Go Back   Home > Forums > Blogs
Old
Maze Back Horn
Posted 11th January 2013 at 12:01 AM by DougL
https://www.diyaudio.com/forums/full-...w-you-can.html
I want to make this for Adam.
Posted in Uncategorized
Views 812 Comments 0 DougL is offline
Old
Headphone amps are hard.
Posted 9th January 2013 at 11:41 AM by rjm (RJM Audio Blog)
Updated 21st January 2013 at 08:12 AM by rjm
The $50-from-China-via-ebay NJM4556-based headphone amp, pictured below, fails the "Is thing thing on?" test. With 16 ohm, 104 dB/mW headphones there is a faint-yet-audible background hiss when the unit is powered up and the volume is turned all the way down. The hiss increases only slightly as the volume is turned up (input disconnected).
The output noise of an op amp is normally estimated from the input-referred voltage noise density multiplied by the gain, and the current noise density multiplied by the gain and the sum of the input impedances on the inverting and noninverting inputs. The NJM4556 datasheet does not give a figure for current noise, but a reasonable guess is 1 pA/sqrtHz. The voltage noise density is estimated at 8 nV/sqrtHz.
Total noise is
Vn (output) = sqrt [(i_n R_s)^2 + e_n^2 + 4kT R_s] * Gain
Working from a source impedance of ~10k, I get about 18 nV/sqrtHz or -138 dB.
[Revised according...
Click image for larger version
ID:	834   Click image for larger version
Name:	sApVI schematic.jpg
ID:	835   Click image for larger version
ID:	836   Click image for larger version
rjm's Avatar
rjm
Posted in The Lab
Views 2506 Comments 10 rjm is offline
Old
6C33C OTL Amp Comes to Life
Posted 8th January 2013 at 01:45 AM by wlowes
This is the continuation of my personal journey to build my first tube amp.
It was a very happy day yesterday when the first mono bloc powered up and produced music. I was pretty comfortable that I had not made mistakes that would result in smoke, but really did expect some issues with hum, grounding or tube substitution. But nothing! Hum was barely audible with my ear on the speaker or from the chassis. And music played! My first test flight was one channel only driven by a Sony Walkman on a small Totem speaker. Even under these conditions the sound was pretty good, and really started to open up after the first 60 minutes. I was like a proud father
The first picture shows the pair with a Rotel CDP in the middle for scale.
I will not be able to fully know the sound until both are wired, broken in and hooked to the good speakers and source. I think they will be amazing. Already better than the very respectable chip amp they replace. There is a switch...
Name:	6C33C pair assembled.jpg
ID:	829   Click image for larger version
ID:	830   Click image for larger version
Name:	Phone pics to 1 7 13 248.jpg
ID:	831   Click image for larger version
ID:	832   Click image for larger version
Name:	Tube light.jpg
wlowes's Avatar
Views 3195 Comments 1 wlowes is offline
Old
my tube_you
Posted 6th January 2013 at 03:32 PM by suwaned (tube audio friends suwaned)
Updated 8th April 2016 at 04:54 AM by suwaned
Preamp cleo4 Triodedick's
The First falling in Love with TUBE, when i had heard the preamp B406 my friend.
I have build the first Project tube , preamp B406 single stage.
final:
Preamp with Phillips B406 and Phillips D3a with output line transformer Hasimoto HL10K_600.
rectifire Valvo AZ1.
Thank you for your Help and advised my Friend "The_Manta" and my friends_audiotube.
ID:	883   Click image for larger version
ID:	884   Click image for larger version
ID:	892   Click image for larger version
ID:	893   Click image for larger version
ID:	895   Click image for larger version
ID:	898   Click image for larger version
ID:	899   Click image for larger version
ID:	900   Click image for larger version
Name:	cleo4v copy.gif12.gif
suwaned's Avatar
Views 1265 Comments 0 suwaned is offline
Old
Noise modulation and subjective performance of DACs
Posted 25th December 2012 at 05:22 AM by abraxalito
Updated 20th September 2014 at 03:41 PM by abraxalito
I've recently come to the view that the best metric of SQ in DACs is noise modulation, however as yet I'm unclear how best to go about making the measurement. Stereophile tried, and here's what they did - Noise, Modulation, & Digital/Analog Conversion | Stereophile.com
Robert Harley reports no correlation with listening so I deduce from this that the test method isn't looking for the right thing. My own gut feel is we need a multitone test waveform rather than a single sinewave as a sinewave has a crest factor quite unlike music and if a sine provoked the condition we'd see it on the 'N' part of a THD+N vs level test.
Having said that, of course we do indeed see something weird going on - on Weiss Medea's implementation of the ESS Sabre. The THD+N plot versus level shows kinks which most certainly are not increased THD at various levels, so can only be noise floor modulation. See a critique I made on WBF here - https://www.whatsbestforum.com/showth...l=1#post133677...
abraxalito's Avatar
Views 1339 Comments 4 abraxalito is offline
Old
To boldly go where no audiophile, or, perhaps just me, has gone before ...
