What could be the cause of those clicks ?
Do you use standard filter pack?
Is you PCM stream correct (not larger than 24bit 192k)?
It's a fantasy feature. Vapourware. Will be implemented one day, or whenever the designer gets 10 minutes to spare
I don’t think Soren has implemented the I2S header yet in firmware. The USB connection is connected to the other I2S DAC input.
The firmware is done to support the 2nd i2s port, including autodetect, just need some more testing and cleanup before release...
Can't really be a hardware issue. Have you changed settings in uManager ? What channel does it output ?
And no, it measures 30 ohm between each output and gnd, the mute jfets are about 30 ohms when muting. If you need to check output impedance, do it while powered on, but without music playing.
Well, as it outputs mono, a short between the channels was suspected - hence the idea to measure the resistance between the channels rather than against ground.
If it outputs combined L+R mono or one channel mono must be verified.
An out-of-phase signal (CD phase test) becomes silent.
On the 1921, what command/setting can produce mono?
Manual says:
set par=value set paramter to value, set alone to show
conspeed = 9600 | 19200 | 38400 | 57600 | 115200
volume = fixed -80 - +10, line output startup volume
filter = linear | mixed | minimum | soft
mode = normal | parallel
Manual says:
Soekris is the J2 connector on the Dac1541 for i2s output, or is it for flashing xmos firmware ?
J2 on dam19x1 is for manufacturing test.
I'm not sure what you're saying, are you trying to run it in mono ? That wouldn't make sense on a dam1921.
Should be at normal mode, parallel is for dam1941 only.
Let me check the mode settings and the audio path, maybe I have missed something.
It was loaded with this filter:
+ a few biquads not showing here.
dam1021,44100,8,4,1999,8
04 TNT441Lin Linear Phase FIR1, 44.1 Ksps, 0-19,4 Khz - 0.3 db, 22.04 Khz -163db
0.0000000000199589610540556
0.0000000000183149373464365
0.000000000014025867195505
0.00000000000762654397771003
-0.0000000000000419597726246247
-0.00000000000793830876143231
-0.0000000000149570322334715
-0.0000000000200777552540517
No crossfeed is a function added in dac1421/dac1541, and the dam1941 is based on the dac1541 so it support crossfeed.
For those who don't know crossfeed, it's a function to be used with headphones to reduce the with of the soundstage to simulate speakers. The dac1541/dam1941 do it using digital filters that mixed the two channels.
Try google if you need more info.
Correct, the first 8 biquads is reserved for the crossfeed so there is only 7 left for the user. I didn't expect that to be a problem, but if needed I can add a software switch to disable to crossfeed function.
The filter file is on the website, new firmware will come up very soon.
Where can I find a 1941 FW/filter file? I would like to factory reset my DAC please?
- Vendor's Bazaar
- dam1941 - Next Gen Discrete R-2R Sign Magnitude 24 bit 384 Khz DAC module
