Acoustic Horn Design – The Easy Way (Ath4)
Suddenly it's funny how is the ST260 actually small - ST260 vs CE360 petals.
And I also already know the tolerance needed - the groove on the petal is 0.3 - 0.4 mm too narrow in my case. Shouldn't be problem to fix this.
YES! :)
- No sanding yet, these are raw pieces as they left the printer, no glue yet.
I only wish the inner surface of the base was better but it seems I can't figure out how to do that in this case.
Rough after the first 1/2" of throat is good.
I've found I like fine sand in the paint roughening the surface.
Fun seeing you do this.
I've turned several pairs of Tractrix 550Hz horns on my lathe, and adapted an end sander to allow me to turn the larger diameter Le Clèac'h 550Hz horns.
You could experiment with small ridges ala Cessaro horns and see what sounds best.
What will the resonace / stability be like? Use bitument to dampen?
I've found the softer the wood the better the sound for higher frequency applications.
I don't know how printed plastic compares.
