are corrected.
  • We support Omicron builders in the main thread.
If interested in purchasing any of these boards, please reply to this thread. Copy everything below into your post and add your own line as follows:
(1) Your name here on diyAudio -- (2) TH board, pieces -- (3) SMT bare board, pieces -- (4) PSU board, pieces -- (5) DC protection boards, pieces, -- (6) Country to ship the board(s).
Running List for Subscription:
YourNameNere -- 1 -- 1 -- 1 -- 1 -- USA
This group buy will close on Sunday, March 23, 2025. Be sure to sign up before then.
The F5 Preamp 2024
As already mentioned earlier in the F5Pi thread, we have all the ingredients that will also make a nice Preamp.
It has taken much longer than we wanted, but it is finally playing music since yesterday.
www.diyaudio.com/community/threads/the-f5pi-f5p-voltage-gain-stage-m2-output-stage-perfectly-integrated.406024/post-7524606
www.diyaudio.com/community/threads/the-f5pi-f5p-voltage-gain-stage-m2-output-stage-perfectly-integrated.406024/post-7538379
www.diyaudio.com/community/threads/the-f5pi-f5p-voltage-gain-stage-m2-output-stage-perfectly-integrated.406024/post-7741027
As always, I don't comment on subjective sonic impressions.
I'll leave it to Fran to tell you what he thinks, when he has enough hours on it.
Happy reading,
Patrick
HIGH VOLTAGE OPAMP FOR TUBE INPUT/VAS STAGE
I am going to test a Texas OPA454 high voltage opamp to drive an EL34 in my SE amp. It's not a particularly quiet opamp but probably no worse than 6SN7 or 12AX7.
(what is the noise figures for these?)
I'll be initially usiing + - 36v switch mode psu with common mode choke on the output and gain will be 20x.
Comments please?
Reactions: mila
Output Capacitor Ambiguity
I restored a late 1960's Sherwood S-9500c a few years ago and recently found another that will receive the same treatment. Reviewing the service manual, schematic and original components in the amp, it seems I have a choice of using either 1500uF or 2700uF capacitors in the output stage.
The amplifier I restored has 1500uF caps and sounds very good. Would there be any benefits or drawbacks using 2700uF caps instead?
Attached is the service manual, Page 4 shows C290 (left channel) and C390 (right channel) as being either 1500uF or 2700uF. The schematic (last page) shows 2700uF.
Transformer suited for MC step up?
I have a set of these Jensen transformers and was curious if they would be useful for MC step up with a low output MC cartridge?
The winding and DCR ratios suggest a possible good fit for MC step up. Aside from shielding and FR linearity, is there anything else I'm missing from the equation which would define these transformers as being a good fit for purpose?
If this transformer isn't a good fit, does anyone have other good suggestions for reasonably priced, decent MC step up transformers which would play nice with low to medium output MCs? I'm running both the AT OC9/II and an older VDH MC cart. Both are low output units.
First DSP
I’m new to the site and looking at getting into DSP as an active crossover for my various DIY speaker builds. I mainly make 2-way speakers and am intrigued with using digital to replace analog crossovers. Looking for advice from the group. This strictly for home use and experimentation so trying to keep budget in mind.
Thanks in advance
High density fiberboard vs MDF?
Greetings. I know that MDF is pretty much standard for speaker cabinets, but I've been reading about high density fiberboard (HDF). I wonder if it might be superior to MDF. Because it's stronger, maybe thinner panels could be used? But maybe it's more resonant than MDF?
Does anyone here have experience with speaker cabinets made of HDF?
I'm about to start designing yet another pair. Any suggestions/ advice is appreciated!
Sony 07DAV-power-13-MP power supply error
Hello, please help me, I have a sony dav-dz830w home cinema, which does not start, I have disassembled it and I have removed the model 07dav-power-13-mp power supply.
I don't have much knowledge of electronics, but I started by checking the fuse and the transformers, and they gave me the correct values.
Later I checked the voltages with the power board outside the unit, I got the schematic in addition to the board to be able to check the problem.
When reviewing the voltages of the different connectors, I obtained the following values in the CN906, which I think is the one that starts the unit, I obtained the following voltages with respect to the ground of the connector itself or of the EB904, ground signal of this area, according to the wiring diagram the plate.
CN906
Pcont1: 0.01v
Pcont2: 14-15 v (oscillates)
Pcont3: 0.3v
E+4v: 4v
D+3.3V: 3.2v
6v: 8.5v
d-gnd: 0v
d+5v: 4.95v
m+8v: 7.8v
m+gnd: 0v
12V: 11.9v
a-gnd: 0v
On the Cn 903, I have these voltages:
Diat+12 = 11.8v
Diat+Gnd= 0v
In the CN 904 :
+31.5v=31.5-32.6v (oscillates)
+31.5v=31.5-32.6v
Gnd= 0v
Gnd=0v
CN907:
6v=8.5V
P-Gnd=0v
P-Com2=14-14,5 v (oscillates)
These are the values that I obtained with the multimeter, I assume that the CN906 is the one that allows the boot, since it gives power to the main board, the others are outputs for the amplification card, IR, etc.
My first question is if these voltages are correct, on the other hand if I put the power board in its place in the DAV unit with its grounds, I don't have any type of voltage on any of the CN906,903,904,907 outputs.
What can happen?, I have managed to get the service manual and the schematic of the power board model 07dav-power-13-mp.
But I don't interpret it very well, nor do I know what could be happening with this, my knowledge of electronics is limited, could someone please help me.
Thank you.
voltage doubler switching noise
Hello. I am using this for my preamp heater circuit:
I also connect that the output to an LM555 timer that activates a relay and all sort of jazz.
the thing is that i get some mishaviours because of this turn on noise:
if I switch it off and turn on again, looks like this, and everything works flawlessly:
any idea on how to reduce that noise?
is this because of the voltage doubler?
the diodes inside the BR310?
may be transformer inrush current?
