Is it possible to cover the whole spectrum, high spl, low distortion with a 2-way?
Old 8th November 2019, 09:49 AM   #4121
jzagaja is offline jzagaja  Poland
Originally Posted by Ro808 View Post
The dark colored stuff in the middle and at the bottom?
Exatcly.
Visit us at http://www.diysoundgroup.com
The SEOS™ Project http://www.avsforum.com/t/1291022/he...-rallying-here
Old 8th November 2019, 10:19 AM   #4122
Ro808 is offline Ro808  Netherlands
2x Pro Audio TL subs,
Wisdom Audio's Regenerative Transmission Line® :
AXIOM Manifolded Transmission Line:
Old 8th November 2019, 11:14 AM   #4123
...And tapped horns are basically transmission lines with the mouth tap filling the hole in the response that's common with 'regular' end loaded transmission lines.
Old 8th November 2019, 01:17 PM   #4124
nc535 is offline nc535
I was just going to comment on that when I saw your post. Only a little bit surprisingly, the tapped horn subwoofer community doesn't seem to have hit upon partially stuffing the pipe to tame some of the resonances those horns so clearly suffer from. No doubt its because that might cost a db or two at the very low end.
My Synergy Corner Horns and Bass Bins
http://www.diyaudio.com/forums/multi...bass-bins.html
Old 8th November 2019, 01:44 PM   #4125
papasteack is offline papasteack  France
Don't say this in subwoofer forum
Bjorno is the master of stuffing
Old 8th November 2019, 01:49 PM   #4126
No doubt there is an art to it.
Just playing with HR. In my sole example, I see partially stuffing the first segment moderates the peaks pretty well but doesn't smooth them out totally. Stuffing any other segments kills the low end.
Old 8th November 2019, 09:34 PM   #4127
Play with S1 area, L12 lengh, and stuffing only at the beginning of L23. And free to you to add low pass chamber (throat chamber) firing a S3/S4 depending if your in TH/TH1 mode... But it's totally off-topic; and i prefer weird dual reflex bandpass arrangements that now hornresp offers (BPB/PBC) ^^
Old 8th November 2019, 09:34 PM   #4128
mlee is offline mlee  Canada
Ignore this post if you already know this but maybe needs mentioning again.
I believe group delay is directly related to roll off so ported sealed or tl can have the same group delay if they all have the same roll off characteristics. Eq can change the group delay so depending on application it might not be an issue for you. Also the audibility of group delay in bass region is large before it becomes a problem. I don't have a source for this on hand right now.
Also just a quick note on my limited testing with linearization of phase in the bass region. I liked it better with no phase correction below 100hz but testing wasn't controlled well. I also couldnt tell zero phase VS slowly increasing phase wrap in a 2 way system. Used rephrase on the same system to test.
Think before you speaker!
https://www.diyaudio.com/forums/full...bac25-4-a.html
Old 8th November 2019, 10:17 PM   #4129
I like to play with hornresp multiple entry horn and output frequency/phase to see group delay in REW. I'm not yet enough confortable with real crossover sofware, something that my brain don't want to work with whereas i love playing with hornresp. So, i play with ME1, the driver between the two others, to delay it more or less, filter more or less, to get with the same response curve, different group delay. Counter-intuitive, but with some destructive partially out of phase nulling, it works, and i start understanding how to move sliders to get what i want. But for that, i need a 3 ways driver at least for this "filler driver".
Here a example while i was trying to figure out how to remove the bumps in GD curve around 200-500hz. The only differences between all the curve are Eq/filters, and input power of the woofer filler driver working between 150-350 hz. The third picture shows promising effects.
And higher order sub (here a kind of 6th order bandpass 40-150hz set in hornresp as a 4th order bandpass + a lot of EQ to get same resultant FR/phase), needs + 5ms delay alignement of others ways as show when it group delay is showed separatly in last picture (don't look too much to artefacts).
Again...it's off-topic, sorry. Just to say, eq don't do all on phase. And FIR isn't anymore the futur ^^
Old 9th November 2019, 01:32 AM   #4130
camplo is offline camplo
#Random
This is the Axi2050 group delay on a 250hz jmlc
Is it possible to cover the whole spectrum, high spl, low distortion with a 2-way?Hide this!Advertise here!
cascode distortion Spectrum. mashaffer Tubes / Valves 34 22nd January 2017 10:37 PM
6av5ga distortion spectrum enzoastro Tubes / Valves 14 30th January 2013 07:01 PM
Distortion spectrum vs feedback artosalo Tubes / Valves 62 8th December 2011 12:51 AM
What do you look for in the distortion spectrum? keantoken Solid State 13 13th May 2009 01:06 AM
Tailoring distortion spectrum syl Solid State 14 25th March 2002 08:32 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
