I think that it would be "safer" for you to use your existing amplifiers. Buy another fullrange speaker (whichever you can afford it) and be happy with it. Sell the Visatons or leave them in a box for another time/project.Can you name any transconductance amps
Also what do you think about gold leaf instead of alu foil
By the way, which B&W woofer are you using? Any pic?
@goodguys
I described two techniques:
household alu foil and silicone sealant (glue is applied thinly on the foil)
or
thinner foil from the goldsmith and the glue they sell with it in german called "Anlegemilch". (glue is applied on the cone)
The thinner one I use for smaller drivers or whizzer cones.
The B 200 is a high efficiency light weight cone so I would buy the thin foil.
But household foil would do very well, too.
One sided already makes a big difference in sound.
You can do A/ B listening test modifying one driver versus the untweaked one with the balance knob on your preamp.
Here you find pretty much all info:
or
Hello,
here I want to describe how I do make a sandwich cone with aluminium foil.
This can be done with normal household aluminium foil and normal glue you can buy everywhere as "universal glue".
You need a scissor and the materials like aluminium foil, glue and the loudspeaker.
The foil can be applied easily to paper cones / diaphragms.
You can use thin aluminium foil from the gold smith and the glue they sell (in german "Anlegemilch") for making sandwich cones with polypropylene loudspeaker cones as here normal glue will not work. Also for delicate whizzer cones the thin aluminium...
- Freedom666
- Forum: Full Range
Vix: Hi. I am using the drivers from an old b&w dm220. They were good speakers in their day.
But it's really the full range drive unit i am interested in, i can change the b&w drivers as i have a ton of drivers from other projects
I need to get the full range unit addressed then decide how much support it needs from other drivers
@Freedom666
I think it is better to get some practice with cheaper speakers. I wouldn't do this modification directly on the B200 if I had no prior experience on this. Also, transconductance amps require some DIY knowledge, how to get them right.
That's why I suggested a purchase of other "more neutral" fullrange drivers.
If he has the means, Moap 10.2 are very good, but expensive. If he wants cheaper, Pluvia 7.2 hd is a good conpromise.
10.3 is a good driver, but has some peak at 7 khz or so which can be annoying.
I solved that by a thin coat of dammar on the membrane, and a transconductance amp, with a bit of filtering...
Thanks ! Is there much difference in sound quality between the units, people on other forums are saying there is not much between them in real life listening.If he has the means, Moap 10.2 are very good, but expensive. If he wants cheaper, Pluvia 7.2 hd is a good conpromise.
I would not like to pay the extra money for moap then struggle to hear improvements over pluvia or alpair
Thank you
just be prepared for a completely different sound.
Its underestimated that a composite material of metal and paper gets the best from both worlds:
damping from the paper and the tensile strength of the metal adding stiffness.
At the same time resonances are damped giving nice waterfall responses
the modern optimized full metal cones must be good although I never listened to one until now.
The diy alu foil trick with already existing paper cones prevented that I buy some Jordan watts alike drivers.
I tried two times full metal cone drivers which looked good from resonance behaviour but the remaining "singing" was annoying so never used them for fullrange puposes.
What's the reason for these conductance amps sounding better, my quad 909 and topping pa5 II are highly ratedVisaton B200 is a good driver. But it is really picky about the amplifier. It does not sound good with a typical solid state amp. You have to either try it with a tube amp, or a transconductance one (Pass F1, F2, some chipamp mods).
If you are not ready to change amps, then...you change the Visaton. Markaudio Pluvia 7HD or something similar is a safer bet...
@goodguys
current driven amplifiers offer reduction in distortion by 10 to 20db(!) compared to classic voltage drive
for fullranges:
EQ for free in highs and lows due to impedance interaction
https://www.current-drive.info/disto/65
https://www.passdiy.com/project/amp...e-amplifiers-and-sensitive-full-range-drivers
for fullranges:
Thanks ! I didn’t get a chance to read the full nelson pass document, it’s above my knowledge. Is Pass saying that transconductance amps make all speakers sound better than when compared to solid state, or is it just full range drive units@goodguys
for fullranges:
Also my quad 909 has an output current of 22 amps, does that help in any way or is the transconductance still better
Which chip amps are transconductance
It is no longer possible to use the Markaudio model ranges to sort drivers into quality,
MAOP 10 > Alpair 10.3, CHP-90 is the descendant of the A10.3. A11ms is different.
Pluvia 11 is not in the same league. P7HD is really good, P7 and P7HD not near as good.
Paper cone drivers are voiced different.
midTweeter size: Smaller will tend to have better top, larger drivers will let you pay louder and cross lower. XO placement should be based on the baffle used.
I’d use MAOP 10 or MAOP 5 (is there still a MAOP 7?)
dave
dave
An elctrodynamic driver is a current device, so a current amp directly drives the loudsopeaker without an IV conversion, but they are also sensitive tomthe loudspeakers impedance so greater care with loudspeaker matching. If you are biamping many of the impedance issues go away.
dave
dave
@goodguys
i made a real newbie thread on this with the big patience of the pros here for which I am grateful
Nelson used the "simple resistor method" using 22 or 50ohms in line with the speaker to get current drive effect although losing efficiency you can make a listening test the easiest way like this.
series resistance method explained here
https://www.current-drive.info/9
using complex crossovers gives to midrange and tweeters often unknowingly a little bit current drive(!)
I wonder if someone tried to make from a chip amplifier a current amplifier design (inspired by Esa Merilainens - current drive info Website) if that is technically possible.
Maybe it is easier to do that with a chip amp or it is not possible at all. At hand I have some amplifier with TDA7266 soon - which has two times seven watts.
Would like to hear some feedback on this, maybe a modification of an existing mini-amplifier from the far east which could be found easily on ebay.
It would be enough for me to have two times five watts, just in order to hear such an amplifier together with...
- Freedom666
- Forum: Chip Amps
@goodguys
impedance linearized multiways could be driven with the sophisticated amplifier from baffles I posted here.
It uses voltage drive in the lows controlling bass driver resonance while offering current drive for the upper frequencies which profit most of this type of amplifier.
Fullranges harmony naturally with current drive amplifiers.
Multi ways can have problems the amp following their impedance curve and deforming the already linear response.
The quad design I don't know. Maybe someone else can give advice here.
Thanks ! I've ordered a pair of the moap 10 from kjf audio, will be arriving on monday i'll let you know what i think of them in open baffleIt is no longer possible to use the Markaudio model numbers to sort drivers into quality,
midTweeter size: Smaller will tend to have better top, larger drivers will let you pay louder and cross lower. XO placement should be based on the baffle used.ing
dave
At the moment i am using a £650 focal ic706v which someone on another forum used as OB and really liked it. I'll replace the focal with the moap and see what happens
- Full Range
- Visaton B200 upgrade