THANK YOU!
Adcom gfa-5200 with slope of the square wave in the bass range
I love my GFA-5200, and it sounded great. However, I felt it had lost some bass, so I decided to completely overhaul it and replace all the capacitors. While trying to adjust the bias, I caused a short circuit, and the amp stopped working. So I replaced all the MOSFETs, diodes, and transistors on both channels and adjusted Q007 and Q008. All the replaced parts should be the same as the originals. Since I'm just an interested hobbyist electronics enthusiast, I'm not sure if I did everything correctly. The amp is working again now, but the square wave has a slope in the bass range. Is this normal, or is there a problem somewhere?
Can anyone help me find and fix the problem?
I've attached the schematics (I only have the schematics for the GFA-5200b; my unit is an older, simpler version) and the curves I measured with my oscilloscope at 40Hz and at 500Hz (blue is output).
Dave's 8" woofer + 104mm tweeter speaker build
Hello,
I am a little late in starting on my InDIYana 2023 build, I spent quite a bit of time testing drivers to see which ones would work best for what I wanted to do. For those who do not know, the Midwest Audio Club has an annual get together in Fort Wayne Indiana in April where one of the things they do is have a friendly theme speaker contest. This years is, Mix a =>8" driver to a tweeter <=104mm inna box <=1.5 cubic feet. My entry will be a Wavecor WF223BD01 8.75" woofer, Seas Prestige 27TBCD/GB-DXT tweeter and Dayton 10" passive radiator in about a 1.3 cubic foot box, about 21" tall, 15" deep and 12" wide.
Enclosure front/back/top/bottom will a pseudo translam with me making translam panels then butt joining them with a lock rebate joint. The baffle itself will start out as a 3" thick panel, but more than half by weight will be removed from it by the time the enclosure is done. Top/bottom/back will be ~1.125" thick panels with the sides being regular 3/4" baltic birch panels with ~1/4" cherry thick veneer applied to them.
BTW, I am soliciting name suggestions for this build, so please suggest some!
Levinson 31.5 Power to the lid Motor DC voltage
HI Everyone,
I have a Levinson 31.5 Transport that was working beautifully. The motor/gear for the close/open lid quit working. But it still plays CDs.
Maxon was the motor/gear OEM. I contacted them with the gear number and motor number. The told me that since the motor is 20+ years old
they could not cross reference this motor/gear any longer.
Please, I needing help finding the DC voltage. Or a spare motor. LOL
I believe when the motor stopped working, the power supple for the motor went out also. I am only getting about 2 to 5VDC momentarily when
I hit the open /close button over and over. I believe the motor is bad because I feed it 5vdc up to 12vdc and nothing happened. I tried rotating the motor
armature shaft with plyers and it will not move.
Any help would be greatly appreciated.
Thanks so much for you valuable time,
Tom
Burson Supreme Sound V6 Classic Opamp Upgrade for Music Hall 25.2 DAC
I just received some V6 Classics from Carlos at Burson/Supreme Sound. I reached out after seeing a thread on DiyAudio about offering samples and wanting to step my Music Hall 25.2 DAC up a notch or two. Big Thank You!
My Music Hall 25.2 DAC and ph25.2 Headphone Amp have been my daily companions while I work from home during the pandemic so they have been getting 6-8 hours of use daily and I feel I've become very accustomed to how they sound. Everything is stock aside from replacing the stock Electro-Harmonix tube on the 25.2 DAC with a Gold Lion.
Tube swapping was a great cheap and easy inexpensive upgrade for this DAC. The Electro-Harmoni stock tube is what I consider to be on the neutral and dry side. The Gold Lion adds a touch more warmth and romance and an additional sense of spaciousness.
So far I have about +- 20 hours of listening to the V6 Classics which replaced 2 X OPA2134 and 1X OPA2604.
One of the criticisms of this DAC is that it can sound a little rolled off and isn't the most revealing. For me, it's one of the reasons I like it. Prior to the Pandemic, I was mostly a vinyl/analog listener and really only used digital to search out new music on streaming services or on my daily commute to work. Since buying this DAC, I've pulled my CD collection out of mothballs and picked up a decent transport.
While this isn't a review of the DAC, the description of its character it is important because the biggest change I noticed right off the bat is the V6 Classic opamps brought so much more detail retrieval and openness to the sound that I was very surprised what I had been missing all along. I've been mostly listening with AudioQuest NightHawks and NightOwls and I find them to be a great example of the differences between the stock opamps and the Bursons. The V6 Classic is similar to the NightHawks in the sense that it's more open sounding with a bigger soundstage and a bit more even bass response, where the stock opamps are more like the NightOwls being more intimate and more bass-heavy.
Overall, I would easily recommend this upgrade for users of the 25.2 or 25.3 DAC. While it may seem like a steep investment for a $599 piece of equipment, it really takes what is already an overachieving product up to a new level. You can spend allot more and get allot less as they say!
Since swapping is so easy with this equipment, I'm going to give the V6 Classics some more listening time and then reinstall the stock opamps and report back.
