Go Back   Home > Forums > Blogs
Old
A catalog of headphone amplifier circuits.
Posted 19th May 2013 at 10:45 AM by rjm (RJM Audio Blog)
Updated 21st May 2013 at 12:12 AM by rjm
Lots of circuits out there, but most are variations of a small set of archetypes. Let's see if I can put together a list:
1. Dedicated headphone amplifier IC. e.g.(lme49860)
2. Battery powered, single stage, generic audio op amp. The ever-popular mint tin cmoy.
3. Op amp + buffer (complementary transistor pair, diamond buffer, unity gain op amp, etc, in either integrated or discrete package.)
a. closed loop connection or "compound amplifier" configuration as developed by Walt Jung.
b. open loop, two stage circuit, e.g. nwavguy o2 and my sapphire amp.
4. simple 2 or 3 transistor "introduction to electronics"-style amplifier
5. The "little big amp", a scaled back version of a transistor or vacuum tube power amplifier design. (Zen, DoZ, transformer coupled SET amps)
6. The power follower. Single-ended MOSFET or BJT, with or without CCS load, voltage...
rjm's Avatar
rjm
Views 1399 Comments 0 rjm is offline
Old
Nearly There - A Low Power Desktop Amp
Posted 17th May 2013 at 07:09 PM by BuildMeSomething
Well, this project is nearing completion. The very last pieces needed have been ordered and will be delivery early next week. The chassis and custom PCB enclosure/heat spreader were collected on Thursday morning from FedEx and UPS. Thursday night was spent drilling and tapping holes for the various parts. Now its some wire placement and waiting on the last pieces...
Problems: None really, a few sizing issues for connecting wires and the caps to the boards. Though, all are just big enough with a little patience. Certainly no issues that require a halt to the project or new PCB's.
Speakers: Decision made, Frugel-Horn Mk 3 with Mark Audio Alpair7.3 drivers... Why? I love the strong imagining and detail given by the little 3" FC full range speakers, so thought I'd give some proper full rangers a go. Should be fun trying to build these
Click image for larger version
ID:	1071   Click image for larger version
ID:	1072   Click image for larger version
ID:	1073   Click image for larger version
ID:	1074   Click image for larger version
Posted in Uncategorized
Views 605 Comments 0 BuildMeSomething is offline
Old
Which soldering station should I buy?
Posted 17th May 2013 at 07:47 AM by rjm (RJM Audio Blog)
Updated 20th May 2013 at 05:20 AM by rjm
Thinking I should get a new soldering station.
I've had my eye on a Weller station for the longest time, but put off getting one for one reason or another.
Looking at the selection, I think the choice comes down to the two following models, or, indeed the equivalent made by another company:
WTCPT (link)
WES51 (link)
The main difference is in the WTCPT the tip temperature is fixed, but rigorously controlled, while the WES51 has user adjustable power but the tip temperature is left unregulated.
I'm leaning towards the WES51 as being slightly more in line with my own style of work: I'm more likely to want higher or lower temperatures depending on the job at hand than I am to require "700F" exactly.
Update 1.
A little concerned the WES51 is only 50W max. That's less than the maximum I use now for the tough stuff.
Hakko has two models in the price...
rjm's Avatar
rjm
Views 1060 Comments 6 rjm is offline
Old
Doping of cloth surrounds on recone of subwoofer
Posted 14th May 2013 at 12:32 PM by googlyone
Well, you learn something every day. I suppose if you don't manage to learn as you go, then you probably stuff things up every day!!!
About 12 months ago I came across some RCF L18/551 eighteen inch subwoofer baskets. I reconed them using aftermarket parts, the process went OK but I was kind of bemused by the untreated cloth surrounds.
I was busy, and had no immediate plans so the drivers were shelved for a rainy day.
The Thielie and Small parameters were "OK" but not exact as OEM. I measured these using the addded mass method, an important fact for later. As an aside, they would do well enough as subs, but their Fs was a bit higher than I would have hoped.
Fast forward to last week, I loaded one into a 220 litre box tuned to 34Hz, and measured the impedance.
Bugger me if the resonance showed one massive peak at pretty much the driver Fs, and a tiny lump out at 80Hz. Huh?
I swapped drivers...
Views 1116 Comments 1 googlyone is offline
Old
Measurements with a sound card
Posted 13th May 2013 at 09:08 PM by alexcp (My DIY projects)
Updated 7th September 2013 at 09:36 AM by alexcp (Updated for ASIO4ALL)
I am using a USB sound card for measurements. It's a pain, but I have nothing better yet.
The sound card is the E-MU 0204. I've chosen it for the specs:
  • Dynamic Range (A-weighted, 1kHz, min gain): 113dB
  • Signal-to-Noise Ratio (A-weighted, min gain): 113dB
  • THD+N (1kHz at - 1dBFS, min gain): -101.9dB (.0008%)
The sound card is intefaced to the real world by Pete Millett's sound card interface.
The software is SpectraPLUS 5.0 by Pioneer Hill Software (PHS). (No link because my antivirus says their web site is infected.) The software runs on an old MacBook running Windows 7 in Boot Camp.
The results do not seem to be affected by nearby computers, flurescent lights, switching power supplies, etc.
The results are affected by:
  • Windows Mixer settings (levels and sampling rates)
  • Software settings (levels and sample rate)
  • Grounding of the sound card, the interface, and the device under test
The greatest source of pain is...
