What did you last repair?
How to save a Dewalt DW207 trill:
To replace the Ni-Cd batteries DW9072 of my old 12 volts Dewalt DW207 working still great!
Old batteries were 10 * 4/5 Sub-C Ni-Cd batteries
Did plug in 4 * Samsung 18650 batteries with a BMS 30Amps for 4 cells... tight fit... really ... but a nice challenge!
(1 * VS-ELEC 4S 30A 14.8V 18650 BMS PCM and 4 * Samsung INR 18650-25R 3.6V 2500mAh )
A connector to provide DC 16.9 volts and 800 mA to charge the cells...
It works! 😎
It works! 😎
Just a few last pictures... I did use the cardboard envelopes to push the connector in place.
I believe that the InTech is the same DOHC V8 also used in the Mustang SVT Cobra. If so, I helped my nephew changed plugs on his about 10 years ago. BTW, I love the Mark VIII. I'd rather have one than a Mustang as they're roomier and less noticeable.
Indeed, that InTech engine is a stong bugger, even in the Mk VIII.
It's hard not to burn rubber from a redlight stop, the car's got so much low-end torque.
I had the transmission rebuilt back in 2005, and modified with the upgraded shift accumulator stuff - piston-springs - Mercon 5 fluid - etc.
This noticeably improved shifting performance, no lagging.
I also modified the air-intake system... it growls nice when you "step on it", yet purrs on the road.
When I took it for a road trip in September 2005 Philly to Winchester Va (to the Patsy Cline event), that Lincoln just breezed down the interstates and was a delight to drive. It's really a highway car.
Because in the city here it guzzles 12.5 miles a gallon, highway I got 26 MPG.
The JBL Premium Sound system is awesome too, and I added some "low end" with a dual 8" sub in the trunk with a 300W amp.
Sadly, I retired it to the back driveway years ago, it's "classic" status now, one day I'll put it up for sale "as is".
It ran great right up to its retirement, but will need work from sitting idle.
Reactions: AstroZon
Grass is always green here 🙂 It is very rare here to see lying snow, maybe once every few years and it lasts no longer than a few hours.
Shh.. less talk of grass.. and jokes.. the Mrs isn't seeing the potential in either.
I'm "repairing" the lawn.. after it was a staging post for 40+tons of sand from the pond excavation. It goes down 1.84 meters (over a meter below the window).