Mixed impedance crossover wiring and amp load
Hello, I have been searching to no avail online to answer a question about impedance wiring, crossovers, and amp load. What I have are some very old 70's PA/Musician speakers that I use both for music on solid state amps and my guitar tube amp as well. These old Peavey speakers had a passive crossover that I am working to redesign and things have become a bit too complicated for me. Originally 2x 15 inch 8 ohm woofers in parallel back to the crossover (so 4ohm), 2x 45-ohm horns in parallel back to the crossover (so 22.5ohm) and 2x piezo tweeters which don't have an ohm rating back to the crossover. It's not a good design, and the tweeters im going a different route with which will match the woofers impedance, and I ended up putting in a single 4-ohm woofer instead of 2-8ohm's. I am also making different cabinets. Each bank of parallel speakers has its own signal coming from the crossover, and the negative terminal just daisy chains around all of the speakers. To me it appears that each bank of speakers effectively parallels all the speakers at the crossover. (All passive crossover design's are this way). Does that not mean they are all paralleled? I read in a few forums that speaker banks at the crossover do not parallel and the amp will see them individually so 4+22.5+4 instead of whatever the 5 speakers would be paralleled together. Is this true? can someone clarify how this makes any sense?
Now for the nitty gritty, 4+22.5+4???? okay so I have also read if you are mismatching impedance that you should use similar impedances. Well, those are definitely not similar impedances. The crossover says (4-ohm) on it but I think this (22.5ohm) may have been damaging my old Randall tube amp. Is this safe to run? What can be done? I don't want to wire resistors in parallel to drop the horn bank more, wasting power and heat, I would rather just completely buy new ones that are rated correctly. They sound decent and I have used them for 25 years on solid state amps with zero problems, but the math makes zero sense to me. So to go a bit further on my impedance question, for simplicity lets say my speakers are all 4 ohm 4+4+4 in each cabinet. Say I connect both cabinet's to left and right channels to my solid state amp. Does that mean my amp is then powering all these banks of 4-ohm speakers? would the two 4-ohm cabinets not also make paralleling and make both cabs 2-ohm total now? Its all very confusing to me. I really don't understand how the crossover which wires 3 parallel speaker banks in parallel doesn't do paralleling. I hope someone can help me I am confused. Thank you all!
Matching 6C33C-B tubes
I am wondering if anyone has tried matching these tubes, and if so are the results all over the place? I built a pair of monoblocks each using 4 tubes in PPP configuration loosely based on the Ciuffoli OTL v8.2 schematic. I have 12 tubes and am measuring the cathode current at 145v Anode and at -50 and -55v bias points. I have results at -50 ranging from 50ma to 245ma with clusters around 110 and 220ma. I am going to need probably 8 more to get 2 fairly matched quads. Surely for a military application they can't be this bad?
Tube clipping nube question
Hi All,
I'm LTspicing my first tube amp dablings. 300B fantasies. I noticed the following:
When the input signal on the grid exceeds the cathode voltage, the 300b output tube clips.
On the 12ax7 input tube however, the grid signal does swing past the cathode voltage. Which is correct? Is this supposed to happen or is this a modeling discrepancy?
Probably common sense to you. Yet I haven't found the answer. Perhaps you would like to point me to the obvious truth. Thank You!
Kind regards,
Ruben
Center Speaker with two or four drivers in a single enclosure
Hello, I would like to build a center speaker as a part of a surround sound system with two/four x 4" fullrange drivers. No tweeters and hence no crossover will be used. The drivers need to sit horizontally . Any tips for the distance between the two drivers? Will a sideways tilt enhance off axis seating experience? Will there be benefits if isolated enclosure is provided for each driver vs all the drivers sharing the enclosure volume? Thanks in advance!
Drive a piezo tweeter?
Hi all.
I have a modern solid state active studio monitor speaker that after 25y bit the dust in a glorious cloud of smoke (Behringer Truth 2031a) and was beyond me to repair, especially when it was cheap to replace.
The amp for this was based around 3 x 38w LM3886T. with a bi-amplified design for the woofer and "ferro fluid cooled tweeter".
I thought it might be a fun project and an excuse to read my Merlin Blencowe high fidelity tube amp design book to convert this in to a valve amplified speaker.
My first port of call was to check the impedance of the speakers assuming they would read 4ohm.
The woofer did but the tweeter did not register for resistance and measured a really small capacitance.
My immediate thought was that the tweeter had fried also, but my friend suggested it may be piezo based as they can read like this?
The cabinet is a sealed unit so I haven't inspected the back of the speakers yet.
Firstly, does this sound plausible, and if so how can I test the speaker? Would it be safe to connect it to a consumer audio receiver?
If so can this kind of speaker be driven by valves given that the anode load is normally a product of output traf and speaker impedance?
Lastly if this seems doable would anyone have any schematics or component suggestions I look at as a starting point?
trying to resurrect an Orion 2150GX after massive short
Hi everyone, as per title, I need some help in trying to resurrect the amp. was working perfectly until, unfortunately, the speaker terminals, on the speaker side got loose and shorted. massive fry up the PWM session, 3 fried original 2N6488. anyway, opened it up and found more were not in good shape and once removed the bars, I had to go full strip down.
Out of the total 25 2N5488 I could only test 8 good and out of the 2N6491 1, most of the latter broke when trying to remove from the bar, despite using Perry's suggested method. to cut the story short, I removed all from the PWM and output, including the SF163/A and the LM317T/337T. went to local electronics shop and got BD911 to replace the 2N6488 and BD912 to replace the PNP 2N6491.
SF163/A came out good so put them back.
MSPA06 tested on board and all look good.
MCT2V octocoupler also tested on board and seems good. anyway, I wne on and read in the past I could add power with just a barebone structure in place, so I put back the BD911 driven by the MSPA06 for the gate drive and 2x BD911 per rain in the PWM, SF163/A and powerd up with a 12v bulb as safety.
Didn't smoke anything and I got VAC out of the secondary of the main toroid and VDC aout of the center pin of the SF163/A, I only got 1.7 VDC on the SF163 and -2 VDC of the SF163A, this using the driver output GND as reference. also, REM doesn't seem to do anything as soon as I power up the amp goes on.
