You can build a pair follow this drawings. Use wood thickness 15mm.Yes 80 is ok for me, send me the design and i cut the wood on weekend.Regards!!
This design have Bass and Mid bass very good.
Notice: when you build, you need to noticed to make a symmetrical pair of speakers, sound hole oriented between two speakers.
This design have bass range about 40hz.
You can refer to assembling plate similar to cabinet for driver 12 inch.
Good luck!
Thank hectori, because you believe me!
How size do you want? H100xW25xD35 okie?
Do the H100 version have any advantages compared to the H80? Would be intresting to try that one.
You can see in page 1 or I will draw for you new drawings!Do the H100 version have any advantages compared to the H80? Would be intresting to try that one.
Hi Tubo! I think you can use plan for driver 12", it too big. Plan for 12'' are H150xW50xD45cm. How size do you want?
hi Vuxuan,
i will try to build the box for my audio nirvana 15cf. this will be a huge box. is this design optimized for this driver?
thanks again,
I think, It good, I don't understand how optimizedhi Vuxuan,
thanks again,
I have new plans for 10 inch drivers. Wait me some day.Hi, do you have plans you can share for 10 inch drivers?
Thank you!
Now I will post for all my box.
Very easy and simple
you can build in a week.
you need one Okan or MDF 1,22x2,44m
Hi vvxuan
Thanks for effort and sharing your job.
Regarding your TLs did you consider the open "mouth" in the back or oposite side of the box?
Is OKAN solid or plywood?
Hi vvxuan,I have new plans for 10 inch drivers. Wait me some day.
Thank you!
Is your 10" plans ready? I built 140liter closed box for my AD4000m philips full ranges some time ago. I wanted to try your TL boxes for them.
Cheers!
Yeah, I already. Wait me some days, this times I'm busy in my work.Hi vvxuan,
Cheers!
Here is new design
VVxuan
I'm very pleased to read your posts...well done on your ideas.
I see some good reports of the small 4 -inch Chinese driver.
Aliexpress.com : Buy 2pcs(pair) HiEND 4inch full range fullrange speaker defy lowther & fostex (new NEO SE edition ) from Reliable se w508 suppliers on GLOBLE HIFI SHOP | Alibaba Group
Can you advise the best cabinet for this? Thanks. Andrew.
Hi Vvxuan
I am having vintage "University 312, 12" 3-way Diffaxial" drivers. I don't know the TS parameters, but someone posted TS parameters for University 6201(Qts ~0.67, fs ~51Hz. (Qes~0.94) ) which is similar to my drivers.
Can you suggest any good design. I have also started a dedicated thread here http://www.diyaudio.com/forums/multi-way/271102-university-312-triaxial.html
Sachin
Sachin
I not have any driver coral, but I think this cabinet good for coral, because I I used good for many driver etc philips, klangfilm siemen, ishophon, rft, fostex, grundig, nirvana, gold wood, pioneer and some driver of Nga soviet..Hi, do you have test coral beta 8 speakers in your cabinet?
Hi Vvxuan
Sachin
Hi Sachin
I have many update version for TL enclosure. If you really care, I will send for you somes new design, better and easier.
- Full Range
- some samples box very good for full-range speaker
