VituixCAD
The latest build informs when mp is checked in Drivers tab:
^Done. Problem with PRs only due to few missing parameters. Hopefully nothing else won't damage because this required shortening maximum length of value + unit.
Someone could also inform North American retailers such as Parts Express that driver manufacturers (including Dayton) use SI units. Not any moose's heads.
Hi. Just received the mic. And have some confusion.
Can you tell me which way to connect it correctly with the interface, please?
Do I need to loop one channel according to the schematic?
Yes I know. I just stuck during VituixCAD manual reading.
Can't find ANY good video tutorials how to do it.
Yes I know about DATS you can live without IF you know already how. Not me 🙂
Seen manuals b4 and bought a "plug and play" solution.
Next time will be crossover questions only.
Promise 🙂
sorry if this was answered some place already:
I recently started using VituixCAD and started first with an active Xover design. Then I replaced some of the active filters with the passive ones to reduce the number of way. However as far as graphing the calculation results on the right side of the screen everything works but the impedance is not being calculated. How can I have the impedance calculated for the passive portion of the Xover?: All drivers in the model have both the freq response and an impedance curve entered. Thx a lot.