I tried Perry's trick or desoldering one leg of the thermal protection, but that doesn't seem to change anything on the REM circuit. so I checked again the octocoupler on the left, the R and the diodes, and the 2 MPSA06. all seems good by the reading when checked in diode mode. i have drawn the schematic as best i could, and i ended up with the exact same diagram of what was posted here already. i need some help troubleshooting this nice amp. I know and I'm sure there are better sounding amps out there, but I just love the form factor, the tone, and the looks.
i have a switch to enable REM ON/OFF and I can see 12V or 0 when flicking it.
Power led also not lighting up
original schematics credit to 90scaraudio from this thread: https://www.diyaudio.com/community/threads/orion-2150gx-repair-help.220408/
I need help with mark levinson
Hello everyone, I have a Mark levinson model "86280-0W690" and I would like to repair it myself since the repair cost is high and I have a little experience repairing but I need the help of someone with experience, my amplifier does not send signal to the speakers, the amplifier turns on and allows you to increase the volume on the radio but does not send sound to the speakers someone to help me I will leave several images of the model
For Sale Bruel & Kjaer - Vintage Microphone Amplifier Type 2603
Brüel & Kjaer - Microphone Amplifier Type 2603
From the late 60s!
The 2603 is about 55 years old, it dates back to 1966~1969.
This preamp needs some care, but the overall condition is good, and fair given its age.
Was planning to restore it but never got to it so I'm letting it go.
ASKING PRICE € 575,00 + shipping
There are 6 or more tubes in the circuitry, and as far as I can tell most, if not all of these tubes are still available in case you need a replacement one day.
I have no idea of the condition of these tubes. Neither do I know if the capacitors need replacement. I never switched it on; it was sitting in my music studio as an eye catcher, waiting to be restored one day. All parts are there. And the unit looks well preserved, which is a good indicator.
It could be non functioning, and require quite some work;
It could require just a minimal check up and of you go.
I can give no guarantees. The unit is sold as is.
To know how it sounds, look on Youtube for:"Brüel & Kjaer Type 2603 vacuum tube preamp"
I collected several PDF's of this device and line of equipment, including the schematics etc.
I will happily send them to you (saves you some research)
Please note: this preamp does not work with regular XLR mics - although you could probably mod it to do so.
It does seem to work with line signals as a DI, as you can see from the linked video.
It accepts the following mic capsules from B&K: 4131, 4132, 4133, 4134 ..
Combine the above capsules with a B&K "Cathode Follower" type 2612, 2613, 2614, or 2615.
The above parts are available on Reverb and through other places and sellers.
The inputs and outputs require a type of B&K plug that is hard to find. Luckily these connections accept simple banana plugs too, which fit like a glove. The ins and outs are basically (unbalanced) line signals. One could easily fashion a set of adapter cables that go from banana plugs (male) to 1/4" jack (female) for day to day use.
Connections are as follows:
"Amplifier input" = the main line input, which accepts a banana plug
The small hole underneath this and other plugs is ground; accepting a banana plug as well
"External Filter Input" = actually an output !! Clean signal from this out
"Recorder" = allegedly this is a more fuzzy / slightly distorted output
The overall gain is adjustable by the "Input Potentiometer" and "Meter Range" switch.
The power connector is a Nema 5-15R.
Adapters are available to regular IEC etc.
Alternatively you can connect a power cord directly using the screws adjacent to the inlet pins.
My location is Belgium. Items are shipped safe and secure with tracking etc.
Please contact me for a shipping quote for your specific location.
I'll be happy to make you a personal quote.
Have a nice day!
Reactions: ziffel
Need help from you boaters out there
I am looking at getting a combination GPS chart system and sonar fish finder unit for my 18’ runabout.
Not new to boating but these things didn’t exist when I was younger.
Do any of you have experience and or recommendations?
I also want to know about the SD cards vs built in charts and yearly update subscriptions.
Yes, I am asking elsewhere, I just trust many of the people here more than strangers so anything helps.
Reactions: Randy Bassinga
The Photography and Camera Thread
I thought it would be nice to have dedicated thread to talk about cameras and such.
To start things off…
On a whim, I bought a $17 manual focus C-mount lens with M4/3 adapter for my LUMIX GX-1. It’s 35mm focal length which gives 70mm equivalent FOV in 35mm format. I wasn’t expecting much, but the lens arrived and it’s nicely built all metal (black anodized aluminum) and laser engraved markings with butter smooth operation. Multi coated lens elements, a round 12 blade aperture. When I installed it on the camera - it instantly transformed the feel and how you take pictures - because both aperture and focus are now mechanical rings and you have to use it just like the old school manual film cameras. I left the camera on aperture priority and applied compensation when needed. Test shots showed nice sharpness wide open at F/1.6 (although very narrow plane is in focus) and superb narrow depth of field to isolate the subject. Nice bokeh - smooth tonality in out of focus regions. Color rendition is excellent. I don’t see any light falloff even wide open. I did not expect it to work so well, frankly. Here are some test shots in the lab. I’m a happy camper. This is a nice portrait lens and it’s going to add another dimension to manual shooting. Damn amazing for $17!
Highly recommended! They make adapters for other camera formats. I chose M4/3 for mine. Here is the one I got. It even comes with two threaded C mount spacer rings to allow macro photography.
Lens looks like this with adapter:
Mounted on the camera it’s quite compact for a short telephoto:
Here is a closeup photo wide open, note the tight depth of field and smooth out of focus regions:
Farther away and still wide open (look at the text on the driver handles):
Color rendition is nice - very accurate:
I can’t wait to use this to take candids or on the street.
The main thing is that it brings back the muscle memory of using my old film cameras. Instead of holding to my eye, I look at the screen to focus. My camera has a magnifier patch to check focus.