Posted 23rd December 2012 at 04:07 AM by fas42
Updated 23rd December 2012 at 04:11 AM by fas42
As 'threatened' in a comment in abraxalito's blog I'm going to kick off posting and linking to some samples of sound generated by myself, at the moment examples of replay on my system, recorded using a very basic technique.
I'll probably regret it, but I'm going to put up a rough and ready trial run, to give a smell of what I'm aiming at. It's full of problems, but it gives some good indicators of what I'm dealing with, and hopefully some feedback will help me for future runs.
The system is my 'dud' HT all-in-one setup, heavily tweaked, and the recording device is a Fujifilm S4000 camera, which does HD video rather nicely, with mono 44.1/16 audio thrown in - that's handy. To maximise sound quality and minimise card storage used, hopefully, the lens was covered while recording, yes, no pics! Unfortunately, signal to noise is poor and the automatic volume control keeps falling over its feet, but you can't get everything for that sort of money :) ...
Banned
Views 1819 Comments 14 fas42 is offline
Old
Rating: 2 votes, 5.00 average.
Rebuilding a Hafler DH200 Part 1
Posted 11th December 2012 at 12:42 AM by Stormrider
Doctor, Doctor
David Hafler (RIP) must have sold tons of these amps... There are always a wide selection of different models on ebay, but the DH200 and DH220 seem to be the most common. I have three of my own (2 P230's and a P125) that I cycle in and out of use. I've repaired and rebuilt several for other people, and yet I keep running into more of them. The most recent being Brokencrank's DH200, which I have documented below for reference, and to have a place to put my notes. I don't claim any of the info below to be gospel, just my experience. I also don't claim this to be a step by step guide to resuscitate your old Hafler. A basic understanding of electronics and amplifiers will be required. Know what you're doing before you do it, and you will make less mistakes. If you have questions, ask!*
Note: All of the component reference numbers (ie. R3, C14, Q10, etc...) I mention will be based on the schematics available in the manuals at Hafler.com. Because...
Stormrider's Avatar
Views 12109 Comments 5 Stormrider is offline
Old
Digital that sounds like analog
Posted 10th December 2012 at 04:18 AM by abraxalito
Updated 15th February 2013 at 06:11 AM by abraxalito
For those who missed Frank (fas42)'s link on a thread I started then here's where I'm continuing my minimal oversampling DAC developments for the time being : Digital that sounds like analog
abraxalito's Avatar
Views 4023 Comments 108 abraxalito is offline
Old
Google+ DIY Audio community.
Posted 7th December 2012 at 11:06 PM by rjm (RJM Audio Blog)
Updated 14th April 2013 at 11:14 PM by rjm
There was no DIY Audio community on Google+.
So I made one.
Google+ has always been a "quiet room" where like-minded people got together to talk about things, away from the noise and chaos of facebook.
The problem was that it was difficult to find said like-minded people. They were there, but for the majority you had no way of knowing that.
Well, now Google has fixed that by introducing "communities". It's a user-created hub, a digital meeting room ~ salon ~ lounge ~ front porch, a designated gathering place associated with a certain hobby, interest, or topic.
This feature is brand new, so I have no idea whether it will work. It could, like facebook, devolve into noise and spam... or it might be useful and worthwhile. I think its worth a shot, anyway.
I created the group, but it is free and open. It's not mine in the sense I don't intend to use it as a platform. I have my own G+ page for...
rjm's Avatar
rjm
Views 1518 Comments 5 rjm is offline
Old
Amplificador SubZero-Dr Jacobid
Posted 2nd December 2012 at 10:17 PM by SERGIODS
SUBZERO
Hello fellow forum would like to know if anyone har Zero sub amplifier, is an amplifier that caught my Atencio.
It is the famous Dr Jacoid
> Output power (RMS) 180W into 8 ohms -------------
> Output power (RMS) 230W into 4 ohms -------------
> Output (music) --------- 220-230W into 8 ohms
> Output (music) --------- 270-300W into 4 ohms
> Check osetljivost/impedansa----0, 6V/47koma (by 200Wrms ohms /
> ----- 7 Hz 112KHz-/-3dB frequency response (to less than 0.01% distortion)
> ------------------- THD <0.003% (a 130WRMS into 8 ohms)
> ------------------- THD <0.005% (a 180WRMS into 4 ohms)
> S/N------------ noise> 95 dB (compared to 100Wrms)
> ------- Damping factor> 300 (in 150WRMS into 8 ohms)
Notice of Copyright. Everything on this website is copyrighted by Dr. cheekbones Borivoje. Reproduction or re-publication by any means, electronic,...
Views 1887 Comments 1 SERGIODS is offline
Copyright ©1999-2017 diyAudio
