Zero Feedback Impedance Amplifiers
zeus amp old DIY
Further thougths, I have a pair of jordans and I would dearly love to construct this amp. At the moment I am listening to mark fenlon's 4inch units full range driven by moolys amp the idea being the neg feedback, clamps the coil.incidentaly, mark fenlon is an english engineer who worked with ted jordan for a while, he is on the internet and his speakers are available from mouser.
Input transformer. Plain. You can balance. Secondary with a middle outlet. 2 MOSFET with a common drain (push-pool follower). Low voltage. Large current. Class AB bias circuit without shutdown. Output transformer with special technology. With middle bend. Secondary winding for loudspeaker. Low distortion (0.18%). Wide band 20Hz-100kHz. High power. Short signal path.
zeus amp
OK GUYS Letts follow susan, bias is set at afew hundred milliamps ok, q1 andq2 are used as gate followers which alter the voltage on, and thus the current flowing through the output transformers primaries, nothing new here.
the center common is to ground. of course it will not work otherwise. any input signal on t1 is magnified by the turns ratio and causes the q1 andq2 to follow the voltage on their gates, one device rising the other falling.of course this is how amps work, so nothing new here.I do not understand what susan means when she says the output tx generates the negative rail surely the power supply does that? this not meant to be a criticisme of susan as she is far more educated than me
This amplifier is simple and not stupid, but smart. It's like seeing a final equation after been simplified. You can go around and around and then you will realize why Susan concluded her design in this way.
In this amplifier the active parts provide no gain, actually the gain is less than 1 because it's based on gate followers design. The gain is done by the interstage transformer (or input transformer) that transforms the low voltage low impedance signal from the line stage to a higher voltage higher impedance sufficient for driving the gates of the two mosfets that btw are not complimentary. The final version of Zeus also uses depletion mode mosfets that get biased by the voltage drop through the output transformer internal DC resistance. So the bias does not require active parts.
And yes the B+ of 37V 700mA (single supply; there is no -37V) applied on the 2 drains flows to the grounded centre tapping of the transformer and when the voltage at the source of the two mosfets start swinging it generates positive and negative voltage on the secondary. For example assuming 1:1 ratio you will have in theory -37V to +37V swing. There is no need of positive and negative power supply rails because the transformer generates them.
The distortion of this amplifier reaches a certain value and it remains nearly constant with the increase of output power.
Susan,
Gate should preferably be referenced ohmically to source (here by a rather low value resistor).
Zener diodes are notoriously slow devices and provide poor protection.
The Hitachi LFETs come with more reliable built-in protection diodes.
Zener diodes are not nice devices.
Your posts emanate an aura of serenity.