Reactions: r66cort and JMFahey
The Singing Bush Kits
Presenting thread here : https://www.diyaudio.com/forums/pass-labs/349248-singing-bush.html
Please , keep all tech. questions there.
Now , the Meat:
in case of kits , there are 3 elements :
A: Mu pcb with all parts , except mosfet puck and big output electrolytic ; which means - pcb , opto , trimpot , small elco , few MF resistors , handful of 3W MOX resistors , polycarbonat 1uF caps , zener ......... in short - everything , including wire ring and needle connectors (tip: I'm not crimping , but soldering them)
B: SIT gain pcb with all parts , except SIT , of course ; which means pcb , input JFets smd presoldered , reg , elcos , trimpots, Graetz, MFilms , small mosfet , bjts , zeners, LEDs , diodes ....... in short - everything , including wire ring and needle connectors (tip: I'm not crimping , but soldering them)
C: Schade gain pcb with all parts , except Mos puck and Iron ; which means pcb , input JFets smd presoldered , regs , elcos , trimpots, Graetz, MFilms , MOX, bjts , zeners, LEDs , diodes ............. in short - everything , including wire ring and needle connectors (tip: I'm not crimping , but soldering them)
so , 2 different kits (each being Stereo , of course) :
Option 1
: SIT Singing Bush = A+B (with Mu 3W MOX resistor set optimized for THF51/2SK182 as gain part, so 0R4 up and 0R2 down) ....... price 110E**
Option 2 : Schade Singing Bush = A+C (with 3W resistor set optimized for Mos Puck as gain part , so 0R2 both up and down) .......... price 110E**
Option 3 : Should I stay or Should I go SIT or Schade = A+B+C (with augmented 3W resistor set for Mu pcb - one 0R4 group and two 0R2 groups , which covers both SIT and Schade Singing Bush) ....... price 160E**
Option 1 down : just pcbs of Option 1 , no parts , smd JFets presoldered on gain pcb ....... price 70E**
Option 2 down : just pcbs of Option 2 , no parts , smd JFets presoldered on gain pcb ....... price 70E**
Option 3 down : just pcbs of Option 3 , no parts , smd JFets presoldered on gain pcbs ....... price 100E**
For any option above , if you don't want smd JFets ( you have your own stash) , shave 20E from final price
**Paypal fee and P&P , tracked for anywhere - included in said prices
'cause I still have some space in post , here is list of parts :
A - MU PCB:
Caps:
1uF MKC Philips - 12pcs
3300uF/16V Pana - 2pcs
Resistors:
MF 600mW - 6pcs
MOX 3W - 20pcs
Trimpot multiturn - 2pcs
Semis:
ZD 8V2 - 2pcs
4N35 - 2pcs
Misc:
ring wire conn.- 2pcs
needle wire conn.- 4pcs
PCB - 2pcs
B - SIT PCB:
Caps:
1uF MKC Philips - 2pcs
10uF/25V Pana - 6pcs
470uF/35V Pana - 4pcs
1000uF/16V Pana - 2pcs
Resistors:
MF 600mW - 32pcs
Trimpot multiturn - 4pcs
Semis:
LED 3mm green - 10pcs
1N4148 - 4pcs
ZD8V2 - 2pcs
1N4001 - 2pcs
IRF510 - 2pcs
LM317T - 2pcs
2SK2145BL - 12pcs on board
Graetz DB1 - 2pcs
Misc:
ring wire conn.- 6pcs
heatsink for IRF – 2pcs
PCB - 2pcs
C - SCHADE PCB:
Caps:
10uF/16V Pana -4pcs
470uF/35V Pana - 8pcs
1000uF/16V Pana - 6pcs
Resistors:
MF 600mW - 34pcs
MOX 3W - 2pcs
Trimpot multiturn - 6pcs
Semis:
ZD8V2 - 2pcs
BC517 - 2pcs
LM317T - 2pcs
LM337T - 2pcs
1N4001 - 4pcs
Graetz DB1 - 2pcs
Misc:
PCB - 2pcs
contact , either via PM , or directly >zenmodiyaudio@gmail.com<
Important: I resorted recently to making pcbs at our Chinese Brothers pcb factory , strictly from quality reasons ( getting tired expecting local fab to get that funny new machine doing Ping! , so I can finally see decent stop lack on my pcbs). Thus - things can be somewhat slower ........ but I wasn't fastest before , so there is no surprise ; slow, but sure ......
Frugal horn build questions
Hello everyone,
Joined here in the hopes of having build questions answered! Is the front baffle meant to be sandwiched between the two sides?
When I look at the 5x5 cut plan the front baffle length is 898mm but I'm not sure these measurements match what is on the sheet FH3-1.
On that sheet it looks like the front baffle goes over the two sides.
I cut everything except the sides already so I'm wondering how to do things right!
Need help with Sony CDP-203, strong distortion on output
I have this CD player with strong distortion on both channels like white noise, even with a silent audio track. The player worked perfectly until it was connected to amplifier that I had never tried before 😞. This makes me think of a problem with the analog output or from the DAC onwards, the tracks are read and can be heard. The service manual is easily found online. I started to probe the power supply voltages and apart from slight deviations they seem ok, I have a USB digital oscilloscope available that does not show me the RF signal with an eye pattern. It seems to me that there is a DC component in the output. In short, lots of ideas but confused, can someone give me a hand?
Parasound HCA-1500A repair and possible upgrades
[UPDATED: Workbook here - Google sheets workbook with all the information organized.]
I've done a bunch of google searches and not found too much on this particular amplifier, insofar as repair and upgrade. The power caps have leaked, and one of the power fuses is blown. I have the whole amp apart which is in otherwise beautiful condition. I'd like to replace where prudent (while I'm here) and upgrade where that's sensible.
