New dam19x1 firrmware rev 1.24 is now up on Soekris Engineering ApS, Products dam1941
The manual has also been updated.
There is now full support for the 2nd I2S port on J9, including auto detect.
There was single report earlier about clicks, same as on the dam1021, it should be fixed now, but please report back those that had the issue.
I see 1.23 firmware on the site not 1.24 rev.
Some products has it's download on their specific product page, others have it in under the top level "Downloads" - could that be structurally improved to use a common pattern?
Maybe an overview chart with product to the left and some properties columns would good - like:
Product (link)-Revision-Latest FW (link)-Latest Filter (link)-In production(y/n)-some_more...-Link to prod page.
I just tried to update the firmware on the DAM1941; first off I updated my DAM1021 with 1.21 with no problems. With the DAM1941 using ExtraPutty I am informed that a connection has been made but I get garbage on the screen followed by the cursor. No input is allowed.
Putting the dac back into the system it is still working as previously. Rubbish on screen is:-
Y 6 + e Ym Y V _e V
Any ideas?
Y 6 + e Ym Y V _e V
Any ideas?
Hi,One thought - I did pair an Apple Remote with the dac and stored this by pressing FILTER for 4 seconds. Could this have corrupted the firmware in any way?
I had the same problem. It was due to a wrong rs232 interface. 1021 is using standard rs232. The 1941 is using a TTL interface. Check the manual for 1941 in there you will find a recommended cable.
Many thanks for the info, I will try setting it to TTL level, in the meantime back to the music.Hi,
- Vendor's Bazaar
- dam1941 - Next Gen Discrete R-2R Sign Magnitude 24 bit 384 Khz DAC module
