Open source Waveguides for CNC & 3D printing!
Hi Augerpro,
I see you have routing templates for the T25, with 5/16" and 1" router guide bushings used to cut the recess and mounting hole respectively. Which bit diameter would be used with those bushing sizes? 5/16" bushings have a 1/4" hole for the bit, which might be a tight squeeze for a 1/4" bit.
Joined 2018
Erin just sent me the Klippel data of the prototype box using the MW16TX and T25B I posted above (and also SB17CAC and SB26CDC version). ABEC modeling paid off I think. Below are the plots of the individual drivers, followed by some reference speakers from Erin's website. I think the final speakers will measure as good as anything below. Crossover integration should be easier than anything I've done prior due to the waveguide, so minimal worries there.
Did you mean CDC rather than CAC here?
If so, which of the wave guides are you using here with the SB26CDC?
Thank you, David
Disabled Account
Joined 2019
Is there a mouth size among and a mid driver size to chose over another according to the listening sweet spot distance, please ?
I have read your WG had horizontal spread circa 110° that is optimal in mid-field up to 2.5/3 meters listeningg distance.
Is it ok to match the 6" WG to a 6" driver for 3.5/4 meters listening distance or your advice to reduce the mouth and mid size towards 5" ?
Or is there maybe somewhere a spreadsheet in the Net to calcul the mouth aperture vis à vis of the side walls and listener distance ?
I am wondering if it has to see with the final Directivity Index from the listener position ? Sorry for the ignorance...
For 3m or more distance to and between speakers - it would actually be benefitial to have narrower spread! You can calculate/estimate the angle your first reflections come form the wall, the speaker should send less energy there and already dampen 6dB.
But more important in my opinion is that the spread is EVEN and fits to the mid driver. And a rule fo thumb is that the WG should be about the size of the mid driver, so dispersion fits at the crossover frequency.
(cause you are sitting in teh far field at these distances and don't hear only first reflections but the whole room chaos. And this should be balanced.)
  • Thank You
Reactions: 1 user
^ here is quick test relating to size of things https://www.diyaudio.com/community/...ations-with-ideal-drivers.380658/post-7241612
Various sized woofers can work fine with a waveguide at least in the context of the test linked. DI hump around crossover can be tailored with multiple things like c-c spacing and delay. Baffle size and waveguide size, if separate, would also affect. Believe or not DI hump at crossover is slightly bigger if woofer and waveguide responses match exactly due to "perfect" destructive interference off-axis. If they mismatch some, destructive interference is less and less power gets lost, lessor DI hump.
I've got no opinion what sounds better or worse, and how big of a difference there would be.
Reactions: 1 user
Good evening, here is what I made for my Scan Speak 6600. Did it 10 years ago, had no calculation/simulation or something to know how to do it.
I did it to get the all the elements in a vertical line. It work good, but never measure it.
At my place have services mostly doing PLA - any major drawbacks for that in this application?
PLA being Fused filament has that ridged look to the print without further finishing. Whether that matters is in the eye of the beholder. Sand paper, filler and spray paint can fix that problem with some elbow grease. It also solves PLA's other drawback that it does not like UV and will degrade more quickly if exposed to sunlight.
Here are the newest designs for this recent batch of tweeters I've been working on. I haven't done any deep comparisons yet, so I have no commentary other than going to a bigger phase shield on the Satori really straightened out the 0 and 10 degree responses. After I cut the phase shield off, I tried it on the Scanspeak 6640 by using putty to attach it, and there was a similar benefit. I'll need to print a waveguide with the bigger phase shield to verify performance.
Reactions: 4 users