  • 15000 uF Nichicon caps are here now, and all leaking. Suggestions here?
  • I'm wondering about the electrolytic caps that are here, while everything is open. Replace? Suggestions?
  • Any resistors I should be considering for upgrade?
I have been in the market for an HCA-3500, but the right one has yet to show up. That seems to have some good information for the DIY guys. Unfortunately I've not been quite so fortunate with this model. Any input is kindly appreciated!
Filippo
Audio enthusiast, DIY Novice
Hi all! I've been a long time forum lurker, but now hope to participate and engage further. I've been an audio and gear enthusiast for the better part of the last 30 years, and have started performing light electronics repairs in the last few years. As my skills have increased I've started taking on new projects as I have no shortage of old gear to work on. Thank you to everyone who have unwittingly helped me so much over the last few years, and I hope to engage with you all here further moving forward. Cheers!
Do they affect sound quality?
I have 2 pairs (4 units) of 10” subwoofers, ADS S10. I’m going to install them to my car. However, only one pair is original, the other has been repaired (new voice coils replaced). I will use a Soundstream reference 405 to power them. This amplifier is capable of driving 1 Ohm load on subwoofer channels. However, I’m wondering if I should install all of these four subwoofers in my car, or should only use one good pair. Because I’m afraid if the repaired pair will make the sound worse or not. But, the crossover frequency for subwoofers will be (always) set below 200Hz, so I’m not sure if the repaired subwoofers will affect sound quality of the whole system. Please share your thoughts.
Bryston 4B-SST clone kit for sale, $ 80 plus the shipping cost
Hello
I have a Bryston 4B-SST clone kit for sale, it never being assembled, all part are include, but there was no output power transistors included in that kit. So you will need to buy the output power transistors.
I did not buy the preamp and the power supply, so there is NO preamp and NO power supply in that kit.
The price for that kit are $ 80 plus the shipping cost, I sell only to a canada buyer, because shipping outside of Canada are too much troubles and cost a lot.
You need to have some good experiences in electronic to do that kit, I can not help you for the asssembling of that kit.
I include a cd of the instructions and scematic. Everything will be well packed in the original box, as you can see in the photos.
Payment can be made by interac-e-transfer
I live in Quebec.
Gaetan
TDA7293 alien use
Hello,
Yes, so it is not audio use, or not directly.
In my turntables, I'm using a double DDS generator to run my Airpax/Premotec motors. For that I'm using LM3886 based amp modules, 2 channels. That is not a straight choice I think, I had some ringing problems before I've inserted 2 antiparallel 47uF caps at the output of the chipamps, but I always wanted to try TDA7293 because I saw some others use those without problems.
Now I need a 3 channel amp (also building a 3 channel DDS gen) and there is no ready made 3 channel module, so I've decided to make one. I have power supplies, so did not put it on the board, but plan to use a simple Graetz and 4x 22mF caps.
So, if you have experience with these chipamps, would you have a look?
As I know the feedback resistors has to be placed the closest possible (some even solder on the IC legs) and obviously in/out has to be separated. Any other thing to watch?
On other threads, there was links to a document listing pitfalls in implementing amp with TDA7293, but the link does not work any more :-(
Thanks!
JG
  • TDA7293x3sch.pdf
    TDA7293x3sch.pdf
Connecting 2 Amplifiers to 1 speaker
If I connect 2 amps to 1 speaker what are the dangers?
I use a a big-box Blue-Ray receiver to power my 4.2 system. I may love my subs but my neighbours are not impressed. My original satellites have been replaced with bookshelf speakers. Turning subs off at night is not a good option as the crossover frequency is too high (120hz).
I have no plans to use 2 amps at the same time. When my home theatre system is off I want another amp to provide a full range signal to the front satellites.
Is this okay?
DIY Plans / Active 3 Way 4x10" + 2x6.5" + AMT with controlled directivity
Hello everyone,
I am planning to build an active 3-way loudspeaker. I would like to use four side-mounted woofers (10 inch), two midrange drivers (6.5 inch) and an Air Motion Transformer as a tweeter.
Everything sounds quite normal, but why two midrange drivers? I would like to have a wide horizontal dispersion, but a strongly focused vertical dispersion. To achieve this, I don't want to use the “classic” M-T-M arrangement, but bring the two midrange drivers closer together and place them directly above each other (about 18 cm distance between the centers of the drivers) and place the AMT directly above them. Due to its design, the AMT already has a strong vertical directivity with a wide horizontal sound dispersion.
I plan to use crossover frequencies of approx. 80-100 Hertz and a fairly low 1150 - 1200 Hz. My own calculations based on Excel templates from the forum have shown that a crossover frequency higher than 1200 Hz could cause problems with unwanted lobes in the midrange.
I have not yet completely decided on the drivers. I have the following favorites:
  • 10-inch bass: Purifi PTT10, SB acoustics WO24-TX, Scan Speak 26W
  • 6.5 inch midrange: Purifi PTT6.5, SB acoustics MW16-TX, Accuton C173
  • AMT: Mundorf 197PP27R-7
You can find a very simple concept sketch of the speaker from the front and from the side in the attachment. B = Bass, M = Midrange, AMT = AMT 🙂. I am thinking about dividing the loudspeaker in two cabinets per side to make it easier to handle. The thin lines in the back have a recurring distance of 10cm. Hence, the loudspeaker would be around 135cm high.
I would be very interested to hear what you think of this concept and what suggestions and ideas you have for improvement.
Thank you and best regards
Klaus
Dark LED passive filter-I/V stage for NOS DACs
Orders now are open on 'Dark LED' passive filter/IV stage boards, ready built and tested or as a kit for the baseboard with a pre-built and tested filter plug-in. PM me and please don't forget to include your chosen payment method and location so I can quote you inclusive of fees and shipping.