Name:	E-MU 0204 loopback spectrum.png
ID:	1055   Click image for larger version
Name:	E-MU 0204 loopback THD+N vs Freq.png
ID:	1056   Click image for larger version
Name:	E-MU 0204 ATEST spectrum.png
ID:	1057   Click image for larger version
Name:	E-MU 0204 ATEST THD+N vs Freq.png
ID:	1058   Click image for larger version
Name:	NE5532 power amp spectrum.png
Name:	NE5532 power amp THD+N vs Freq.png
alexcp's Avatar
Posted in Instrumentation
Views 1621 Comments 0 alexcp is offline
Old
Rating: 2 votes, 4.00 average.
NE5532 power amplifier
Posted 12th May 2013 at 07:51 PM by alexcp (My DIY projects)
This is a project developed by Douglas Self and published in the Elektor in October and November 2010.
The idea is rather unusual: "An interesting power amplifier can be made by connecting enough 5532s in parallel, how about 32 for a start? This may sound like a radical course of action, but it actually works very well, making it possible to build a very simple amplifier that retains not only the excellent linearity but also the power-supply rejection and the inbuilt overload protection of the 5532, which reduces the external circuitry required to a minimum."
Elektor used to sell PCBs for this project, which I used. I modified the circuit slightly to incorporate an active volume control along the lines of Douglas Self's preamplifiers.
Here is the result:
ID:	1045   Click image for larger version
ID:	1046   Click image for larger version
ID:	1047   Click image for larger version
ID:	1048   Click image for larger version
ID:	1050   Click image for larger version
ID:	1051   Click image for larger version
ID:	1052   Click image for larger version
ID:	1053   Click image for larger version
alexcp's Avatar
Views 8085 Comments 2 alexcp is offline
Old
Eternally Penultimate Zen - mod #4
Posted 11th May 2013 at 08:32 PM by alexcp (My DIY projects)
Updated 27th April 2015 at 12:29 PM by alexcp (Added pictures, links)
My first solid state amplifier build, in 2009, was The Penultimate Zen, aka Zen Variations Part 4, aka ZV4. It was built with the parts I could find back then, without knowing where to look. It ended up big, heavy with two 400VA toroidal transformers, ugly inside with some electrical tape here and there, without proper grounding, etc., etc. I was as disappointed with the sound as my wife was disappointed with that heavy black metal brick gathering dust.
My first mod on ZV4 came after I turned my disappointment into finding better part suppliers. I returned to my ZV4 and replaced the output caps with something marginally more decent from eBay. The sound improved a notch. Aha!
My second mod was to rebuild the power supply. I threw away one of the toroids, added a softstart circuit from Hypex, and put in a CRC filter with some Mundorf HC caps. One power supply for two single ended channels forced me to learn about grounding and add input transformers and balanced...
ID:	990   Click image for larger version
ID:	991   Click image for larger version
ID:	992   Click image for larger version
ID:	993   Click image for larger version
ID:	995   Click image for larger version
ID:	996   Click image for larger version
ID:	997   Click image for larger version
ID:	1620   Click image for larger version
Name:	ZV4-JFET two-tone.png
alexcp's Avatar
Views 2057 Comments 0 alexcp is offline
Old
Audacity sucks.
Posted 9th May 2013 at 02:50 PM by rjm (RJM Audio Blog)
Updated 10th May 2013 at 03:35 AM by rjm
Under windows at least, Audacity is unable to record audio at bitrates above 16 bit.
It will seem to, all right, but the data is quantized at 16 bit (30 microvolt LSB), regardless of the settings chosen.
The attached images show the same source, the first recording is made in Audacity, supposedly 24 bit, but actually only 16 bit, while the second is recorded with a program than actually supports 24 bit, exported, and imported into Audacity. The data is amplified +70dB in both cases to make the difference visible.
Audacity will happily manipulate and save high bit rate data, but as a result of licensing restrictions and on account of it being freeware, it does not support the actual recording of this data.
Any internet search will confirm that the Windows version of Audacity is limited to 16 bit recording. And yes, it's more of a limitation of Windows than it is of Audacity. My irritation, however, is chiefly with Audacity...
ID:	987   Click image for larger version
rjm's Avatar
rjm
Views 940 Comments 0 rjm is offline
Old
Back to passive filters
Posted 8th May 2013 at 02:11 AM by abraxalito
I didn't much care for the sound of my active elliptic filter - great dynamics in the bass for sure but the upper-end colourations were a bit unnatural sounding. So I've shelved tthat one for now and instead I'm playing with a simplified (by which I mean fewer inductors) passive elliptic.
There are two topologies for building elliptics where the zeroes are realized either by shunt series-LC networks or series paralleled-LC networks. The series created zeroes means fewer inductors are called for. In its most basic, unbalanced form there would be just three inductors for a 7th order filter. This filter though is balanced and designed to feed my Nitro desktop amp directly, without any I/V amplifier stage.
abraxalito's Avatar
Views 1151 Comments 13 abraxalito is offline
Old
Tube-I-zator Output Cap Upgrade
Posted 3rd May 2013 at 03:23 PM by dvb projekt
Updated 30th November 2016 at 08:58 AM by dvb projekt (Sound review added)
My last dream come true!
The output cap upgrade to the holy grail...
DUELUND´s CAST PIO Copper Cap!
Therefore the Tube-I-zator must go to the 2nd floor
Sound review
Now after ~150 hrs. burn in time, i will share my impressions with these outstanding caps.
I had a déjà vu after changing from my previous Mundorf Suprem silver/gold/oil caps to the Duelund CAST PIO Copper.
The same difference as in my 300B mono block´s.
This openness, clarity, three-dimensionality with so many more subtleties and micro informations, absolute breathtaking.
Only the Duelund CAST has
dvb projekt's Avatar
Views 1848 Comments 3 dvb projekt is offline
Copyright ©1999-2017 diyAudio
