Home | Forums | Rules | Articles | diyAudio Store | Blogs | Gallery | Wiki | Register | Donations | FAQ | Calendar | Mark Forums Read |
Analog Line Level Preamplifiers , Passive Pre-amps, Crossovers, etc. |
Thread Tools |
#481 |
Hello everyone!
@Jean Paul: ![]() I started an implementation for a version with two channels of Kuartlotron (without power on the card Firstly) with standard components. Before going further, do you think that this provision is interesting? But as keantoken working to propose a layout, should I continue? Regard's! |
#482 | |
![]() You must continue working ![]() |
#483 | |
diyAudio Moderator Emeritus
![]() Just go on, if it is not for others it will be for yourself and it will make your skills better. I was busy with it as well but decided to change to a new GB project that needs much time.
It's only audio. Member of the non modular PCB design committee Last edited by jean-paul; 2nd September 2015 at 06:24 PM. |
#484 |
I got this far and then realized the MOSFETs were TO-247 and not TO-220. Why use such horrendously oversized devices?
The Kmultiplier rail filter! -=- The Simple Kuartlotron Superbuffer! Need something built, repaired or modded? PM me and ask what I can do! |
#485 |
With the DCB1 someone came up with running the MOSFETs at very high currents (so called "hotrodding"). This was supposed to sound better. I haven't tried but knowing that the circuit only draws a few mA I never even bothered. In my Mezmerize samples I used small heatsinks in standard config but let's say the MOSFETs only get lukewarm at standard current even without the heatsinks. Maybe Salas can give advice on suitable TO220 devices. I would add TO220 heatsink pads for heatsinks that can be soldered on the PCB in case you will use TO220 MOSFETs.
BTW "horrendously oversized devices" is a standard in audio land. I bet they won't break down in this application ![]()
It's only audio. Member of the non modular PCB design committee Last edited by jean-paul; 2nd September 2015 at 06:41 PM. |
#486 | |
#487 |
Do as you like but that is cross wiring. They taught me to keep inputs grouped together, same with outputs.
It's only audio. Member of the non modular PCB design committee |
#488 |
It needs a TO-220 part that's as slow as the IRF240 to make it stable. Or I could just add another resistor and use the IRF710. Thoughts?
#489 | |
What say you? // |
#490 | ||
![]() Quote:
It's only audio. Member of the non modular PCB design committee Last edited by jean-paul; 2nd September 2015 at 08:44 PM. |
Thread Tools | |
Thread | Thread Starter | Forum | Replies | Last Post |
New error correction amp | PMA | Solid State | 101 | 3rd January 2011 11:00 PM |
error correction et al' | sq225917 | Digital Source | 4 | 7th August 2007 10:16 AM |
Visual error correction? | Circlotron | Everything Else | 4 | 15th September 2003 04:17 PM |
New To Site? | Need Help? |