'Dark LED' combines a grounded base (discrete) cascoded stage followed by a 9th order LC filter, then passive I/V followed by a single-ended output buffer, designed to deliver lowest noise. The LC filter does the job of removing DAC images which, when in NOS (no oversampling) begin at 24.1kHz where this filter gives 40dB attenuation. Input sensitivity is +/1mA for 1VRMS out. The grounded base input stage presents a very low impedance to your DAC chip's current output (typically of the order of 5ohm) which helps it give of its best.
Here is how an 18kHz sinewave looks on a typical very-lightly filtered NOS DAC, compared to the filtered output of 'Dark LED' reproducing the same signal :
Preferred payment method is via Wise which typically adds a 2% fee. Our receiving currency is CNY, alternatively USD or Euro. PayPal may also be used, in USD but will attract higher fees, 5.5%.
Price for a Dark LED built and tested unit including top-mounted filter board : 920RMB (~USD128)
A kit with most SMD parts pre-soldered at JLC, filter plug-in pre-built : 720RMB (~USD100)
Physical dimensions: 72mm * 65mm, max height 25mm. Fixing centres : 60mm * 60mm, M3 holes.
Shipping is in addition and depends on your location and speed of service. Courier (FedEx, TNT, DHL) typically takes 8 - 10 days and e-packet four to eight weeks. Not all locations can be serviced by e-packet though.
FAQs
What else is needed to turn the built up Dark LED filter-I/V stage into a fully operational DAC?
You'll need, as a foundation, an existing DAC with a current output, +/1mA R2R chip. A few examples of suitable DAC chips are PCM56, PCM61, AD1860, AD1865 and PCM1702, these all have +/-1mA output in Iout mode. Your base could be an existing DAC board where you wish to bypass its on-board I/V (perhaps a socketed opamp) or maybe just a lash-up on perf-board with your R2R chip of choice. If your chosen DAC chip includes an opamp, be sure that this isn't in-circuit and the input to 'Dark LED' is being taken from the Iout pin of the DAC chip. With a socketed single opamp I/V the DAC Iout can usually be taken from pin2 (-ve input) of the socket when the opamp's removed.
Next you'll need a well regulated low noise power supply of dual rail +/-18V rated at 100mA or higher. An LM317 and LM337-based board set to the correct output voltages will be the bare minimum noise-wise. If you already have a single winding AC supply (an AC wall-wart) then 18VAC at 10-20VA would be in the right ballpark. Use a half-wave rectifier so you get both rails from a single winding or alternatively, a centre-tapped trafo. I don't recommend using switching supplies due to issues with common-mode noise, its very hard to filter out.
Third you'll be wanting some output sockets, typically RCAs so you can connect your Dark LED I/V to your amp or preamp. But your existing DAC may already have these, fed from its own filter stage.
What will I have left to solder if buying the kit version?
The parts JLC hasn't soldered are three NP0 capacitors, several 0.1% thin film resistors, ferrite beads (all 0805 size), SOT-89 transistors, 7mm dia inductors and the through-hole parts which are electrolytic caps and connectors.
What, if anything, is unique about Dark LED's design?
The LC filter is hand-built with in-house wound close tolerance gapped ferrite cored inductors, selected NP0 ceramic caps and the rest of the circuitry uses discrete (bipolar and MOS) transistors to deliver as low noise as possible. To this end, an SE (single-ended) approach is taken with I/V. The name 'Dark LED' comes from the use of infra-red LEDs as voltage references, which are very low noise indeed.
The use of IR LEDs helps reduce intrinsic and power-supply coupled noise meaning that a heroic ultra-low noise PSU isn't required, LM317/337 deliver satisfying results sonically at around 20uV audio band noise. Some technical background to the design can be found on my blog : https://www.diyaudio.com/community/threads/i-v-stages-and-noise.391189/post-7146239
Ideal bridge rectifier GB
I had a look on the market, did not find one, so we built one. 🙂
We have designed a small form synchronous rectifier, aka ideal bridge, using modern ultra low Rdson mosfets.
It started as a small side project, but the results are so good that we want to put this in production and make it a standard product.
The advantages of such bridge are very well documented:
Active rectification - Wikipedia
http://www.ti.com/lit/wp/snva595a/snva595a.pdf
Synchronous Rectifier Circuit | Active Rectifier | Radio-Electronics.Com
http://peufeu.free.fr/audio/alim_mos_diode/
Linear product presentation.
https://www.youtube.com/watch?v=x74SSPgKiNA
While this video is about automotive product, the principle is similar.
https://www.youtube.com/watch?v=X5qFJ5XNi9A
Specifications:
- operates from DC to 600Hz
- AC operating voltage 6Vac to 51Vac
- DC operating voltage 9Vdc to 72Vdc
- Iq = 1,5mA
- continuous load current up to 16A or more depending on mosfet configuration.
Do not use centre taped transformers (and centre taped used as main reference ground).
The price will start from 35euro and go down with volume as we get parts in lower price.
Up to 100 units - 35 euro
Up to 200 units - 30 euro
Over 200 units - 25 euro
GB google spreadsheet is open till 1st March included
https://docs.google.com/spreadsheets/d/144EP7ZezFLFgZeNq8q8LCgoa5Lb6z94TKbopFC7S6aw/edit?usp=sharing
Tibi
  • Thank You
Reactions: romanescu
3 Way DSP Amp
I assembled the following revision of the light version of the board, three channels of 100W PWM DAC with DSP ADAU1452.
Since there were some changes to the board structure, I decided to create a new topic to avoid confusion. Description of the previous version of the board here.
On this board revision, I add three auxiliary ADC inputs and two discrete input/output ports from the DSP. This expands the possibilities of external control of the chipboard.
