"WHAMMY" Pass DIY headphone amp guide
I hear rumors of a possibility of a discrete from Nelson.
Oh, good to hear about. Just knew, that there was a paper, older one from Nelson, containing some general information. So this is good news. Timing from rumor to execution might be tempting for us greedies.
Whammy 5W class a power amp maybe? For 100db+ speaker. To have a low power alternative to ACA without lytics in order to power mids and tweeters in a multi way system. Just an idea - and by the way I really like my ACA.
Hi Guys,
Need your help just finished the Amp and there seems to be something wrong my Right Channel. My Voltage rails are fine +16.7v & -16.7v. However my right channel is not putting out much power at all, and its square wave looks sick...
The only non-standard thing I have added is a feed from R10 & R14 to the v12 LED (power Switch) with a 4.7K limiting resistor on the R10 +V link side.
1Khz Signwave 1vp-p Right channel is ~2mV and Left is 100mV
1Khz Squarewave 1p-p - Right channel is 10mV and Left is 100mV
Any ideas where to look next, could this be an issue with my OP-AMP its a Burr-Brown OPA2134PA without the 100 pF caps.
Mark.
I don’t know how to edit previous so I post a new one.
I almost finish my WHAMMY with previous version PCB. Hook up the power socket and wire and I am done with this project. I tried to connect the power everything seems fine. I hear no noise of any kind. Just wondering if I have to install the capacitor between the negative of RCA and ground.
False alarm all good.
Ok I found the issue, I just noticed a hard to see x10 switch on the CRO leads, I must have knocked one to x10 rather that x1, I guess what threw me off was the dodgy looking square wave, Doh.
So now both channels look good and the square wave looks right now 🙂
My Beyer DT-1990pro's sound unbelievable on this thing, super happy 😀
The FFT Graph looks good, 2nd 3rd and 4th harmonics @ 3 4 & 5Khz
Just before I tidy up the wireing
Front with power switch
Mark.
