Thank Dieter! But I don't understand your question: "what dimensiones do you took for it?"Hello vvxuan,
Nice Work yyou do. You wrote that you made a desingn for the Fostex Fe-103. what dimensiones do you took for it?
Dieter
Oh! Now I understand!Hell,
I mean the dimensiones of the enclousure. Do you have a drawing?
Thanks for your help
Dieter
I used fostex 103 - this driver quite good. You can use drawing for driver 4,5inch. If you want a design smaller, I can draw others to you. Let me know, how size you want?
I'm afraid that the size you want is too small, will not promote the full potential of driver.The speaker should be only 110mm=w and 350mm=h. Its the space i have on the sides of my computer monitor.
Here is the enclosure I used Fostex 103. size H50cm, W17cm, D20.5cm.
Here is the frequency response graph when I used driver Fostex 103
You can hear frequency range 65hz-16khz.
I can design an enclosure better, with size H40-50cm; W14cm; D30cm. You Ok?
Have a problem, you use Fostex 103 you must be cutting baffle hole diameter for driver are 9.3cm. If you use plywood 1cm then wide of enclosure at least is 12cm can not 10cm.Hallo,
when you can make it with a inner w=100mm it could be the best choice for me.
Ok! I will draw the dimension in side at least and the dimension out side you will choose! Wait me a few day.I knew, for building i must make some tricks. But this is not a big problem. with a inner wide of 100mm i can make the front 130mm wide. Thats enough to make a 93mm hole.
Hi DieterK!I knew, for building i must make some tricks. But this is not a big problem. with a inner wide of 100mm i can make the front 130mm wide. Thats enough to make a 93mm hole.
I'm sorry, I'm late!
Here is your drawing. I used plywood thickness 1cm, if you use other wood thickness,you need to keep the line sections are 8x8cm.
Good luck!
Hi DieterK!
Good luck!
do you know if this cabinet will work for W3-593? Tang Band W3-593SF 3" Full Range Silver Cone Driver
I like the size of this cabinet and I have the drivers.
Hi gychang!
I've drawn the design enclosures for 4,5inch type. if you use the 1.5 cm thick wood, the size of the enclosures will be H110cm W17cm and D29,5cm.
finally getting it slowly finished. I am not finished with cabinet but I heard the speaker for about 2 hours and it sounds full, will have to listen for more time but bass is sufficient, here is the youtube: https://www.youtube.com/watch?v=sy_bzMO0hu4
thanks vvxuan, nice cabinet for the speaker.
Greg, They blocked your YOU TUBE demo, just when I wanted to hear the results of this build! I have been waiting for this one, as you said you were going to do this build a while back. Anyway, I hope they sound as good as your expectations indicated. BTW they look Great!!
Mac
Greg, They blocked your YOU TUBE demo, ..
Mac
sorry, shouldn't have played recorded music without consent...
Got a listen this time Greg. Good bass and detail! I think you have a winner there!
Mac
- Full Range
- some samples box very good for full-range speaker
