some samples box very good for full-range speaker
Yes 80 is ok for me, send me the design and i cut the wood on weekend.Regards!!
You can build a pair follow this drawings. Use wood thickness 15mm.
This design have Bass and Mid bass very good.
Notice: when you build, you need to noticed to make a symmetrical pair of speakers, sound hole oriented between two speakers.
This design have bass range about 40hz.
You can refer to assembling plate similar to cabinet for driver 12 inch.
Good luck!
Hi Vvxuan
I am having vintage "University 312, 12" 3-way Diffaxial" drivers. I don't know the TS parameters, but someone posted TS parameters for University 6201(Qts ~0.67, fs ~51Hz. (Qes~0.94) ) which is similar to my drivers.
Can you suggest any good design. I have also started a dedicated thread here http://www.diyaudio.com/forums/multi-way/271102-university-312-triaxial.html
Sachin
Hi Sachin
I have many update version for TL enclosure. If you really care, I will send for you somes new design, better and easier.
