I actually found i don't have a need for 15V with the AD823 I'm using, the standard rails should work just fine, correct me if I'm wrong. My current issue is in where to mount the IEC inlet and RCA jacks. I'm using the hammond chassis and a large IEC inlet that sticks too far to mount behind the transformer. I'm thinking of mounting the inlet essentially as close to the transformer as I can get, but am wondering whether I'm better off mounting the jacks on the left side of the back panel (closer to transformer but shorter cable run) or on the right of the back panel (longer cable run, closer to inlet, but further from transformer)?
Does shielded cables exists that are relative thin and flexible?
I like PTFE but that kind is a bit stiff and a little hard to handle. Especially for shorter distances.
Definitely using shielded cable 🙂 just wondering if placement of that cable made much of a difference. I’ll try routing it the long way, and I can always shorten the cable!
I like Mogami cables for signal stuff, they have shielded 1,2 and 4 wire stuff in a range of stiffness and thickness
Canare L2B2AT is also nice, it is lavalier microphone wire. I used that for my WHAMMY. Very thin and easy to work with. Not too expensive on Ebay either.
That is twisted shielded pair? When used for RCA ("single ended") do you use pair (both wires) for signal and screen as gnd or only connect screen in one end and then use the twisted pair as signal and gnd? one benefit of screened twisted pair is that you can get the best from both worlds when used "single ended"? …..both twisted and screened? ….so it will reject both "magnetic noise" and RF?
But don't think many use it that way?
In the whammy i used the screen as gnd (joined for both RCA ins) and one conductor for each R and L +. I think i did the same for my BA3-pre, but i believe i did what you suggest (screen only connected one end) for a recent kuartlotron. I don't know how they compare, none were noisy.
Well, I must of done something to break my whammy Today I replace the cheap mic cable and unsealing output wires with higher quality shielded mic cable. When I reassembled it, I got smoke in the PSU section :-(
When I add power, the resistors in the PSU section get extremely hot, very fast. Any ideas? Thanks.
Something is shorted. The hot PSU resistors means there's lots of current flowing somewhere...
Thanks. Is it possible I damaged the board desoldering some of the wires? I order the get the solder out of some of the holes, I held the iron to the board for a while to heat the solder for the sucker.
I’ll go over everything tomorrow to see what might have shorted.
Ug. I cannot find a short; at least it's not obvious to me.
Here are some images. Anyone see anything or have an idea how to find a short?
IMG_0841 | Allan Marcus | Flickr
IMG_0844 | Allan Marcus | Flickr
You said you got smoke in the PSU, where? Those need to be replaced.
I think R37 and R20. The smoke might have been the solder heating up. I unplugged it pretty fast.
There is continuity between the two AC inputs, so that's is not good.
I'm guess it's really hard to find this type of short. Is it possible the short is in the board? Should I remove one item at a time until the short is discovered? Or just start over?
Did you try measuring the resistance between the ground and signal at the output
terminal?
I'm not sure how to measure that. When I connect the leads from MM on the ohm setting, it bounces around a lot.
I'm considering building a WHAMMY for both headphone and pre-amp use. I'll probably use a switching headphone jack, as suggested before.
An issue I see might be excessive gain, so I'm thinking about including a gain switch. Am I correct that I would have to switch both R1 and R12 (e.g. between 1K and 10k for unity)?
Any comments on performance on unity gain? Would I be better off building a buffer instead and stick to my separate headphone amp? Would be nice to have both in a compact package though.
Power amp is a Yamaha ax-596 in power amp "mode" (100W class AB), until I build something different.
I've built some kits before, but this would be the first "semi-free" build.
You will measure some low resistance on the AC in it is the transformer primary. If R37 and R20 smoke you have a problem with the + supply. Connect a meter to ground and measure resistance on pin 1 and 3 of the 7815.
Between 1 and 3 on the 7815 measures 5Mohm and then slowly drops if I hold the probes there.
There appears to be a possible solder short between 2 legs of the opto coupler. There is also a piece of solder stuck to the bottom of the board that may be shorting 2 traces if it melted through the mask.
- "WHAMMY" Pass DIY headphone amp guide
