Headphone Systems Everything to do with Headphones
LuFo Lite - a 1 Transistor SE Class A Headphone Amp
Thread Tools
Old 22nd July 2021, 03:32 AM   #31
Skip Pack is offline Skip Pack  United States
My question exactly. I have two on the shelf and have your Lu1014 boards and a stash of calibrated LUs.
Old 22nd July 2021, 03:47 AM   #32
xrk971 is offline xrk971  United States
Got Foam?
xrk971's Avatar
I forgot that I ran the sims a while back. Yes, 20mH is enough to double the output swing into 32ohms.
XRKaudio Store // Manufacturer’s Forum
Old 22nd July 2021, 07:50 AM   #33
marconi118 is offline marconi118  Germany
Logically you should double the mH if you double the speaker impedance....
So these 20 mH 6A crossover inductors could be candidate for 4ohm speaker LuFo with high bias let's say 4A
Old 22nd July 2021, 08:11 AM   #34
I am wondering how a jentzen 53333 47mH 2.5dcr would perform...
It is quite cheap at 15euro
Old 22nd July 2021, 11:53 AM   #35
Got Foam?
xrk971's Avatar
Lower impedance speaker requires more current, and that would require more stored magnetic energy, no?
For filters, inductor values scale with impedance, but this is not a filter but rather, a dynamic storage “battery”.
That Jantzen is an iron core crossover inductor with ferrite discs. I don’t know how much DC current that can take without saturating. It’s cheap enough to try?
Old 23rd July 2021, 10:15 PM   #36
Got Foam?
xrk971's Avatar
I just got a pair of LSA HP-2 dynamic headphones - these are waveguide loaded (front horn), closed back, graphene coated diaphragm drivers, 105dB/mW and 33ohms. Connected them to the LuFo Lite. In a word - wow! These are excellent headphones and the resolution and texture of the bass can really be heard nicely, the midrange is butter smooth and natural sounding. Very comfy and lightweight with real leather ear pads, headband, and wooden ear cups.
LuFo Lite - a 1 Transistor SE Class A Headphone Amp-edcfb0e8-c477-4673-8c5d-31d3b6c6c7be-jpeg
File Type: jpeg EDCFB0E8-C477-4673-8C5D-31D3B6C6C7BE.jpeg (479.0 KB, 461 views)
Old 24th July 2021, 05:26 PM   #37
Have you ordered your first test PCBs? If so would 4-6 weeks be a likely timeframe for ones we might purchase? (optimistic, of course). Thanks
Old 24th July 2021, 10:40 PM   #38
Got Foam?
xrk971's Avatar
No not yet, plan to soon. They should be here within 10 days if I order tonight. Sort of trying to consolidate a few more boards in same shipment. We will need to build a verification build. It’s pretty simple so I don’t expect any problems.
Old 17th August 2021, 03:45 AM   #39
Got Foam?
xrk971's Avatar
Here are the LuFo Lite BOM, schematics, and stuffing diagram.
Old 17th August 2021, 07:02 AM   #40
nautibuoy is offline nautibuoy  United Kingdom
nautibuoy's Avatar
Thanks X.
Here's another possible inductor for LuFo Lite, very cost effective!
https://www.mouser.co.uk/ProductDeta...4dDGW6C96rclk=
LuFo Lite - a 1 Transistor SE Class A Headphone AmpHide this!Advertise here!
Thread Tools
LuFo Amp - 39w SE Class A from 28v Rail xrk971 Pass Labs 703 20th August 2021 05:59 PM
Noir, a two transistor headphone amp: class-A, single ended, 150mA bias Mark Johnson Headphone Systems 319 16th August 2021 02:00 AM
OPA454 Front End for LuFo Amp xrk971 XRK Audio 9 30th June 2021 04:50 PM
Clone Audio Technica Class A AT-HA5000 FET Transistor Headphone Amplifier NTSBuilding Headphone Systems 51 21st December 2019 04:15 PM
Balanced Drive 2 Transistor SE Class A Headphone Amp xrk971 Headphone Systems 26 30th July 2019 12:44 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Copyright ©1999-2021 diyAudio