To coordinate the operation of the ESP32 module and the DSP via the I2S port, a clock frequency detection circuit was implemented on the I2S bus; this was done to eliminate the transient process when receiving I2S data.
An ESP32 module was added to the optical input/output board to implement wireless audio transmission via Wi-Fi and Bluetooth.
Starter projects for Sigma Studio.
3Way DSP Amp + adapter for Dante AES67 board.
Aliexpress sells the Audio Network Transmission Interface A404 module, which supports the DANTE data transfer protocol.
The A404 module can be connected to the 3-Way DSP Amp using the adapter I assembled.
This solution, using Dante software, allows you to transmit two stereo channels to the 3-Way DSP Amp via the Ethernet.
The price of the 3Way DSP Amp + adapter board without the DT AES67 module is $105.
Attached to the post is an archive of a folder with files for the starter project for Sigma Studio.
Help with bias adjustment procedure on Parasound HCA-1000A
I could use a little assistance on the step-by-step to bias adjust my HCA-1000A.
I've watched a few "generic" YT videos on this for other amps and sort of get the basics, however the forum posts, videos and articles I've read have not been on this unit, or haven't provided enough detail for me. Some procedures have been close but when things state "measure from the output rectifier emitter" I sorta get lost. I know, I sound like an idiot. I just would like to learn.
I've got a DMM and some 'nads to give this a try, but I need some baby steps. If someone could point out where/what I should be placing my leads I'd really appreciate it, and then I can pay it forward someday.
What Should I Look for When Hiring a Video Production Company?
Hi everyone,
I’m looking to hire a video production company to create a short promotional video for my small business.
There are so many options out there, and I’m unsure what to look for in terms of quality, pricing, and reliability.
Should I prioritize companies with big portfolios or go for smaller, more affordable teams?
Are there red flags to watch out for when reviewing past work or client testimonials?
Any tips or recommendations would be greatly appreciated
especially if you’ve been through this process before.
Salas Folded Simplistic Phono (2014)
Hi all DIYers from Athens, Greece.
I' m selling my best diy project I made 11 years ago under the invaluable guidance of Mr. Nikos Salas.
I tried to use the best components I could afford (and find) at the time, inclusive of a sturdy aluminum case and a toroidal transformer (from a specialist in Poland).
I used silver WBT solder throughout and I made the best solders possible (see photo)!
The phono worked for approx. 18 months with a VDH The Frog (MC-high cartridge) with great results!
For a short period, I easily configured the insides for MM cartridge as guided by Mr. Nikos. Again, great sonic results.
Since then, the phono remained in this configuration but disconnected from my stereo due to a "different hobby orientation".
To be able to re-swap again to MC configuration I prepared a bag containing every component as well as detailed instructions. If I'm correct I didn't omit anything.. 🙂
Unfortunately, I cannot help in any technical question as I have forgotten everything about this project, sorry. Mr. Salas could help here if possible.
I'm asking 800 euros + shipping.
For overseas buyers: you should also provision for customs fees but I don't know if it's possible because I have no selling experience outside the EU and eBay.
Thank you for reading this listing,
Stavros.
PSU design/topology for portable HYPEX UCD400HG amp?
For my final bachelor's (EE) project , I've decided to build a battery powered PA speaker.
I am using a single RCF CX12N251 coaxial speaker as a driver and two HYPEX UCD400HG HxR amp modules to drive the woofer and the tweeter. For DSP I am using ADAU1701 board from wondom.
The main question for me is which route should I go in regards to power supply? Because the amp modules require +/-60Vdc (Bi-Polar).
For example, using two LiFePO4 12v batteries, and building two boost converters to boost them each to 60V, put them in series and use the middle point as GND? Ofc, trying to keep the noise as minimal as possible.
Anyways, if you have any experience or similar let me know. Looking for the "best" option for a class D.
Much appreciated!!
Tried unusual output stage with great results
Hi guys I have to share my unscientific experiment.
I got bored in my hotel room so I thought I try something crazy.
I pulled the opamps out of my Chinese R2R DAC and also out of my Accuphase c-3850 preamp clone boards from Ali that normally use NE5534 on the input.
Took some wires that fit nicely into the opamp sockets and connected all in in/out fashion.
Result is very good. Dynamic detailed spacious sound.
All is powered by the Jan Didden silent switcher that runs off a 5v power bank. It puts out positive and negative 15v for the Accu boards and 5V for the Dac itself.
Listened for about 2 hours with only using up 1 bar of four from my 10a/h power bank.
I used my phone with USBplayer pro in bit perfect mode.
Absolutely stunning without any expensive opamps involved.
Gain is very high but for road use I will put the volume pot between the two Accuphase clone boards
If I use my tube amp I can probably get away with using only one Accuphase board.
Reactions: pjasio253
TL graphic (THD and harmonic)
Hi all. Lately I've been working on a hybrid MLTL box that has a single 180 degree bend with no filling, just a completely empty duct to experiment and understand what happens inside. Previously I had built a BR box using the same speaker (without tweeter and without crossover). In both cases I made some measurements with REW obtaining graphs of SPL, distortion, harmonics and impedance, obtaining different results. I wanted to compare my results with those obtained by other people who have built transmission lines. In particular I am interested in the distortion and harmonics graph. I searched online without finding anything, this seems strange to me, perhaps I have not looked in the right places. What do you think?, are there people in this forum who want to share their data?. Ciao and thanks.
Projects by fanatics, for fanatics
Get answers and advice for everyone wanting to learn the art of audio.
Join the Community
507,772
Members
7,887,886
Messages
Filter
Forum Statistics
Threads
406,205
Messages
7,887,886
Members
507,772
Latest member
Hypertone
