My latest infatuation - transformers
Posted 25th October 2014 at 08:11 AM by abraxalito
Updated 6th November 2014 at 11:51 PM by abraxalito
I've found that some of the el-cheapo trafos (18rmb each) at a shop at the local electronics market are of split bobbin construction. This makes bodging up an audio OPT from two mains trafos a fairly straightforward matter.
I bought some with 9-0-9V and others with 0-12V secondaries. Then I disassembled them (fortunately they're not varnish dipped) and swapped out the 220V primary bobbin for the secondary of the other one. This gives me a trafo with 18V on the primary and 12V on the secondary, a step down of 1.5:1, impedance ratio of 2.25:1. So it makes a 4R drive unit appear as 9ohms to the chipamp.
And when I applied this to the output of the bass/mid of my chipamp (residing in the Phenix active speakers, its a TDA7265), apart from it sounding quieter I suddenly realized how much power supply noise I was still listening to. Incredible
So if you want to know if your chipamp PSU decoupling is really up to snuff, see how much difference a 1.5:1 trafo makes. Subjectively it 'distanced' the sound, Frank's 'disappearing speakers' trick once again
Update - bought some more 15VA trafos, this time with 15V secondaries. After taking them apart, I tore out the primaries (the wire is thin (0.15mm) so unwinding isn't recommended unless you have an hour or more to while away, just cut through the whole caboodle with wire cutters and recycle the wire as copper scrap). In lieu of the 220V primary I wound a 7.5V secondary (0.8mm wire, around 0.3R) making these 2:1 step down. The application is my now long-in-the-tooth D1080 MkIIs where a pair of TDA8947s drive the units. I'd recently discovered there was a substantial mis-match in that the units are 4R and the 8947 is not at all suited to such a low impedance load, given it has a bridged output. A 2:1 ratio trafo transforms these units into 16R, a perfect match. So far I've only done the trafo mod to the bass/mids but the effect is quite repeatable, much improved dynamics and a shifting backwards of the music so that the speakers now seem rather incidental to the goings-on. Don't forget a 3,300 or 4,700uF 'lytic in series with the primary though to prevent trafo saturation with the DC offsets typical from chipamps. The D1080s have undergone such a remarkable transformation that I shall have to buy up a few more pairs now....
Update2 - now have wound and installed the tweeter trafos. These are much easier and quicker to wind as the design equations indicate much fewer turns are required for HF duty. I use ferrite cores, similar to Ferroxcube EQ25 and 40turns for the primary, 20 for secondary. I'll post up a pic of the end result in due course. I've only wound a couple of pairs so far, the wire might benefit from optimizing as I'm concerned about HF losses and with the wire thickness I use (0.6-0.8mm) there may well be considerable proximity effect losses. Listening now and Leonard Cohen's voice has not been more engaging in its emotional impact, addictive stuff
The soundstage depth is the best I've ever had from a pair of integrated electronics actives - these speakers have the active XO mods I talked about in an earlier post but still only use TL084s.
Update3 - I've now uploaded a pic of the tweeter trafo. As you can see its dminutive, under 30mm across and about 20mm high.
Update4 - I'm experimenting now with a smaller size of transformer. I found another vendor where their 10VA trafos cost 9rmb - half the price of the 15VA ones. But on disassembling the first one I found that they're not making the best use of the winding window - more copper can be got in
These also aren't split bobbin which is an advantage for doing custom windings (rather than re-using ready made ones) because there's no shroud holding the two bobbins together, meaning more space for windings. So it may well be that a 10VA with optimized windings can equal or exceed a 15VA. Stay tuned
Update5 - added a pic of the 'unwrapped' electronics from my 2nd pair of D1080s - I figured I needed the electronics out in the open to better optimize the SQ. Besides that the cabinet was severely constraining how many caps I could tack on to the supply
The trafos for bass/mid now are 9rmb 10VA types, wound for 2.5:1 step down. Needless to say the sound is awesome, a major incentive for me to persue higher step down ratios...
Total Comments 101
Comments
Posted 2nd February 2017 at 12:49 AM by abraxalito
