@nautibuoy
This allows the amp to deliver twice the current in the speaker, so it will only give you more output if you put another speaker parallel or use another type of speaker with half the impedance.
Thanks.
So, with the configuration I mentioned, with 8ohm spealers and 24V supply, I would have a stereo 30W amplifier.
Hmmm, will that be enough?
Hi Lutkeveld,
I am wondering about the function of the EQ button. Does it immediately change between 2 DSP configurations or only after reboot?
I would like to use it to switch between 2 different filter/crossover settings. This would be a nice feature.
Best regards
Walter
Best regards
Walter
Hi Lutkeveld,
Best regards
Walter
Best regards
Walter
Hey guys,
can someone plz send me the beta software version for real stereo 2.1? I'm waiting for months now, to setup my system correctly. Thanks alot!
greez JazzJack
greez JazzJack
Luke, I love these amps! They produce simply amazing sound and are almost infinitely tunable. Unfortunately I have blown one of the chips. I sent you an email with the picture. I had JUST gotten the EQ settings tuned almost perfectly! please let me know if there is anything you can do thanks!
Hi
I have no sound. Have paired the bluetooth, The power led is green and bluetooth blue??
Is there someone who can give me ideas of where i should start troubleshooting?
You have double checked all of your wiring, especially to the speakers?
The two leds functioning suggest the power is ok and you paired your bluetooth device.
check the blue tooth volume at the phone or tablet is set at least midway, and not muted.
turn the rotary volume control a few turns clockwise and maybe go through the pairing process you should here some sound as they pair up.
Did you get the programming lead and if so have you connected that to have a look at how the board is configured.
support
yes Luke is very helpful and provides awesome support. I've had quite a few of these amps 🙂
I had the same issue with a burned TAS-Chip. But Jesse replaced it without hazzle. Great Support!
My 2nd Zoudio powers this.
4 channels happily pushing a pair of these! Running off a pair of 12V lead acid 7-9AH batteries, starting at 25V full charge. After a few hours listening, dropped a whole 0.25V. No hum, noise, ground to the house wiring - it's fully floating, as I'm using the BT from my W10 laptop PC. Spec for the TAS chip (all of them) says 30V absolute max, I assume beyond which the little silicon crystals inside crack due to voltage stress. I'm running so low power, I'm not worried at all about burning anything starting out a volt over 24 -
One aspect of the OBs is that I can be listening at a comfortable level - with a kid sleeping in the room across the hall. Leave my bedroom and nothing in terms of far field sound propagation.
I cant say enough about the sonic clarity of this little amp. I've looked around and it's hard to find an amp with a direct digital signal path to the speaker terminals. They all seem to have to go through a capacitor on the way. The TAS5756, popular in the rPi hat amps, actually brings the DAC out on a pin, where it then goes through a 2.2uf ceramic, then back into the chip. (what were they thinking? Negative feedback from the speaker terminals?) On my Amp 2 hat, it's of course manufactured with the cheapest possible peripheral components, without a second thought given to that particular p-o-s. At 0603 - maybe 0402 - it's hard to modify to put in something better - I wonder how many other little class D amps are made like this? Most of them?
Anyway - happy owner of a 2nd Zoudio, now powering a second system. Really enjoy the purity of the sound - fiddling with the EQ curves to dial it in.
Thanks, Jesse for bringing this out. It's a treat!
Yes.Does the start-up chime and BT chime go through XO filtering in the DSP?
12-24VDC, preferably under 26V. most 6-10 Ampere PSU's should be good.Which power supplies are reccomended?
Lutkeveld hasnt been active here in nearly two months.
Is he out of bussiness?
Nope. Just spoke with him the other day via email. Maybe use the contact form on Zoudio.com if you need to get a message to him.
@walterhw
EQ changes instantly
@superlian
Sorry for the late response to the thread.
Send me an email and I will help you out.
Manufacturing has been difficult lately with all the component shortages going on.
Im busy with setting up manufacturing locally and securing stock.
Also working on new products.
@jjasniew
Thanks for the compliment!
@superlian
@jjasniew
Careful with Lead acid batteries, I think when fully charged they are actually over 13V each if I am not mistaken.4 channels happily pushing a pair of these! Running off a pair of 12V lead acid 7-9AH batteries, starting at 25V full charge. After a few hours listening, dropped a whole 0.25V. No hum, noise, ground to the house wiring - it's fully floating, as I'm using the BT from my W10 laptop PC. Spec for the TAS chip (all of them) says 30V absolute max, I assume beyond which the little silicon crystals inside crack due to voltage stress. I'm running so low power, I'm not worried at all about burning anything starting out a volt over 24 -
Oon
Oon, If they are the same as an automotive battery nominal power off charge is 12.6v. So yeah it would put you just over 25v. Iirc the absolute max voltage input of the amp is like 28???
- Vendor's Bazaar
- ZOUDIO AIO4CH: 4-channel amplifier with DSP and Bluetooth
